Temporary increase idle to like 1k?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by butcherbird, Jul 16, 2022.
  1. Jul 16, 2022 at 8:13 AM
    butcherbird
    butcherbird [OP] Member
    I have a 2011 Tacoma 2.7l and it... has some issues. I probably need to work on throttle body and fuel pump (filter) but at the moment it usually dies when pressure is removed from the gas pump. Is there any way to adjust the idle? I think I had the ecm trained but just replaced battery and alternator and am starting at zero again.
  2. Jul 16, 2022 at 8:21 AM
    Bishop84
    Bishop84 Well-Known Member
    You have to clean the throttle body. Throttle cleaner or penetrating fluid works.
    Next time you replace the battery, turn the key on for 10 seconds before starting and it will prevent this issue.
    Dm93 and butcherbird[OP] like this.
  3. Jul 16, 2022 at 8:25 AM
    butcherbird
    Yeah.. my dad has been suggesting I need to do that. I should probably listen to him occasionally. Thanks I will look into the 10 seconds key suggestion for next time.
  4. Jul 16, 2022 at 8:26 AM
    Smokestacks
    Smokestacks Well-Known Member
    BayArea
    1996 3.4L 4x4 Tacoma extra cab MT.
    Eaton Truetac limited slip Bilstein 5100s struts set at 2” 5100s shocks Torch add a leaf B&M short throw shifter Hella h4 headlights Warn front hitch Curt rear hitch Sony DSX-GS900 Deck Custic 1000watt amp Alumpro 10” sub Lund Steel Gullwing tool box Broadway rearview mirror Weather tech window deflectors
    Why not fix the actual problem instead of creating potential new ones? Did you replace the fuel filter? If for some reason it’s your only solution you can adjust the idle where your throttle pulley is most likely looks and works like a bicycle brake. If you do that I’d mark where it is before so you can put it back.
  5. Jul 16, 2022 at 8:33 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    No fuel filter on 2nd gens, it is integrated into the fuel pump.
    No idle adjustment on 2nd gens either, they are drive-by-wire and PCM controls the idle.
    As suggested above disconnect the battery, clean the throttle body, reconnect, and allow the truck to idle up to operating temp to relearn the idle.
  6. Jul 16, 2022 at 8:38 AM
    butcherbird
    I think fuel filter will require pulling the tank and replacing the fuel pump. I will check again but I think throttle is electronic. I am very fond of my Toyota but am starting to miss my old cj7 right now
    Smokestacks[QUOTED] likes this.
  7. Jul 16, 2022 at 8:56 AM
    butcherbird
    I appreciate the quick replies. At least it confirmed what I need to do today ;)
  8. Jul 17, 2022 at 12:52 PM
    butcherbird
    Just wanted to say thanks. The little bit of carbon on throttle body seems to have been all it was
    Dm93[QUOTED] likes this.
