Temporary Rear Suspension
Discussion in 'Long Travel Suspension' started by anonymous7, Feb 7, 2012.
  1. Feb 7, 2012 at 3:38 PM
    anonymous7
    anonymous7 [OP] Well-Known Member
    Hawaii
    05 Tacoma
    TRD Sport 4x4, Satoshi grill mod, TRD Cold Air Intake,
    Just curious, since i see so many people do it... Get the LT front and wait quite some time before getting a bed cage done.
    What has everyone used as a temporary rear set up?
    Looking for some good suggestions as well, because i plan on doing the same soon.
  2. Feb 7, 2012 at 5:12 PM
    jtlachac08
    jtlachac08 Well-Known Member
    Jeremy
    Phoenix, Az
    I ran the Defined Engineering SUA kit with stock location Bilstein 5100's and was still able to moderately run the truck offroad. It all depends on what rear set up you plan on using I guess.
    What do you have in mind?
    There's no real "temporary" set up. That's just a waste of money lol
  3. Feb 7, 2012 at 9:03 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Do the rear first.
    You'll get better performance out of a rear LT and some bilsteins up front than the other way around.
  4. Feb 7, 2012 at 9:04 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    im in the same boat, but ive decided on AAL and 5100 just to bottom out less often.
  5. Feb 7, 2012 at 11:02 PM
    anonymous7
    Hawaii
    05 Tacoma
    A big reason i DONT want to do the rear first is because im in hawaii with no reason to really use the LT... the only reason im getting it is because eventually i will move back home to california. so the LT performance wont be an issue as im just trying to build my truck up for when i do move back. And so, because the front end will be easier [and i havnt really found a fab shop for the rear yet] i think im going to go with that.
    likely going camburg since the 4wheelparts store on island can help me out with shipping on everything.
  6. Feb 8, 2012 at 7:39 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    you should still build the rear first. i know it doesn't look as cool and it doesn't pull in the bitches like a killer wide gnar gnar sick front end but it's the smarter route to go. take it from people that have already crossd over to the dark side
    you're going to run into the problem once you do get back to CA and still only have a built front end. also, there is a hell of a lot more to PROPERLY building the front end that simply buying a kit and bolting that bitch up. you need to gusset the shit out of everything (this means welding) otherwise it wont take long for you to break something.
    defined and giant both offer nearly 100% bolt on rear LT kits for the 05+ tacomas and there's less welding reinforcement that needs to take place on the back half of the truck...
  7. Feb 8, 2012 at 9:15 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    i suggest listening to matt, he has given me tons of advice with me joining the scene also.
    i listened to most of it, i didnt listen to some. i wish i listened to all of it haha
    edit: and jason (jberry)
  8. Feb 8, 2012 at 10:06 AM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    Actually just buy a built truck allready! lol its alot cheaper
  9. Feb 8, 2012 at 10:36 PM
    anonymous7
    Hawaii
    05 Tacoma
    I am def looking at the giant rear Lt... however... it will cost a crap ton to ship here without the help of a local store.
  10. Feb 9, 2012 at 2:48 AM
    JawKnee
    JawKnee I <3 Pink Tacos
    Ontario Ranch
    2002 Tacoma
    Total Chaos, DMZ, Deaver, Sway-Away, KMC, BFG, Hella, ICOM, BTF, Glassworks, Trac Performance, Lowrance.
    Save your money and wait until you are back in California, then lt the front and back at the same time. You already said it yourself that lt performance is not needed in Hawaii. So why not just wait it out.
