temp gauge issue
Discussion in 'Performance and Tuning' started by kfq269, Mar 10, 2012.
  1. Mar 10, 2012 at 1:27 PM
    kfq269
    kfq269 [OP] Member
    Andy
    New Jersey
    2004 toyota tacoma
    Ive had my 04 taco for five yrs and the problem im asking about is why does my temp gauge always show normal operating temp even after sitting overnight in the middle of winter? My fan constantly runs even during a cold winter start. Are these two issues connected? How do I make the repair myself? Thanks
  2. Mar 12, 2012 at 8:16 PM
    LGE RAW
    LGE RAW Well-Known Member
    Rob
    Dothan
    2020 TRD Off Road DCSB 6AT Magnetic Gray Metallic
    New Mods in the works.
    sounds like your sending unit may have failed. You can get it checked at the auto parts stores that have scanners, or you can use the torque app to read it if you have an android phone.
  3. Mar 12, 2012 at 8:42 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    And if the sending unit is bad, the Ultragauge won't tell him anything his "idiot needle" isn't already telling him.
    Obviously, if the fan (electric?) is kicking on and the gauge shows mid-scale when the engine is cold, there's a problem with one or more of the sensors.
  4. Mar 12, 2012 at 11:00 PM
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    If there is an open or short in the THW (ECT) sensor, or wiring, the system will have a default "failsafe" of 80 degrees celcius (normal operating temp). Your fans will always run to prevent overheating, and the temp gauge will always read normal. Find a scan tool that can read parameters, and see if the ECT says
    -40 or 120/140. Keep in mind these are metric measurements. Sorry, Canadian. The low end will be an open, whereas the high end will be a short. More then likely the sensor itself, but do not eliminate corrosion in connectors, or a broken wire. The open/short reading will help you there. If you would like to diagnose this yourself, pm me, and I will assist you. Must be at least a little mechanically inclined.
    -S
