Temperature gauge doesn't work anymore
Discussion in '1st Gen. Tacomas (1995-2004)' started by trouttacoma, Oct 12, 2014.
  1. Oct 12, 2014 at 12:50 PM
    trouttacoma
    trouttacoma [OP] New Member
    Tahoe
    2002 4-cylinder access cab Tacoma 4x4
    I have a 2002 Tacoma 4cyllinder, few months ago the temperature gauge started to flicker on and off. After the about a half hour of driving the tempature gauge would read at a normal operating level, now it doesn't work at all. I haven't replaced the thermostat, but it seems like my engine is working normally but I am not for sure.
    Has anyone had a similar issue and if so any suggestions on next step?
  2. Oct 12, 2014 at 1:55 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    just replace the temperature sensor, its probably bad if the reading was fluctuating
  3. Oct 12, 2014 at 6:23 PM
    Rozz
    Rozz Well-Known Member
    Sturgis, SD
    '15 TRD Sport
    Stuff
    Find the temperature sender for the gauge, and unplug the wire. Now, ground the wire to the engine (key on). If your gauge goes all the way to the hot side, then your gauge is good, and your sender needs replacement. If the gauge doesn't move, then your gauge has crapped out.
  4. Oct 12, 2014 at 6:25 PM
    geodude
    geodude Well-Known Member
    Ive also got a an '02 4cylinder (no tachometer) and my temperature gauge hasn't worked in a few years. Could be first start of the morning in -10deg winter or its been running highway all day; the needle shoots right to the center of the gauge and sits there as soon as I start the truck.
    I looked into fixing it a while back and found that there are separate temp relays. One that feeds to the computer = important, and one that feeds to the dash = not important.
    The trucks operation isn't effected at all with that sensor out so don't worry. I looked into a replacement relay and they're around $80 so it wasn't worth the fix to me.
  5. Oct 13, 2014 at 10:36 AM
    a.smo
    a.smo Well-Known Member
    Aaron
    PHX, Az
    '99 Trd Xtra Cab 4x4 5sp
    Good info. Thanks!
  6. Oct 17, 2014 at 3:18 PM
    trouttacoma
    Tahoe
    thanks that was all super helpful. It appears that it is my actual temp gauge that is broken. any tips on how best to replace the gauge or any good websites on where to buy a new instrument cluster?
  7. Oct 18, 2014 at 10:16 AM
    a.smo
    Aaron
    PHX, Az
    If my temp gauge ends up being broke I'm prolly just going to get an aftermarket gauge.
  8. Oct 18, 2014 at 2:37 PM
    keakar
    karl
    louisiana
    just get the whole gage cluster, there are a few people on here selling theirs and they can be found on ebay as well.
    unplug your dash cluster gages and plug in the new ones and your done, no need to try and fix the gage