  11. Feb 9, 2012 at 7:16 AM
    97yota4wd
    Eric
    Mesa, AZ
    this^
    if your like me, theres no way you could keep that much money in da bank for that long lol
  12. Feb 9, 2012 at 9:53 AM
    Marnes2986
    Marnes2986 Well-Known Member
    Mark
    Anaheim-Corona, Ca
    (6) Method Racing Beadlocks 17x9 Black Powdercoated with Viper Red Beadlocks
    (6) 315x70x17 Goodyear Duratracs
    Camburg Long Travel Front Suspension Kit
    Heim Steering
    Heim Upper Arms
    Bypass Hoop
    TC Coil Bucket Gusset Kit
    TC Lower Arm Tab Gussets
    Camburg 4.0 Spindle
    Fox 2.5''x8'' Coilovers
    Fox 2.5''x 8'' Triple Bypasses
    Fox 2''x 2'' Bump Stops
    DMZ Rear SUA Kit
    Fox 3.0''x 16'' Triple Bypasses
    Fox 2''x4'' Bump Stops
    Glassworx fiberglass all around
    Kartek Battery Boxes
    Dual Optima Yellow Top Deep Cycle Batteries
    (5) Hellas converted to HIDS
    (3) Hella Ralle 4000 HIDS
    (2) Hella Optilux HIDS
    Piaa amber
    Aluminum Dust light Housing With Maximus LEDs
    Mastercraft 3G Racing Seats
    Crow 5 Point harnesses
    ICOM 2200H Race Radio
    Cobra CB
    Federal Signal Siren/PA
    Uniden HP1 Digital Trunking Scanner
    Escort 9500ix GPS Radar detector
    Lowrance Baja Elite
    Kenwood Head Unit
    MB Quart Speakers
    Kicker Subs
    Autometer Carbon Fiber Gauges
    K&N Intake
    Doug Thorley Headers
    dual Borla XR1 Racing Mufflers w/3'' exhaust
    URD AFR Calibration
    Blacked Out Windows
    Moroso roll bar padding
    Mastercraft roll bar handles
    ALLVIEW Rearview Mirror
    Quick Disconnect fire Extinguisher
    Dynamat
    K4 Switches
    Blue Sea Systems LEDs
  13. Feb 9, 2012 at 9:56 AM
    Marnes2986
    Mark
    Anaheim-Corona, Ca
    Just collect parts! The owner of the truck above collected all those parts before putting on his truck and did everything at once
    I suggest installing a race radio/modded ham radio or investing in a GPS. Buy some fox shocks from 4wheel in HI. Open a savings account etc. Just offroad with the truck stock and when you get to Cali just start building with all the parts youve collected
  14. Feb 9, 2012 at 12:57 PM
    anonymous7
    Hawaii
    05 Tacoma
    Definitely might save now, but still have to spend a little. My stock suspension feels like crap and it's time to replace it, which is the biggest reason i would like to do this.
    So, maybe any more suggestions would be nice. It's mostly my tax return, so I'm going to be very likely to spend it.
    Maybe i'll get a supercharger.. HAHAHA
    On a serious note. I may do the rear first, there are thing's i would like to do to the bed that would require a lot of work. While keeping it usable, that is.
    I will likely go with the Giant rear... is the picture of the bed cage posted on there site the bolt on cage? If it is then it is very likely i will go that route, it looks pretty good.
  15. Feb 9, 2012 at 1:05 PM
    jtlachac08
    Jeremy
    Phoenix, Az
    They do have a very nice looking bolt in bed cage, at a very not so nice looking price. Can't wait to see the turn out.
  16. Feb 9, 2012 at 1:59 PM
    Marnes2986
    Mark
    Anaheim-Corona, Ca
    If you want to get the kit and install it, its your choice. A lot of us have done it that way and although I warn against following in my footsteps, I say if you wanna buy it just buy it. Its your truck
    Just be aware that youll be a bucking bronco as soon as you hit an uneven whoop. Make sure you check your motormounts and buy TC's aligment cam gussets.
    We sound like downers, but in reality, youll have fun with a truck that has LT front and stock Rear. Just dont expect too much out of it. Have fun!
  17. Feb 9, 2012 at 2:08 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    I have about given up on this concept. I hardly ever get bitches with my gnar gnar front end! Mostly just random dudes looking under my fenders. It's just annoying.
  18. Feb 9, 2012 at 2:10 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    What I love is the guys that walk up and say "how much is a lift kit like that"
  19. Feb 9, 2012 at 2:25 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    lmao yea and "what kind of lift is that?"
    I just say spacer lift
  20. Feb 9, 2012 at 2:25 PM
    jtlachac08
    Jeremy
    Phoenix, Az
    Or
    "Damn sick trophy truck bro"
    :rofl:
