Temp Guage going up and down 2006 toyota Tacoma 4.0
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kbsjdbe, Aug 10, 2021.
  1. Aug 10, 2021 at 4:09 PM
    Kbsjdbe
    Kbsjdbe [OP] New Member
    None
    My 2006 Tacoma 4.0 does fine until I turn the ac on and them after a while it it will overheat then drop and keep doing it. It was dumping Coolant out of the overflow tank. It's not head gasket we've had it checked. Trick has 240k. Thanks
  2. Aug 10, 2021 at 4:16 PM
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    For starters, how's the fan clutch - does it get harder to spin the fan when the truck is warmed up? If not, that may be the culprit. Also make sure the serpentine belt is in good condition and has good tension.
  3. Aug 10, 2021 at 4:19 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    How did you check the head gasket?
    Dm93 likes this.
  4. Aug 10, 2021 at 4:40 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Sticky thermostat or low coolant would be other suspect areas aside from a head gasket.
    TnShooter likes this.
  5. Aug 10, 2021 at 4:42 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'm thinking thermostat. You are going to have to check your fan clutch for sure though. If all that tests out fine go straight for the head gasket and check that.
  6. Aug 10, 2021 at 4:52 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I agree with the others.
    Other than that, I remember 1 person reporting a bad radiator cap causing coolant to over flow from the reservoir.
    Apparently it was weak and allowing the coolant in the overflow tank too soon.
    Not sure I believe that was the real source of the problem. I never seen the guy post back since. But hopefully for him, it was that simple.
    If you are sure it’s not the HG’s. I’d start with the thermostat.
