Temp check mode, OBD missing required pins
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Furion486, May 28, 2023.
  1. May 28, 2023 at 7:00 AM
    Furion486
    Furion486 [OP] New Member
    I have a 2021 Tacoma I was getting ready to drain and fill the transmission and I noticed the pins I need seem to be missing on the OBD port.
    Is there another way to put the vehicle in temp check or am I missing something?
  2. May 28, 2023 at 7:23 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    20 and newer I believe, have a newer, better, easier way to put into temp check mode. sorry, I do not have a link to help you. Ski
  3. May 28, 2023 at 2:45 PM
    crashnrondo
    crashnrondo Well-Known Member
    Ron
    Wisconsin
    2021 DCSB Limited
  4. May 28, 2023 at 3:04 PM
    H6G
    H6G Well-Known Member
    Far from home...
    ‘18 Blk. Pro/ ‘17 GT350
    '22 Pro suspension/ Custom Deaver springs/ ECGS and...
  5. May 28, 2023 at 4:09 PM
    Furion486
    Thanks for the info.
    It appears to have been under filled from the factory, I drained maybe 2 quarts out of the pan if that.
    40k miles on the truck.
  6. May 28, 2023 at 4:47 PM
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    You don't need to mess with the OBD Port. Just follow the procedure below.
    AC60F (AUTOMATIC TRANSMISSION / TRANSAXLE): AUTOMATIC TRANSMISSION FLUID: ADJUSTMENT; 2020+ Tacoma
    To enter automatic transmission fluid temperature detection mode:
    Depress and hold the brake pedal.
    Start the engine. [#1]
    Turn off electrical and mechanical loads
    Slowly move the shift lever from P to S, then move the shift lever to P. (~3 seconds each position [#2]
    While observing the D shift indicator on the combination meter, move the shift lever back and forth between N and D at an interval of less than 1.5 seconds for 12 seconds or more. [#3]
    Perform #1, #2, & #3 within 60 seconds
    Check that the D shift indicator comes on for 2 seconds.
    Move the shift lever from N to P.
    Release the brake pedal.
    Allow the engine to idle until the automatic transmission fluid temperature reaches 35 to 45°C (95 to 113°F). The D shift indicator will come on again when the fluid temperature reaches 35°C (95°F) and will blink when it exceeds 45°C (113°F).
    Performing this operation will cause the vehicle to enter fluid temperature detection mode and engine idle speed control mode. In engine idle speed control mode, engine idle speed control starts when the fluid temperature reaches the specified temperature and the engine speed is maintained.
    shotgunbilly420 and Josh-L like this.
  7. May 28, 2023 at 6:13 PM
    terry5008
    terry5008 New Member
    Georgia
    2020 Taco TRD Pro
    I was just trying to figure this out today and low and behold, here is this post. Now that's timing!:amen:
    Looks like SSMTRDOR did a copy and paste from Toyota TIS. I will attach a copy of that as a print to PDF. Go to the section "(b) When not using the Techstream:".
    So, I'm wondering, is the part where you shift from P to S to P even needed? He didn't do that in the vid.
    shotgunbilly420 and SSMTRDOR like this.
  8. May 29, 2023 at 11:02 AM
    terry5008
    Georgia
    2020 Taco TRD Pro
    Yep! Works like a charm on my 2020. While watching the big D, I had an OBDLink MX+ connected to the OBDII port and was watching the temp. I recorded a range of 97.3 to 115.3 degrees F at 700RPMs. I didn't time how long it lasted, but it was more than enough time for the job.
    I wonder what you do if you live in a place like Arazona and your truck has spent half the day sitting in 120-degree heat.:confused:
  9. Aug 8, 2024 at 1:39 PM
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    Im dealing with that now. I'm wondering how long it takes to cool down
  10. Aug 10, 2024 at 12:39 PM
    Tacogent
    Tacogent Well-Known Member
    Nonw Stock
    I live north of Tucson, AZ. I check the trans oil level being the second thing I do in the AM ..... after the truck is sitting, not running all night ...
    when its about coolest during the day.... After coffee ....
    Its 103F now and tomorrow AM its suppose to be 85F at 8:00 AM ..
    Wait and test then
  11. Aug 10, 2024 at 1:15 PM
    2k2
    2k2 Flareless
    Zak
    See Build Thread
    Yeah. I had to park in the garage and wait about 3 hours.... Even then it immediately was in temp check mode (solid D)... Before that it was in overtemp (blinking D).
  12. Aug 10, 2024 at 7:07 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    It is my belief that the P to S and then back to P is to make sure all the passageways and valves are full of fluid before doing the level measurement. Necessary with just a "level check" or a simple incremental "drain and fill" probably not, but if you were doing any dropping of the pan and changing of the filter I'd error on the yes - do it. Myself, I will, and do.
    According to other threads on this site the transmission does have a filter - I have no specific knowledge in this area, yet.
    Edit:
    That filter is more often described as a "strainer".
  13. Dec 29, 2024 at 5:21 PM
    dougluvgold
    dougluvgold Member
    Douglas
    2023 tacoma trd off road 4x4 dbl cab
    What about the trans thermostat valve that sone mention depressing and putting pin threw hole to hold it open . Should that be done on level check no drain or replace of parts just che k . It doesn't mention it anywhere in the file so mixed thoughts on if important or was that not added because specific type 4x4 or with trans cooler
  14. Dec 29, 2024 at 5:36 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    At Level check.
  15. Mar 26, 2025 at 4:03 PM
    Stormpeacock
    Stormpeacock IG: @storm.peacock
    Rich
    Atlanta, GA
    19 Cement Offroad
    MCB Elite Performance Tuned 5.29 Differential Gearing 35" Kenda M/T on Steelies SOS Bumpers, Skids, and Sliders Ranch Camper Shell
    so I had the thermostat pinned during the initial drain…
    Are you saying that I have to have it pinned during the level check and overflow opening?? I know it’s not a lot of fluid but I was wondering if I was a bitnoff
  16. Mar 26, 2025 at 4:31 PM
    Vlady
    Issy, WA
    It needs to be pinned down during the procedure. Needs to be pinned down prior the engine start.
    This is how i do. Also see tundra level check procedure
    -check tranny temp (OBDII)
    -drain the fluid.
    -crack the overfill plug and hand tigh.
    -pinned the thermostat
    -fill the tranny
    - start the level check procedure.
    -adjust the level.
    -shutdown the engine and unpin the thermostat.
    Stormpeacock[QUOTED] likes this.
