Temp guage increases with RPM's 96 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by RockNDetermed, Feb 11, 2010.
  1. Feb 11, 2010 at 6:18 PM
    RockNDetermed
    RockNDetermed [OP] New Member
    Doug
    Beaverton, Oregon
    95 Tacoma 4WD, 2.7L, 5Spd
    Flowmaster, KN Air Filter
    96 Tacoma 4x4, 3.4L ext cab Sr5
    Just gave my truck a tune up new plugs, wires, fuel filter, pcv, and cleaned my K and N cold air intake. I sprayed throttle bottle cleaner into the intake without the truck running, and now the truck bogs down, it's hard to start, and tonight it just died on me. When my RPM's increase my temperature guage will read hot and goes back down when RPM's decrease. It left me stranded today, will not start and a friend had to tow me home. Anyone have any ideas or heard of such a thing? I would greatly appreciate your input.
    Thanks
  2. Feb 11, 2010 at 8:47 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Just so we're clear ... Is the temp gauge consistently tracking with the tach in both directions (rpm's up / temp up; rpm's down / temp down)?
    Other than actual overheating, I can't think of anything non-electrical that would explain this.
    I'd suggest checking the tach and water temp sensor wiring / connections. Maybe you accidentally loosened / disconnected / shorted one of them and now you're getting some sort of cross-interaction between them at the cluster.
    I'm having an even harder time coming up with a single cause that would explain both the instrumentation weirdness and the bad engine behavior together. I'm guessing there are two different faults involved.
  3. Feb 12, 2010 at 3:12 PM
    Moteef
    Moteef New Member
    This is Moteef! Maybe you should check out dem black ass ground wires that you took off when your lazy white ass replaced dem plugs. If dat don't fix it, grab some watermelon and some Olde E.
  4. Feb 12, 2010 at 8:08 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Did you get OEM wires? ive heard bad things about aftermarket wires.
  5. Feb 13, 2010 at 1:20 PM
    RockNDetermed
    Doug
    Beaverton, Oregon
    It's fixed. Ground off the water temp sensor wiring / connections was loose.
  6. Feb 13, 2010 at 1:51 PM
    Moteef
    Moteef New Member
    I pitty da foo that forgets to hook back up dem ground wires after doing a tune up.
    "Never stick your entire hand in a jar full of jelly beans, The black ones will steal your watch" HeHaa.
    -This is Moteef
  7. Feb 13, 2010 at 5:49 PM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    Glad it turned out to be a straightforward electrical fix ... :thumbsup:
