Telluride to Moab in July
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cdex8357, Jun 16, 2020.
  1. Jun 16, 2020 at 6:01 PM
    cdex8357
    cdex8357 [OP] “Everybody gotta die sometime”
    “Dex”
    H-Town
    2013 Taco OR
    Mid travel FOX 2.5 Coilovers FOX 2.5 secondary bypass FOX 12” Triple Bypass
    Planning a trip in July to Telluride with the wife, we are staying a few nights in Telluride. My wife wants to spend sometime in the town. I dont know what to expect with COVID. We will start early on our first day in Telluride.
    We planing on hitting the trails, i at least wanna complete Black Bear Pass, Imogene Pass, and Ophir pass. If we have time maybe any other trails yall can recommend.
    What is the suggested order i should tackle these in? so i'm making the best of my time...
    i thinking two tails a day. one day is set aside and we will be hiking.
    Then we will push on to Moab, Utah.
  2. Jun 16, 2020 at 6:10 PM
    durtkillon
    durtkillon Well-Known Member
    Kurt
    Fort Collins, CO
    2010DCLBV64X45SPAT 1E7 BASE
    Sickest Mod: Synthetic Oil
    Depending on your set-up and tolerance to pucker, Engineer Pass/California/Corkscrew is a tad milder than Black Bear, which has a very narrow, exposed section. You can eat in Lake City and fuel up. All good choices, however. You will love the passes between Telluride and Ouray.
  3. Jun 16, 2020 at 6:15 PM
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    Engineer pass looked beautiful.
    high tolerance!! and mi "Vieja" will have to buckle and shut up.
  4. Jun 17, 2020 at 5:25 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Check but believe Black Bear is one direction dropping down into Telluride - was years ago when I did it.
  5. Jun 17, 2020 at 5:43 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    You are correct.
    It's not expected to open until mid-July, so....
  6. Jun 22, 2020 at 5:00 PM
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    we planning the week of July 20th, how do i find out if it will be open.?
  7. Jun 22, 2020 at 5:12 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
  8. Jun 22, 2020 at 5:20 PM
    Naveronski
    Fort Worth
    Easiest is on FB. There are several groups and pages that post updates daily.
  9. Jun 22, 2020 at 5:22 PM
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    thanks for the link, that's what i was looking for.
    dont plan on it..
  10. Jun 22, 2020 at 5:25 PM
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    cool, i try..that..
    any idea whats the best order to tackle these
