Temporary front end protection film for road trips
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lenoxluda, May 2, 2019.
  1. May 3, 2019 at 4:21 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    A can of spray Pam will keep those bugs from sticking, also baby oil applied with a sponge will work also.
    If it rains you may need to reapply.
    hoarder23 likes this.
  2. May 3, 2019 at 4:40 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  3. May 3, 2019 at 8:28 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Just carry waterless wash and microfiber towels with you.
    I highly advise against taping over your headlights for obvious reasons.
    I’m a detailer and I handwash my vehicles. I dont run through autowashes ever because of the paint damage they cause.
    On road trips I’m not bringing my arsenal of detailing crap with me. You either need to blow the coin on a professional ceramic coating or make sure to wash and apply a quality sealant on the truck prior to your trip. Then just let the bugs sit till you get home. The sealer protects the paint for about a week or two.
    Sticking crap to the paint job will just worsen paint damage because that will just rub the whole trip.
    Its like those leather bras. People put them on to protect the paint but the dirt and grime that gets under them will wear right through a paint job and cause clear coat failures and rusting.
    lenoxluda[OP] likes this.
  4. May 3, 2019 at 8:30 AM
    BillsSR5
    bill
    2014 SR5
    that's a good idea, have a bottle of Quick detailer and a bunch of microfiber towels to wipe off the bug splatter and bird crap or everything else that you can pick up on the trip
  5. May 3, 2019 at 5:03 PM
    lenoxluda
    lenoxluda [OP] Well-Known Member
    09 Sport
    Great point!! You just talked me out of it. Thank you! The bugs get thick as hell up here in the land of 10,000 lakes, after a trip to the cabin only 2hrs away the front gets covered in the summer. I think I'll do it the right way and consider the ceramic coating or sealant at the least.
    PackCon[QUOTED] likes this.
  6. May 3, 2019 at 5:12 PM
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
    Either scotchcal graphic film or Roadwarrior Plus.
  7. May 3, 2019 at 5:14 PM
    Trouble_The_Tacoma
    Trouble_The_Tacoma Well-Known Member
    Conrad
    I'll second the painter's tape method. I know a lot of guys in the tuner car scene who tape up their cars before a show/meet in order to keep them looking fresh without bugs and stuff by the time they get there.
  8. May 3, 2019 at 5:58 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    I added heavy duty dog screen to my front grill years ago and my radiator, AC condenser, trans cooler all still look new with no imbedded bugs or rock chips. Open the hood and attach with 4 clips, close the hood, tighten and clip down to the plastic radiator air dam and the grill area is protected. Lasts about 2 years then replace for a few dollars. As for the paint area that plastic will work great or simply use a dryer sheet and the bugs wipe right off
