Temperature Gauge/ Fuel Gauge not working.
Discussion in '1st Gen. Tacomas (1995-2004)' started by 97Blk_one, Feb 15, 2016.
  1. Feb 15, 2016 at 6:07 PM
    97Blk_one
    97Blk_one [OP] Well-Known Member
    Memfrica
    not so low
    A whole lot,But not satify
    Was zip, folks!
    Sorry if someone already posted this. I can't find it.
    I got some issue with my temperature gauge and fuel gauge, both not working because my 10 Fuse keeping on blowing. I changed the fuse, working fine. BUT when I put in drive or reverse the fuse blown again.
    Anyone ever run into these issues? Much appreciated for your input.
  2. Feb 15, 2016 at 9:09 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    This dosent help ya much, but its gotta be a short causing that issue. Rubbed through or exposed wire er something like that, rodent damage possibly....
    97Blk_one[OP] likes this.
  3. Feb 15, 2016 at 9:30 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    To move the shifter out of park you gotta depress the brake pedal right? Could that action be what is blowing the fuse. If so, the pedal mechanism is right behind the dash panel area. Check for wires that are moving when you depress the brake pedal. I agree with @bry838 , a bare wire being grounded to cause a short.
  4. Feb 15, 2016 at 10:13 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    id think a short somewhere near the neutral safety switch if not inside the dash behind the gauges. are the shift indicators lighting up, or are they supposed to but not?
  5. Feb 16, 2016 at 4:52 AM
    97Blk_one
    Memfrica
    not so low
    Thanks guys !
    After tracing what you guys have suggested , I found what the issue was. Awhile back (years) I've installed a bar light under the tailgate. Some how the wires got pinned against the tailgate and exposed bare wire to the metal. I taped the wires, and vióla the issue was solved. Thanks again for your input guys !
    Digiratus likes this.
