TEPUI Roof Top Tents and Gear
Discussion in 'Buy / Sell / Trade' started by TepuiTents, Jul 9, 2014.
  1. Oct 29, 2016 at 6:16 AM
    #361
    Fox2011PM
    Fox2011PM "The Mountains are calling"
    '13 DCSB 4X4 TRD OR
    ADS 2.5" CO's w/adj, ADS 2.5" Rears w/ piggybacks, Firestone air bags and 1.5" AAL, SCS SR8s, Tom Woods custom one piece drive shaft....more to come
    Perfect, thanks
  2. Oct 31, 2016 at 12:16 PM
    #362
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    Tepui Ayer on the tall relentless bars. its about flush with the top of the prinsu rack.
    sawjai526, scott96929 and Box Rocket like this.
  3. Oct 31, 2016 at 5:31 PM
    #363
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    Looks great buddy! Thank you! Nice truck
    Tac0maSteve and rob1208[QUOTED] like this.
  4. Nov 19, 2016 at 4:06 PM
    #364
    scott96929
    scott96929 IRoniK
    Scott
    Phoenix, Az
    2007 Tocoma PreRunner (Ironik)
    All Pro Front Plate Bumper, MaxTrac 4" Spindles, Light Racing Upper Control Arms, BOSS Leaf Springs, Toytec Adjustable Coilovers, Fox 2.0 Rear shocks, 17" Raceline Assault Wheels, Toyo RT 285 70R17, AFE Stg II Cold Air Intake, Prinsu Cabrack, Prinsu Bedrack, 10K Kensun HID Headlights, Avec 20" Optic LED Light Bar, Avec LED Fog Lights, Heretic 30" Combo LED Light Bar, Viper Max 12000 Winch, Quick Fist, Tepui Kukeman Ruggerized RTT, Smittybilt Awning, Relentless Fab Tailgate Reinforcement, Anti-Dark Hood Lighting Kit, Fog Lights Anytime Mod, Rear Differential Breather Mod, P&L Tailgate Lock, KMFAB Rock Sliders, KMFAB Rock Light Kit, KMFAB Bed Light Kit, KMFAB RTT Light Kit, KMFAB 12 VDC Outlet Kit,Optima Dual Battery, SSCS Kit, Switch Pro 8100 Kit, Cali Raised Ditch Light Kit
    Kukenam XL Ruggedized RTT with RTT light kit mod and Rock lights fabricated and installed by @JeepAndrew Lights light up the campsite really nice. The RTT Light Kit inside the RTT has its own switch and has dim control as well. The exterior RTT Light Kit has its own switch and has dimmer control as well. Both hooked up to (1) 12 Volts adapter plug in the bed of the truck. If you want to see more pics of this set up look here, https://www.tacomaworld.com/media/albums/rtt-light-kit.28311/
    Moab, Utah
    [​IMG][​IMG][​IMG][​IMG][​IMG]
  5. Dec 6, 2016 at 10:10 PM
    #365
    JackSmith
    JackSmith Well-Known Member
    Tony
    SJC, CA
    '16 TRD OR DCSB 4x4 Manual
    aaaaaarg, so much stuff to buy
  6. Dec 9, 2016 at 7:59 PM
    #366
    hobiecat111629
    hobiecat111629 Well-Known Member
    2015 Tacoma Access Cab
    Digging up an old one.....I'm giving serious consideration to either the Ayer or the Kukenam, but can't decide. Anyone slept with two people and a dog in the Ayer?
    The Kukenam looks like it would be better suited for my wife and I with our 60lb boxer, but I'm not sure if the extra weight is worth it for the 1-2 trips a year we don't have a dog sitter and take him with us.
  7. Dec 10, 2016 at 4:23 PM
    #367
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    Long wait but worth it. Spent all day painting the bars, creating a hoist system then mounting it up. Now I can't wait to use it
    rileySB, sytfu510 and BYJOSHCOOK like this.
  8. Dec 13, 2016 at 1:52 PM
    #368
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Anybody with the Autana-R. Can the annex fit into a 35L dry bag? Roughly 12" in diameter and 24" long...
  9. Dec 13, 2016 at 4:03 PM
    #369
    hobiecat111629
    Which one do you have? And how bad is the loss of rear visibility at that height?
