Tensioner/timing guides
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jerry07$, Jan 29, 2025.
  1. Jan 29, 2025 at 6:01 AM
    Jerry07$
    Jerry07$ [OP] Active Member
    I have a slight rattle on acceleration, it doesn’t sound very loud or violent if that makes sense? I was just wondering if anyone here as had a timing chain tensioner or guide go bad on 3.5 2GR-FKS engine in the Tacoma? I have no other symptoms other than the slight rattle, no misfires, starts and runs fine, idle is solid, no issues or odd sounds on start up hot or cold. I bought the truck used it’s got just shy of 80,000 miles on it. Coming from the 2.7, I’m fairly new to the 3.5. Any thoughts or input would be appreciated.
  2. Jan 29, 2025 at 6:07 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    I would vote spark knock over tensioner rattle.
    t0p_d0g likes this.
  3. Jan 30, 2025 at 2:35 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    As airforce2cc mentioned. Try higher grade fuel, see if that eliminates rattle. Also check for any loose heat shields, or parts.
