Temp display problems
Discussion in 'Audio & Video' started by bigragu, Nov 29, 2011.
  1. Nov 29, 2011 at 2:55 PM
    bigragu
    bigragu [OP] Member
    Tacoma trd
    Temp display/navigation not working any suggestions on where to get one cheap? I've read the threads about how to fix this issue, the problem with my unit is something different not the 510 circuit, it's a smaller connecter that's come undone, to small to soldered.
    Thanks
  2. Nov 29, 2011 at 5:08 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2008 F-350 Powerstroke
    You're talking the overhead console one right? Not something aftermarket....
    I'd suggest hittin a pick and pull or something. If you want, you can send it my way and I can TRY to fix it. Its a pretty simple circuit.
    Have you checked your fuses?
  3. Nov 29, 2011 at 5:10 PM
    brian
    Elizabeth City, NC
    Oh and it being a smaller connection.... you just need a smaller soldering iron. if you're sure its a solder joint, I can easily do it at my work in 5 minutes time.
  4. Nov 29, 2011 at 5:19 PM
    TexAggie
    TexAggie Well-Known Member
    Eric
    Amarillo, TX
    OME Lift
    Junk yard or try and fix it, no aftermarket parts for that
  5. Nov 29, 2011 at 5:25 PM
    Bfoster133
    Bfoster133 If i asked my dad for money, He'd knock me out
    Blake
    Thousand oaks, California
    2011 PreRunner TRD offroad
    15% Tint, 5100's at 1.75, Rear Diff Breather, CB radio, Black rattle canned rims, 265/75/16 Goodyear MTR, Magnaflow Offroad pro cat back, hi-lift bed mounted, shovel bed mounted
  6. Nov 29, 2011 at 5:43 PM
    brian
    Elizabeth City, NC
    lol fail. :p
  7. Nov 30, 2011 at 4:23 AM
    bigragu
    bigragu [OP] Member
    Tacoma trd
    It's the OEM system, and the little piece that came undone is real small probably less than half the size of the 510 circuit, which has already been fixed, could be a fuse but I think I have to start checking the junk yards for a new one.
    Thanks for the input
  8. Nov 30, 2011 at 8:49 AM
    brian
    Elizabeth City, NC
    Since its already broken, you're out nothing, mail it to me and I will try to fix it if you are not too far...
    take a pic if you can, i'm curious.
  9. Nov 30, 2011 at 8:52 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    I am too.
    Fink
  10. Dec 1, 2011 at 4:22 AM
    bigragu
    bigragu [OP] Member
    Tacoma trd
    I'll see what I can do my computer has problems when trying to send pics. I'm in Ma not sure if that's too far too make it worth it?
  11. Dec 1, 2011 at 2:05 PM
    bigragu
    bigragu [OP] Member
    Tacoma trd
    not sure if this will help, the circuit is to the right of the black box with gold writing
