Temporary fixes for DB lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by WyoExplorer, Oct 1, 2024.
  1. Oct 1, 2024 at 3:23 PM
    02hilux
    Planet: EARTH
    :rofl:
  2. Oct 1, 2024 at 3:40 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    OP, if you can’t see that your ride sucks because you have no up travel and are riding on your bump stops, you might not be in a good position to safely and knowledgeably SAS this truck.
    You need to lift the front to get off those bump stops. Or remove the lift and put it back to stock.
  3. Oct 1, 2024 at 3:53 PM
    02hilux
    Planet: EARTH
    that’s why maybe 5 people out of 100 people will go through SA and the other 95 is all talk :rofl:
    the funny thing is, this $1400 topnotchlift Billy’s coilovers includes a ~1.5” hat. OP pictures has no preload, hence riding on the bump stop causing a shitty ride quality.
    Diablo169[QUOTED] and Bucky13 like this.
  4. Oct 1, 2024 at 8:30 PM
    WyoExplorer
    WyoExplorer [OP] Member
    Kaiden
    Black 2003 Tacoma TRD
    6” FabTech Lift
    @Dare Devil Diablo Thank you for the input, I just adjusted them to where they need to be. Truck squats slightly, but have OME leaf pack on the way (Don't want to look like I'm from SC). @02hilux I'm still learning how to work on my own truck, but at least I’m trying to get things done the right way (As much as I can right now). And @Diablo169 with "home wrecking" as your job title, maybe you should focus more on fixing your own life, then maybe you won't have to project so hard that your significant others leave you for someone else before trying to give advice about anything else. Take care BRO:duh:.
  5. Oct 1, 2024 at 8:38 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    It looks like you need to crank the preload way up to get the ride height in the front correct. The UCA should be angled down at ride height.
    Also, it looks like your front brake lines are original length or at least not long enough for the correct extended travel and lowered position of the caliper with the drop bracket. You probably want to replace those asap before you lose all braking when one rips apart.
    Lastly, once you fix the front ride height and after you get on your new OME leaf pack, you can measure how big of a block you’ll need to lift the rear so you’re not a Carolina Squatter.
    YotaOverAll, treyus30 and LOLLY like this.
  6. Oct 1, 2024 at 8:39 PM
    JasonLee
    15 TRD OffRoad
    Can you post photos and measurements of the distance between the front and rear rubber bump stops mounted to the LCA and where they strike on the drop bracket crossmember? This will confirm my above assessment that the front needs to go way up. Until you do that, your ride will continue to be bad.
    LOLLY likes this.
  7. Oct 2, 2024 at 4:51 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    https://topnotchlifts.com/collections/tacoma/products/96-04-tacoma-6-8-adjustable-coilover-set
    I'm sitting here wondering if that bump stop bracket is welded in right. Looking at it, if it were not there, I'd guess you'd have 2-3" of travel before some kind of bind. Your springs also barely look any more compressed than they do in this product page.
    The quick solution would be to add as much preload as you can via the collar, provided your brake lines and such allow it, which should move your LCA lower relative to the bump stop
    MalinoisDad likes this.
  8. Oct 2, 2024 at 2:33 PM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    Disconnect the sway bar, check your tire pressures, say your prayers, and maybe even toss the bump stops to gain ~ 2" of up travel before you smack bare steel. If you disconnect the sway bar it might help when one side articulates by itself but it'll make for looser cornering on that 6" lift.
  9. Oct 3, 2024 at 1:05 AM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    Stock
    With all due respect, I feel my points were valid.
    And, to be fair, Home Wrecker would insinuate I do not have a significant other that could potentially leave me.
    End of the day. I’m always down for Won Tons and 4D’s :bananadance:
    And, I know a thing or two, cause I’ve seen a thing or two.
    The box on Winch Hill 3.
  10. Oct 3, 2024 at 6:12 AM
    v5ensx
    v5ensx CARB legal is not CALI legal
    Can you explain this? Regear the case to maintain the pinion drop…. :confused:
