Temp. Lift Solution
Discussion in 'Suspension' started by dud122, Feb 13, 2009.
Worth it or not...
  1. Yes
    10 vote(s)
    31.3%
  2. No
    22 vote(s)
    68.8%
  1. Feb 13, 2009 at 6:20 AM
    dud122
    dud122 [OP] rabble rabble rabble
    Dan
    Riverdale Park, MD
    2002 Tacoma DC
    OME up front, Dakar in the back, Elite front bumper, Warn winch, Tactical rear bumper with tire swing/jerry cans/hi lift, Revenge Fab. sliders, Tundra brakes, Camburg UCA's, Safari Snorkle, FJ TRD wheels, Truxedo, Bed Rug, Lights, CB, Switches, skids, LED's... OH MY!
    i know a lot of people don't like the spacer lifts but this would only be temporary so i can fit the tires i want now and save up for the ome coilover lift later. i can get this NIB for 130 + shipping...
    PART # TAC 04 3AD
    1995.5 - 2004 TACOMA 4X4 V6 OR 4 CYLINDER
    STANDARD CAB, EXTRA CAB, OR DOUBLE CAB.
    COMPLETE 3 INCH LIFT KIT
    WITH FRONT DIFFERENTIAL DROP KIT
    AND PRO COMP ADD-A-LEAFS
    NO SPRING COMPRESSOR OR SPECIAL TOOLS REQUIRED
    This kit comes complete with the following
    A. ( 2 ) 3 inch front lift strut spacers and all required hardware.
    B. ( 2 ) PRO COMP add-a-leafs and new centering pins/ bolts.
    C. ( 2 ) 1" Front differential drop spacers and required hardware.
    D. ( 1 ) Rear brake proportioning valve extension bracket.
    Complete step by step installation instruction with pictures.
    And our Tech Support Ph # is posted on the home page if you have a question.
    The complete kit only takes about 3 1/2 hrs. to install.
    In most cases your stock rear shocks will work, But for the best ride
    and handling on and off road longer rear shocks are recommended.
    As with any lift a front end alignment is required after installation.
    3" LIFT
    KIT $169.99
    S/H $ 20.00
    TOTAL $189.99
    California residents
    Subject to 7.75% TX
    Please read shipping
    policy below
    worth it???
  2. Feb 13, 2009 at 6:40 AM
    dud122
    Dan
    Riverdale Park, MD
    2002 Tacoma DC
    perhaps a poll will generate more interest...
  3. Feb 13, 2009 at 6:59 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Why waste your money on a temporary lift.
    Save up the $$ and get what you want the first time and you won't have to do it over again later.
  4. Feb 13, 2009 at 7:10 AM
    dud122
    Dan
    Riverdale Park, MD
    2002 Tacoma DC
    it seems like most people have been paying upwards of 7-800 for everything for their 3" lift...
    i was thinking with this i could at least have the look of the 3" lift for now if not the functionality and maybe allow me to get parts for the good lift a little at a time....
    if i have this on then i can save up for new/longer shocks and put them on with this lift... then save for the coilovers.... save for tires....etc. does this make sense?
    maybe do a bit of the good lift at a time.
  5. Feb 13, 2009 at 7:57 AM
    Janster
    Jandy
    Lancaster, PA
    You don't have wheels & tires yet?
    You gotta wait until you have bigger wheels & tires. That 3" lift will look funny with stock sized tires.
  6. Feb 13, 2009 at 8:02 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    That lift you have posted will destroy your ball joints in very little time. If your lucky. If your unlucky, it will F up much more than that.
  7. Feb 13, 2009 at 8:10 AM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    Just dont do any offroading with the spacer lift.
  8. Feb 13, 2009 at 8:11 AM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    x2
  9. Feb 13, 2009 at 8:18 AM
    06Bluez
    Phoenix, Arizona
    06 4x4
  10. Feb 13, 2009 at 9:42 AM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    :confused:whats wrong with a sapacer lift?
    and why shouldnt u do off roading?
