Temporarily lifting rear but not front ok?
Discussion in 'Suspension' started by PilotBoy352, Mar 17, 2023.
  1. Mar 17, 2023 at 2:52 PM
    PilotBoy352
    PilotBoy352 [OP] Well-Known Member
    Tim
    Mesa, AZ
    2015 MGM DCSB (rip) now 2018 white DCSB TRDOR 6MT
    I have a set of Icon 2.5 Coilovers and an Icon Add a Leaf. I am planning on installing everything tomorrow, but i may run out of time and not get to the front. Is it ok if I temporarily lift the rear with the add a leaf before I install the front coilovers?
    Thanks in advance.
    Ps. I am running Bilstein 5100s all around rn, and I am going to use the rear shocks with the add a leaf.
  2. Mar 17, 2023 at 2:57 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    Sure, won't hurt anything. You'll just have to put up with the super raked look until you get to the front.
    PilotBoy352[OP] likes this.
  3. Mar 17, 2023 at 4:28 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Sure thing. You will be fine. Shouldn’t mess up your alignment up either.
  4. Mar 17, 2023 at 4:37 PM
    PilotBoy352
    Tim
    Mesa, AZ
    Thanks for the advice. I've got the bilsteins set to level the truck, so the rear should only be 1.5" higher than the front in theory. Hopefully it wont look to weird.
    Fluffymonkey[QUOTED] likes this.
  5. Mar 17, 2023 at 4:38 PM
    PilotBoy352
    Tim
    Mesa, AZ
    I am gonna take it in for an alignment when I finish lifting it. Is there any way that the rear could be messed up at all?
  6. Mar 17, 2023 at 4:58 PM
    Jojee117
    Jojee117 Well-Known Member
    Joe
    MT
    06 TRD Sport Prerunner 4WD swapped
    Not unless you really manage to mess something up with the leafs. I would recommend running the truck around a couple hundred miles to get everything settled before getting it aligned if you can. I did that and didn't have any problems, but my buddy got his aligned immediately and he ended up with bad tire wear after his setup settled out of alignment.
  7. Mar 17, 2023 at 5:46 PM
    PilotBoy352
    Tim
    Mesa, AZ
    Hmm, I haven't heard that, but I will take it into account. Would you say going wheeling is ok before I get it aligned, or should I wait until after everything settles?
  8. Mar 17, 2023 at 6:09 PM
    Jojee117
    Joe
    MT
    If anything, it'll probably help it settle faster. I honestly can't say whether or not it'll be okay, but typically the main issues with a bad alignment are bad tire wear and handling.
  9. Mar 17, 2023 at 6:12 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I did my rears one weekend, the fronts the following weekend.
    It isn't as bad as you think it'll be.
    SuperAir, sbx22 and PilotBoy352[OP] like this.
  10. Mar 18, 2023 at 2:19 AM
    SuperAir
    SuperAir Well-Known Member
    Maine
    19 TRD ORAC Cement
    Eibach Stage 1, 17x8.5 Ray 10s, 265/70-17
    Absolutely this. If you take it down the road and it "feels ok" then run it a bit to get everything settled before alignment. Mine drove fine after and I ended up with almost 500 miles on it on brand new tires before I had it aligned. No issues.
  11. Mar 18, 2023 at 7:57 AM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    You'll be fine. I remember when I had a old s10 that I lowered, I did the front and didn't have enough time to do that back in the same day and drove to work the next day lowered 3 inches in the front and stock in the back and it was fine
