Temp gauge always in red
Discussion in 'Technical Chat' started by Shaknbake, May 23, 2014.
  1. May 23, 2014 at 6:45 PM
    Shaknbake
    Shaknbake [OP] New Member
    Utah
    98 tacoma
    I just swapped over from a jeep. I have a 98 tacoma 4x4 sr5 that I've replaced both coolant temp switches and the gauge still is pegged in the red? When I unplug the back sensor the gauge goes dead. When it's plugged in it stays in the red? Any suggestions?
  2. May 23, 2014 at 6:50 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    First thing I would do is get a ScangaugeII and plug it into your OBDII port. It will tell you exactly what your temperature is.
    It is a known fact that the temp gauges on our Tacoma's are pretty dumb. If your gauge is truely in the red, than you definately have a problem. The gauges really don't move much from normal to overheated(red).
  3. May 23, 2014 at 6:59 PM
    Shaknbake
    Utah
    98 tacoma
    Yea the truck can be cold and first time it starts in the morning it goes red? I thought it might be a grounding issue cause the speedometer and odometer stopped also?
  4. May 23, 2014 at 7:03 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Cold engine first thing in the morning and it's in the red when you turn the key on before you start it?
    But ya, from the speedo and odo not working, there's an electrical problem in the dash.
    All we can do from here is suggest checking all fuses (in both fuse blocks, under the dash and under the hood), and scan under the dash for a hacked wiring job from the previous owner. Also look for evidence of water in some of the more obscure areas that might be hard to clean... truck could have been flooded.
  5. May 24, 2014 at 11:05 AM
    slo13zx3
    slo13zx3 Well-Known Member
    Brian
    forest city pa
    14 trd off 6speed nav
    sounds like u have a wire thats short to ground
