Temp gauge fluctuates frequently at higher rpms
Discussion in '1st Gen. Tacomas (1995-2004)' started by maximilian55, Mar 27, 2013.
  1. Mar 27, 2013 at 3:43 PM
    maximilian55
    maximilian55 [OP] Well-Known Member
    max
    washington
    04 Reg Cab 2.7l
    So i have a 04 tacoma 2.7L, shes got 267,000 miles, and nothing has ever been changed on it (besides oil, brakes, minor things). And recently i noticed that when my engine is at moderatly high rpms (not very high) the temp gauge will go all the way to the top (overheating side), and if i let off the gas and let it sit in neautral then it will slowly go back down to normal. Just driving at normal rpms it starts to rise on me.
    However i dont notice any difference while driving it, and i put my heater on full to see if it would help, and it barely made a difference if any. Also the air coming out of the vents was like luke warm.
    Any ideas what to do?
  2. Mar 27, 2013 at 3:50 PM
    bubba353z
    bubba353z Titles? We don't need no stinkin' titles.
    Columbus, Oh
    12 TRD Sport AC 4x4
    Is the radiator full?
    I'd check / replace the thermostat, and take a good look at the water pump and radiator to make sure everything is flowing properly.
  3. Mar 27, 2013 at 3:52 PM
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    If your coolant level is good, then it sounds like a bad thermostat that's not opening completely and letting it flow. I have no idea about whether or not that's a pain to swap on a 2.7, but that's where I'd start.
  4. Mar 27, 2013 at 10:48 PM
    maximilian55
    max
    washington
    04 Reg Cab 2.7l
    Checked the radiator and it was pretty much empty, im not sure how full it was supposed to be but i guessing thats my problem. Would it be necessary to do a full flush of my system? i looked online and it seems that mixing coolants can be a bad idea and im not 100 percent sure what or when was the last time the coolant was changed
  5. Mar 28, 2013 at 4:27 AM
    bubba353z
    Columbus, Oh
    12 TRD Sport AC 4x4
    A full flush / refill wouldn't be a bad plan - especially with 267k on the odometer.
    If you're in a hurry, a quick refill probably won't hurt anything for a few weeks - until you can get around to it.
  6. Mar 28, 2013 at 4:32 AM
    bubba353z
    Columbus, Oh
    12 TRD Sport AC 4x4
    The radiator should be full to the top, and then fill the recovery / overflow tank to the appropriate level (hot vs. cold mark).
    Check it after a day or two (engine cold), and top off as needed. If you are losing fluid over time, then you have either a leak or a head gasket issue.
  7. Mar 28, 2013 at 3:13 PM
    maximilian55
    max
    washington
    04 Reg Cab 2.7l
    Ok so im going to flush the system, but after looking online im still confused on where the drain plugs are. I found a little plug on the lower passenger side of the radiator, and im assuming thats it. But do i need to drain it from the engine also? or will I be ok to just drain it from the radiator
  8. Mar 28, 2013 at 3:26 PM
    bubba353z
    Columbus, Oh
    12 TRD Sport AC 4x4
    Yes, that's most likely the plug you want (considering I can't see it)......
    I'm not sure if there is a drain on the block, but maybe someone else will chime in. If there isn't then just fill the system with water and run it for a while until it gets hot enough to open the t-stat with the heater on. Then drain the radiator again and refill with antifreeze (it's OK to repeat again with water, if you want).
    I don't know how much fluid the block will hold, so you may need to do some research to figure out the blend needed to get to 50/50 once it mixes with the water in the block.
  9. Mar 28, 2013 at 4:08 PM
    TherealScuba
    TherealScuba Well-Known Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    Honestly sounds like the belt could be slipping and not providing enough spin on the water pump at higher RPMs.
  10. Mar 28, 2013 at 4:42 PM
    maximilian55
    max
    washington
    04 Reg Cab 2.7l
    i just flushed the radiator out, except when i ran water through it i didnt let hte engine run. is that a problem?
  11. Mar 28, 2013 at 4:46 PM
    bubba353z
    Columbus, Oh
    12 TRD Sport AC 4x4
    You won't get all of the old coolant out if you don't.
  12. Mar 28, 2013 at 10:15 PM
    maximilian55
    max
    washington
    04 Reg Cab 2.7l
    how much of a problem is that? do i need to flush it out again right away? or am i ok for awhile. i used the prestone coolant that says it mixes with all kinds
  13. Mar 29, 2013 at 4:07 AM
    bubba353z
    Columbus, Oh
    12 TRD Sport AC 4x4
    You're in better shape now than you we're before, but the old coolant will mix with the new and potentially reduce it's effectiveness. Not saying it will hurt anything though.
    Your call.
  14. Mar 29, 2013 at 7:59 AM
    maximilian55
    max
    washington
    04 Reg Cab 2.7l
    ok ill just flush it out again in awhile. thanks for your help man! i really apreciate it
  15. Mar 29, 2013 at 8:08 AM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    Sorry that I missed this thread. Looks like you are on track with what you need to do. If you pull the thermostat, then you will drain out most of the coolant. You will typically have no more than 1 quart of fluid left in the block. A small percentage of coolant mixing of the old with the new is not that much of an issue, so you can do a single drain and refill without any issues. Once you are done with this of course you will want to keep an eye on your coolant level in the radiator for several weeks. (Remember do not remove the radiator cap while hot!) Loss of coolant should be addressed at that point. Some parts places will sell a dye that can be added to your coolant to help locate a leak. The dye is harmless, and will REALLY help if you have a small leak. Good luck.
  16. Mar 29, 2013 at 7:03 PM
    maximilian55
    max
    washington
    04 Reg Cab 2.7l
    thanks man, i changed the coolant and it fixed the issue. im gonna let it run as is for awhile, and then later ill do a flush again but do it the right way. Time to start taking care of my baby more haha
