Temp control light fix ???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by savoy, May 13, 2011.
  1. May 13, 2011 at 6:03 AM
    savoy
    savoy [OP] tacoma 4 life
    Josh
    Fort mcmurray, Alberta
    06 Tacoma double cab black
    Pro comp 6" lift, afe intake, flowmaster duel exhaust, dick cepek 35" mt's, and black XD rims
    Hello all
    I apologize in advance I can't search the forum. On my iPhone when I click the search box it closes safari
    That aside. I'm wondering if anyone has seen a post on how to fix the light for the tempature control. The furtherest one to the passanger side the "fan setting" light isn't working.
    Is this a easy fix. ? Or do I have to rip the dash apart to get in there
    Thanks for the help
    Savoy
  2. Aug 17, 2011 at 4:22 PM
    spares
    spares Canadian Bacon
    New Brunswick, Canada
    06 DCSB TRD Sport
    did you ever figure this out? mine is out now i want to know how hard it will be to fix
  3. Jun 25, 2012 at 4:55 PM
    denboss
    denboss New Member
    Dennis
    Corona, CA
    06 sr5 pre runner
    The whole temp unit pops out. I just grab the knobs and pull towards you. Sometimes the knobs come off so I have a little hook that grabs the unit. Disconnect the wires ( two plugs) and look in the back of the unit. The bulbs are near the top and are little twist off knobs. Turn with a screwdriver and they will come out. Toyota sells new ones for $14.00 each. A bit high so if you can find a pick a part yard you proberly can get the whole unit for $10.
  4. Jun 26, 2012 at 11:59 AM
    dexdawg
    dexdawg Well-Known Member
    Frederick, MD
    2010 DC SB OFF-ROAD
    I just replaced mine like 2 weeks ago. Just pull on the knobs and the entire piece comes out. Be careful not to break clips. Unhook the plugs and small bulbs are very easy to replace. Got my bulbs from www.candlepowerinc.com.
    should be KT928 under Japanese Dash & Indicator Bulbs. might have to buy more then one but cheaper the dealership.
    I just check and it says they are out of stock right now.
  5. Jan 1, 2013 at 4:06 PM
    mrbee
    mrbee Member