  11. Feb 13, 2009 at 10:59 AM
    Janster
    Jandy
    Lancaster, PA
    There are two different types of spacer lifts.
    1) Spacer that is mounted INSIDE the coil assembly
    2) Spacer that is mounted ONTOP (outside of) the coil assembly
    The lift kit you posted is a #2 which mounts ontop and outside the coil assembly. Those types of spacer lifts are probably the worst front lift kit you can buy for a variety of reasons which are somewhat hard to explain but the folks have already touched on the details slightly.
    If you're gonna go with a spacer lift - you're much better off getting one that goes inside the coil assembly and requires you to compress the coils to install it.
  12. Feb 13, 2009 at 11:03 AM
    tarheelfan_08
    tarheelfan_08 Carolina Alliance
    Justin
    North Carolina
    2010 White 4x4 Double Cab Tacoma Short Bed
    Chrome Grill, Chrome accessories(door handles and mirror covers), LEER Super White Cover, Mirrors with Turn Signals, Window Vent Visors, Step Rails, WeatherTech Digital Floor Mats, Mini Maglight Holder, Chrome Bull Bar
    Dont settle for less..only settle for the best and if you cant afford the best then wait until you can!! It will be worth it in the end...trust me!!
  13. Feb 13, 2009 at 2:29 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Dont do what I did! I got a spacer lift figuring I would save $. But It just wore my shocks/springs out. My ride sucks now, stiff as hell! and now Im spending even more on C/O's and new UCA's. which is what I should of saved up for in the first place!
  14. Feb 13, 2009 at 7:37 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    so is it like weaker
    weaker as in the mounting bolts break off if u hit somthing hard enough?
    thats the only thing i can think of
  15. Feb 13, 2009 at 7:52 PM
    Janster
    Jandy
    Lancaster, PA
    Nope...not really.
    It has to do with overall suspension downtravel & upper/lower A- arms.
    If you never offroad - I'm sure you'll be fine.
    When the coil is ontop (outside the coil assembly) -the entire suspension is lowered and the down travel is increased which causes both the upper & lower A-arms to operate at extreme angles causing extreme wear on the balljoints & gawd knows what else.
    When the spacer is inside the coil assembly - the suspension travel is basically the same as stock and keeps the upper/lower A-arms in their stock locations (relatively) = less wear on ball joints.
  16. Feb 13, 2009 at 7:58 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    wouldnt the upper and lower a arms be in the same position with the inside coil spacer as with the outside strut spacer?
  17. Feb 13, 2009 at 8:04 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    I ran one for a while, I wouldnt get a 3 inch, 2 inch and you should be good, I had mine on for like a year and had no problems, ride was a little on the soft side, but it fit the tires I wanted, if you abouse your truck off road, then yeah its gonna break something but if its for the street you should be good. oh and once i got my coilovers I sold the stock assemblies w/spacers and got my money back :)
  18. Feb 13, 2009 at 9:54 PM
    Janster
    Jandy
    Lancaster, PA
    At rest.....Essentially Yes. If you never take the truck offroad - you'd probably be fine.
    If you take it offroad and allow the suspension to droop - that's where the problems can begin. Over-extending the ball joints....
  19. Feb 13, 2009 at 9:57 PM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    ooooooooohhhhhhhhh
    i still dont understand :confused:
    sorry
    i kno what ur saying but i dont see how its really any diffrent
  20. Feb 14, 2009 at 6:57 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Actually, the A arms wont be in the same position. The Top spacer posted will lengthen the strut assembly, so the A arms wont be in their respective positions. As the strut is now longer than it was, the suspension will now have the ability to "Over extend", which is now going to enter in the chance of the front shocks breaking (just ask 06Bluez), and destroying your ball joints, as they are now the limiting factor in how long the suspension can travle downward.
