temperture hand
Discussion in '1st Gen. Tacomas (1995-2004)' started by kevinl34, Apr 13, 2013.
  1. Apr 13, 2013 at 8:20 PM
    kevinl34
    kevinl34 [OP] Well-Known Member
    duncan s.c.
    toyota tacoma dbl cab sr5
    Hello just finished installing a radiator fan clucth water pump and t-stat i ran the truck till it was up to temperture but it seems the temp is running a little high. Based on the picture is this about normal for the prerunners? I used all oem parts also thanks
  2. Apr 13, 2013 at 8:22 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Seems good to me. Mine runs about there around town, but a little lower on the interstate.
  3. Apr 13, 2013 at 8:25 PM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    Looks a little high to me (mine runs horizontally about perfect) but I wouldnt worry too much tho
  4. Apr 13, 2013 at 8:32 PM
    smuook
    smuook Daily Driver "Plus"
    Smuook
    Loganville, GA
    2004 DC V6 PreRunner
    Billy 5100, Satoshi, MBW Wheels, All Pro Front Bumper with 3x PIAA 530, LED dash lighting, other stuff too much to list
    You might be a little higher than mine. Just changed to lower thermostat... With stock 180f:
    With new 170f:
  5. Apr 13, 2013 at 8:49 PM
    Sittingbull2
    Sittingbull2 Old N.R.A. Hippy
    Mitch
    Southeast texas
    2000 Xtra Cab SR5 White
    3" Body lift, ARB Front Bumper w/9000 lb. Warn Winch, Chevy Alum. Rims w/ Kelly 285's M/S
    Did you get all the air out of the system (purge it) ? That also could raise the temp some until the air bubbles are out.
  6. Apr 13, 2013 at 8:50 PM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    Seems a little high, but as long as it is stable and not going any higher it should be good. Mine runs about perfectly horizontal.
  7. Apr 13, 2013 at 9:20 PM
    kevinl34
    duncan s.c.
    Yea my brother has one and his runs right in the middle and he brought mine to the intention that it seem to be running a little high. The truck seems to run fine and like i said i changed just about all of the cooling system parts other than the coolant temperture sensor. Im sure that the system was burped.... What else could i look at like i said its not running in the red but not to far from it...
  8. Apr 15, 2013 at 9:40 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    4 or 6 cyl?
    If it is the V6, how about the t-stat, was it installed with the jiggle valve "down", in the 6 o'clock position?
    Many folks will swear the valve should be in the "up" or 12 o'clock position. "It helps to purge air bubbles" they say. Google "jiggle valve", most returns including Wikki say "up".
    The Toyota FSM specifically says down for the V6 and up for the 4 cyl. The FSM seems to defy conventional wisdom or is just flat wrong (it frequently is) but apparently this is not the case.
    There is some pretty substantial evidence with the V6, putting the jiggle valve "up" consistently causes around a 10* increase in coolant temp. Haven't seen anything with regards to the 4 cyl. You may or may not see it on the dash gauge. They are not real sensitive.
    This thread is one of the better ones on the subject http://www.yotatech.com/f2/5vz-fe-running-warm-after-timing-belt-pictures-pleasure-249481/
    Just something to think about/check.
  9. Apr 15, 2013 at 6:01 PM
    423 TACO
    423 TACO Well-Known Member
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    i have the v6 mine runs about there. little above horizontal but i've never worried about it since its stable and has never climbed higher
  10. Apr 15, 2013 at 7:16 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Mine runs in the middle. Factory stat.
  11. Apr 15, 2013 at 7:41 PM
    kevinl34
    duncan s.c.
    I think its fine being I dont remember which way the jiggle was placed . It doesn't climb any higher than in the picture so im thinking it ok. However I might take it somewere to make for sure the temp is ok.....One more question when I installed the radiator the hose going to the vgr box thinge came loose and now my check light is throwing code p0402 Im beleving it might need a cleaning but is there a diy on how to remove it? and what should I soak it in?
  12. Apr 15, 2013 at 7:45 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    remember, the guages are not calibrated. it gives you a decent reference. as long as it's not overheating, you are OK.
