Temperature gauge issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gclif, Sep 17, 2023.
  1. Sep 17, 2023 at 1:04 PM
    Gclif
    Gclif [OP] New Member
    2012 gray Tacoma off road
    Hello everyone, I have a 2012 Tacoma 4.0 off road. Been a fantastic truck, yesterday when I would drive the truck and get it up to operating temp and stop and put it in park or neutral the temp gauge would drop straight to cold and engine would idle high as if the truck was just started first thing in the morning (I live in NC it’s definitely not cold outside right now). I put a new thermostat along with a coolent temp sensor with no change. Can’t find anything on this matter, if anyone has any input it would be appreciated!
  2. Sep 17, 2023 at 1:15 PM
    Bishop84
    Bishop84 Well-Known Member
    I’ve seen this with thermostats but clearly you changed it.
    is the cooling fan loud? The clutch make be sticking.
    tcjacado likes this.
  3. Sep 17, 2023 at 1:21 PM
    Gclif
    To me it sounds normal, I may have to do some more investigating on the fan. What is strange is when I put it in park/neutral and then gauge goes to cold as soon as I put it drive it rises slowly back to operating temp.
  4. Sep 17, 2023 at 1:46 PM
    Gclif
    Bishop84 what’s the best way to test out the fan to see if that is a possible candidate to the problem.
  5. Sep 17, 2023 at 1:52 PM
    Bishop84
    Used to go the kamikaze route, hold it when starting and see if you can hold it. If you can, its good.
    The proper way is to know what its supposed to feel like at a stop, vs bad at a stop. It's a trained thing. But it should spin freely when cold.
  6. Sep 18, 2023 at 8:02 AM
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    Gotta say, this sounds electrical to me. Your sense regarding the coolant temp sensor was, I think, a good place to start. I saw a diagnostic done on South Main Auto where a bad temperature indication to the ECM caused a very rich condition.
    What I can’t figure out is how the gear selection could have anything to do with that temperature reading. It would be interesting to look at a couple of wiring diagrams to see if there is any connector where the transmission wires and the coolant temp sensor both go through. Seems unlikely, but would be good to know, as that would be the first place I would look.
  7. Sep 18, 2023 at 8:06 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    The cluster has those wires (if it’s an automatic).
  8. Sep 18, 2023 at 9:00 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The problem is you are low on coolant. When the engine is running and loaded the coolant is circulating and wetting the temperature sensor giving a reading. When you place it in park or neutral the coolant flow is decreased and the temperature probe is not in the liquid causing a cold reading as it is a wet bulb probe and needs to be in the liquid to read the temperature.
    Top off the coolant.
    winkel and tcjacado like this.
  9. Sep 18, 2023 at 7:55 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I'd suspect a wiring issue, is the CEL on? If so what code(s) is it setting?
  10. Sep 19, 2023 at 6:20 PM
    Gclif
    Dm93 it is showing code P0125
  11. Sep 19, 2023 at 8:33 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Can you scan tool show coolant temp?
    If so see if it's within about 10 degrees of ambient temp when the truck has been sitting overnight.
    Jimmyh likes this.
