Temperature display by sunglass holder
Discussion in '2nd Gen. Tacomas (2005-2015)' started by shakao, Sep 2, 2009.
  1. Sep 2, 2009 at 7:08 PM
    shakao
    shakao [OP] Member
    MN
    Speedway blue
    Mine doesnt work. Is this a fuse problem? Bulb? Its been out for about 4 months now. Just never had time to fix it.
  2. Sep 2, 2009 at 7:14 PM
    Tool
    Tool Who Inspires You?
    Riverside, CA
    07 PreRunner TRD Sport
    6in ProComp Lift, DTLT Headers, JBA Exhaust, AVIC-D3 with Bluetooth, Coverking seat covers, 2 10in Rockford Fosgate subs, Rockford Fosgate Amp, N-fabs, 6000k HID LED Taillights
  3. Sep 2, 2009 at 7:18 PM
    shakao
    shakao [OP] Member
    MN
    Speedway blue
    Nicceeeeeeee.
    Gee, you Tacoma guys are fast on here. hahaha
  4. Sep 2, 2009 at 7:20 PM
    Tool
    Riverside, CA
    Your welcome =)
    i had the same problom like 3 months ago
  5. Sep 2, 2009 at 7:41 PM
    geobay
    geobay New Member
    canada
    06 TRD double cab
    Fixed mine today
    Thanks sooooooooooo much , tool
    better than the 1200 the dealer quoted here in canada
  6. Sep 2, 2009 at 8:25 PM
    Tool
    Riverside, CA
    dang 1200??? thats crazy
  7. Sep 2, 2009 at 8:33 PM
    ilovetacos
    ilovetacos Well-Known Member
    Gavin
    Sacramento/Woodland
    2006 TRD Sport 4x4 DC
    Sold!
    Yes we're fast and helpful...I had a customer come into my office the other day and I noticed he was driving a Tacoma. We started chatting and he told me his temp gauge stopped working. I grabbed a screwdriver out of my breakroom and went out to his truck and showed him how to fix it. He came back by later that day with a solder gun and I did it for him right in my office. He tried to give me $40 for helping him but I didn't take it. It felt good to help out a another Tacoma owner out.
  8. Sep 2, 2009 at 10:15 PM
    Silver06Taco
    Silver06Taco Well-Known Member
    WA state
    Silver 06 DC TRD Sport
    Fixed mine recently too.
    I was searching around ebay the other day and noticed someone auctioning off repair work for the temp gauge. He was charging $85
  9. Dec 14, 2009 at 7:11 AM
    sdv55ce
    sdv55ce New Member
    Knoxville, TN
    06 PreRunner SR5
    It takes about 20 minutes, a soldering gun and some .032 solder.
    1. Take out the screw where the sunglasses are stored.
    2. Pop the from end out, a little tricky - leverage your knuckles against the overhead. The back is hooked on so it swings down from the front.
    3. Take off the 2 connections, use you r finger nail to push down the clip that holds them in.
    4. Lay it out on a surface that won't scratch the finished surface and take out three tox screws on the back.
    5. Take of the displat cover - four snap in points - 2 on each side. You can use your finger nails to put back and coax each side out.
    6. Take a close look at the 510 resistors for cracking. Just solder them back and put it back in. Take a look at the 181 resistor also - mine were okay.
    I followed the directions I got here, but can't find them again.
  10. Aug 10, 2010 at 6:27 PM
    pitriz222
    pitriz222 New Member
    Colorado
    2005 Tacoma
    Good find, easy fix, THANKS..!!!!!!! found one resistor hanging loose resoldered both works great.
  11. Aug 10, 2010 at 6:43 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    There was a guy on another Toyota forum trying to charge $200...said it would take a week to get get back after you send it to him. I asked what exactly he does for $200 concidering it takes about 5 minutes of soldering to fix the problem. He hasn't posted since...:rolleyes:
