Temporary bedliner removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pdk9, Apr 22, 2012.
  1. Apr 22, 2012 at 7:21 AM
    pdk9
    pdk9 [OP] Active Member
    Southern, New Hampshire
    I am trying to install a used TracRac onto my 2012 DC Longbed. The TracRac requires a rail to be installed onto the top of the bed rail so I need to temporarily remove the sides of the bed liner to access underneath the top rails. Any links to on this removal?
  2. Apr 22, 2012 at 7:30 AM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    You can find the Factory Service Manual here. Also... it's not a bed liner, it's the bed and one piece, and check with XXXX for his install. It doesn't look like he removed anything. Remember the search feature is you friend. Good luck.
    Frank
  3. Apr 22, 2012 at 11:03 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    +1
    Bed is attached to the frame, and the fenders/bedsides are attached to the bed.
    You can not remove the bed.
    You CAN remove the pockets above the wheel wells, and the storage boxes at the rear, and from there you should be able to reach the bottom of the rails.
  4. Apr 22, 2012 at 12:31 PM
    pdk9
    I believe the install that XXXX did used the Tacoma brackets to connect to the bed rails. I want to be able to use a tonneua cover as well as the TracRac so I need to go through the top of the bed rail like a normal pickup bed. I will try going through the boxes but I need access to the all corners of the rails for the mounting bolts.
  5. Apr 22, 2012 at 1:33 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    You don't have any other options due to the way the Tacoma bed is made.
    The fenders literally hang from the plastic bed. You can remove the fenders, but other than that, the only path is through the places I mentioned above, or from under the truck (you can reach all the way to the rails from under the truck, but it'll turn your installation into a 2-person job).
  6. Apr 25, 2012 at 6:49 PM
    pdk9
    I guess I need to find out if the rails are structurally sound enough to screw through them. The TracRac that I have is the one that requires a rail to be installed onto the top of the bed rails and then the rac system slides on these rails vs. the clamp on type that XXXX used. Thanks for the advise.