  10. Dec 13, 2016 at 5:52 PM
    #370
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    Tepui Kukenam Sky Ruggedized. How much visibility is lost?.....all of it lol. But it doesn't bother me, I rarely use my rear view mirror anyway, except when I back up, but I use the rear view camera in the mirror, not the actual mirror. I did a lot of research on which bars and how much height I wanted and landed on this setup. Relentless Fab 8" bed bars (3). I wanted it the same height as the cab to reduce any drag. I did replace my plastic bed caps with KBVOODOO's flat steel ones. So I'm thinking on the factory plastic ones, you could expect about an inch more in height. I think any setup that doesn't put the tent higher than the cab will all but eliminate rear visibility out of the rear view mirror. Even if you did a mount that kept it at the same height as the bed I feel would still impede rear visibility. The tent closed is about 12", but with the ladder and the cover prob puts you at closer to 18" or so. That all said, I'm 100% content with this setup. Hope this helped
  11. Jan 12, 2017 at 5:43 PM
    #371
    CO_0321er
    CO_0321er Well-Known Member
    I know you posted this a while ago.
    But I was in the same boat as you. I measured out on my floor the sleeping size of the Ayer, boxed it off, laid inside of it, and realized it will be tight for just my wife and I. A dog would make it uncomfortable. I went with the Kukenam. As soon as I set it up and got in it, I'm happy with my decision. I say Kukenam for 2 plus a dog.
  12. Jan 12, 2017 at 6:11 PM
    #372
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    been eyeing the Kekenam Sky Woods Camo for a while now, how much w/out shipping since I plan on picking it up myself..
  13. Jan 12, 2017 at 7:46 PM
    #373
    CO_0321er
    If you are an REI member, you can have it delivered to your local REI for free. Plus if you are a member, you will receive 10% back. I paid 1400 for my Kukenam sky. Free shipping. And I'll be getting $140 back.
  14. Jan 13, 2017 at 1:05 AM
    #374
    rileySB
    rileySB RileySB
    Gen
    Santa Barbara, CA
    13 DCSB OR 4x4
    5100/887, Dakars, 285s, Built Right UCAs, Icon rears
    I understand that the material on the Ruggedized version is thicker and the bottom is diamond plated and stronger...I'm just wondering if anyone wants to chime in about their experience between the two? I really want the Ruggedized Kukenam but REI only has it in bright orange and it's about $600 more than the Kukenam Sky which has more color options. I'm hoping to use my REI dividend and their april sale to catch a good deal. I wanted the Ruggedized because I figured, why not get the most durable, best option...but now I'm wondering if it's overkill for my level of off roading. My plan is to go on more primitive trips this coming year, but I don't do much heavy duty rock crawling or anything super technical, don't have lockers, and I just like to cruise on fun dirt roads to nice scenic places... Just curious if my level of offroading (stuff like Lippincott, Laurel Lakes, some of the blue rated Big Bear runs, Imogene Pass, Alpine Loop, washboard Death Valley runs) warrants spending extra on the Ruggedized version. Thanks in advance!
  15. Jan 13, 2017 at 11:26 AM
    #375
    CO_0321er
    I know we messaged each other... but I'm not sure what our level of off roading expierence has to do with which tent to buy. Im as noob as they come with wheeling. I too don't have lockers. I don't do hardcore crawling. But I love to camp and off road to my potential. I think your location and weather situations decides on which tent you get. Someone can chime in if they think off roading expierence deserves different tents. I'd like to know the facts if it does.
  16. Jan 13, 2017 at 7:08 PM
    #376
    rileySB
    rileySB RileySB
    Gen
    Santa Barbara, CA
    13 DCSB OR 4x4
    The description said it's more durable for 4x4 rigs. But I'm not sure what that has to do with the tent. Unless doing more hardcore wheeling is going to be detrimental to the frame or something? It's not like I'm going to be driving off road with the tent open so I'm not sure why it matters. Yes, can someone please chime in? Much appreciated!
    Tatts521 and CO_0321er like this.
  17. Jan 27, 2017 at 8:40 PM
    #377
    hobiecat111629
    With the 8" relentless bars, do the window props on the front window clear the cab?
  18. Jan 27, 2017 at 8:59 PM
    #378
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    I can guarantee they don't. With the allpro rack the tent stuck above the cab some and I still had to bend a rod to open the window
  19. Jan 27, 2017 at 9:56 PM
    #379
    hobiecat111629
    Well damn......Do you have a short bed or long bed?
    I'm hoping a long bed gives enough wiggle room to slide the tent back enough to clear the rods. I really want to be able to get the window open and still clear the mast on my sailboat without having to unhitch the trailer at 2am when we roll into a regatta site.
  20. Jan 28, 2017 at 5:09 AM
    #380
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    I got my passenger side to clear, but both....no. I've seen people rig different things up to prop them open, but like I said, I got one corner of the cab side window to clear using one prop bar, and I figure for ventilation, that will be good enough. It's a great tent and great bed bars.
