Temperature gage goes to HOT
Discussion in '4 Cylinder' started by 4696 Lady, Jul 28, 2011.
  1. Jul 28, 2011 at 2:16 PM
    4696 Lady
    4696 Lady [OP] New Member
    96 Tacoma
    Temperature gage goes up to HOT when I turn on the AC but when I turn off the AC, the temp goes back down. I drained and flushed the radiator and I replaced the thermostat but when I turned on the engine again and it warmed up and the AC was turned back on, the temp went back up to HOT. Whats next? I noticed the sound of boiling water in the upper hose but the radiator cap and the radiator water were not hot; I stuck my finger in it.
  2. Jul 28, 2011 at 2:18 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    hmm weird... never heard of it, hopefully someone can help you out.
    welcome to tw by the way!:)
  3. Jul 28, 2011 at 2:32 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Are you sure your engine is cycling coolant through the radiator? That boiling noise and a cool radiator is good sign something's not working as it should.
  4. Jul 28, 2011 at 2:35 PM
    97yota4wd
    Eric
    Mesa, AZ
    take off the radiator cap when its cold. start it, watch the coolant and the gage. if the gage gets hot and theres no movement in the coolant its not cycling
  5. Jul 28, 2011 at 2:37 PM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    Water pump?
  6. Jul 28, 2011 at 2:39 PM
    motorsport36
    motorsport36 Black Lights Matter
    Furnace, AZ
    98 SR5 AC 4x4
    I hate it when my gage goes hot
  7. Jul 28, 2011 at 2:41 PM
    4696 Lady
    96 Tacoma
    Thanks, I am going out right now and doing as you suggest; I'll let you know what happens...
  8. Jul 28, 2011 at 3:07 PM
    4696 Lady
    96 Tacoma
    I took off the cap and watched the water/coolant; it does not move but it does get hot. Also the upper hose gets so hot you can't touch it. What do you think? Water pump or radiator or fan clutch?
  9. Jul 28, 2011 at 3:19 PM
    scocar
    scocar hypotenoper
    When the engine is running and you turn on the AC, do the RPMs inscrease by 100 or so when the compressor kicks on? If not, could be a sensor or switch or relay that is faulty and not revving up the engine for additional cooling when the compressor is running.
    I don't think this alone would cause your temp to max out, but it could be a factor in your problem here.
  10. Jul 28, 2011 at 3:35 PM
    4696 Lady
    96 Tacoma
    Scott, is that what the temp sensor does? I'm trying to find out all of this so I will be more educated about what the real problem and costs are when I take it in to a mechanic. The small things I can do myself but when we get into motors and such, I'll have to hand it over.
