Tensioner
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bg04 tacoma, Sep 27, 2016.
  1. Sep 27, 2016 at 5:15 PM
    Bg04 tacoma
    Bg04 tacoma [OP] Member
    2004 tacoma SR5 Pre Runner v6 ext cab Black
    None only had 6 months
    Anyone know the signs of a bad upper tensioner (stationary one) for a 3.4?
  2. Sep 28, 2016 at 8:37 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    What are you talking about?
    I would say the signs of a bad upper tensioner are a loss of tension on whatever the tensioner is tensioning...:D
    Other than that, could you be a little more specific?
    TooMuchToDo likes this.
  3. Sep 28, 2016 at 9:28 AM
    TooMuchToDo
    TooMuchToDo Well-Known Member
    2002 Gold Tacoma XtraCab with 192k
    ...we'll get there.
    if you're talking about the idler pulley in the timing belt setup squealing would be sign #1. excessive TB wear would be #2.
    most TB kits include replacement pulleys, might as well replace it while you're in there, even if it's not bad. I did the same with my water pump. Pulled the old one out and it looked just fine and felt solid...but, i was elbow deep in the engine already. better to replace it with OEM now than cook the engine when the old one decides to fail.
  4. Sep 28, 2016 at 9:44 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    ^ Yeah you'll feel a grinding feeling when manually spinning it, or most likely you'll hear it squeaking. TBH I rarely replace them if they're not making noise because they usually last a really long time, but it is definitely a good idea to do it while you're in there.
