Terrible 4 cylinder mpg
Discussion in '4 Cylinder' started by Wolverinesam, Nov 3, 2015.
  1. Jun 9, 2016 at 5:04 AM
    #181
    JL911
    JL911 Psshh
    PA
    5 spd 4 bngr
    Calling bullshit.
  2. Jun 9, 2016 at 5:25 AM
    #182
    Tylandus
    Tylandus Well-Known Member
    Midwest
    2019 4Runner SR5 Premium Superwhite
    My '12 4cyl PreRunner (4x2) Access Cab has gotten 22.5 and 22.3 avg MPG the last two tanks that I have watched. I live in StL and my driving is highway/suburbia combo and admittedly my foot gets lighter the older I get. My '08 Mazda 3 hatchback I traded in for the Taco only averaged ~1 MPG better than this truck; I'd say the tradeoff of fuel economy for a truck I have wanted for years has been worth it.
  3. Jun 9, 2016 at 10:26 AM
    #183
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    Any time you want to observe, come on by. The last time someone called me a liar on this forum I made the mistake of apparently sounding like a tough guy. Not my intent. I keep a book on my gas purchases and miles. Last summer I made a trip through Utah and Colorado, mostly off the interstates and frequently on back roads. The truck was loaded in the back and behind the seats with camping gear and averaged 25 mpg. Maybe there is something different about my truck. I have always been able to exceed the rated MPGs on my vehicles, tho.
  4. Jun 9, 2016 at 10:48 AM
    #184
    jayuu
    jayuu Well-Known Member
    Central Maine Highlands
    2017 Black TRD Sport DCSB 6 sp manual
    I used to avg @24-25 with my 2010; and, like you, have generally gotten better mpg than the window sticker estimate...
  5. Jun 9, 2016 at 1:49 PM
    #185
    JL911
    JL911 Psshh
    PA
    5 spd 4 bngr
    How are you tracking your mileage? I'd like to see you enter data into a tracker like the one I have in my signature and not just some off the cuff estimate. EPA rates the 4x4 2.7 manual at 19 mpg combined. I too have exceeded the EPA estimate by 3 mpg as seen in the tracking app. I have a very difficult time believing that you are getting 6 mpg higher in mountainous and high elevation terrain with hundreds of extra pounds added.
  6. Jun 9, 2016 at 4:17 PM
    #186
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    It's easily explained that generally you CAN get better mpg at high elevation. Thinner air means less wind resistance, and less drag. Thinner air means less power which means less gas, unless you just keep your foot in it and try to maintain 10 mpg over the speed limit climbing hills. I get 4-5 mpg better at CO elevation, compared to sea level.
  7. Jun 9, 2016 at 4:23 PM
    #187
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Written mileage data is "off the cuff" estimating?
    Calm down a bit.
  8. Jun 9, 2016 at 5:56 PM
    #188
    JL911
    JL911 Psshh
    PA
    5 spd 4 bngr
    Where's the data? Im not upset. Just calling BS.
  9. Jun 9, 2016 at 6:09 PM
    #189
    T4RFTMFW
    On his notepad, apparently. Which is allowed.
    Why anyone has to prove anything to you is beyond me, my truck got 24 average and a high of 28.
    It happens. It may not happen to you, though.
  10. Jun 9, 2016 at 8:17 PM
    #190
    worthywads
    You gas up every 1-4 days 4-11 gallons, who's got time for that? I have no doubt azreb can pull 25 mpg, especial at altitude.
    10 years of my data, yeah 4 tanks in a row averaging over 36 in 2009.
  11. Jun 10, 2016 at 5:01 AM
    #191
    JL911
    JL911 Psshh
    PA
    5 spd 4 bngr
    I prefer to not let my tank go below half. Your truck is 2wd so of course it gets better fuel economy.
  12. Jun 11, 2016 at 10:26 AM
    #192
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    I once thought I had exceeded 27 mpg once and 26 mpg a few times. Made me really happy about the truck until I took the time to compare the odometer to freeway mile markers and gps. The truck would read 6% more miles (inflating the mpg number) and 10% more speed (so I was unknowingly driving at a more efficient speed). A $30 speedo gear from Toyota made the odometer right but the speedometer is still a little high. I don't know why they would calibrate a four cylinder truck so it would need 285/75 tires to make the odometer right (and the speedo would still read fast!). I know it's not just my truck either. At least one other on this forum put an N30 gear on the speedo sender to fix his because I copied what he did.
    That's why whenever I see someone with a 2.7 5 speed 4x4 make a claim I chuckle a bit knowing someone else was swindled too.
    At elevation, I have no doubt his truck could average an honest 25 mpg with the right commute, even without hypermiling. I'm at 800 ft or so and with a 20 mile rural commute I had no difficulty at all keeping around 23 mpg just setting the cruise at 55 and trying to ignore the whine.
  13. Jun 11, 2016 at 10:39 AM
    #193
    jayuu
    FWIW, my 2010 odometer was pretty much spot-on with the interstate markers. And I got 25 mpg...
  14. Jun 11, 2016 at 3:17 PM
    #194
    worthywads
    My 5-lug is 1.5% off on the Odometer but 6% off on speed. I don't adjust my mpg because of the 1.5%, my actual odometer reading is off by more than 1.5% the other way since while hypermiling the distance traveled between shutting off the motor and putting it back into run isn't recorded on the odometer.
    I doubt many people here factor the odometer with their stock tires, though we're all off some, not just the 4x4 2.7L guys.
  15. Jun 11, 2016 at 4:01 PM
    #195
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    As long as I get 300+ miles per tank I'm good with that. I don't need any more maths beyond that. 4X4 2.7L 5spd lifted w/ 33's , 4.56 and camper.
    jayuu likes this.
  16. Jun 14, 2016 at 1:10 PM
    #196
    Albino Taco
    Albino Taco Member
    Helotes, TX
    '10 Super White Tacoma Reg. Cab 2.4L 4x4
    Brush guard, winch
    Peddle to the metal! Screw it!
  17. Jun 14, 2016 at 1:28 PM
    #197
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Alot of liars in this thread.
  18. Jun 14, 2016 at 4:06 PM
    #198
    worthywads
    I know, I can't believe some people tell us worse than what they really get. :crazy:
  19. Jun 16, 2016 at 4:39 PM
    #199
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    Still hitting 19-22 mpg
  20. Jun 16, 2016 at 8:48 PM
    #200
    75z28
    75z28 Well-Known Member
    Homer
    2017 OR 4x4 DCLB SSM
    My 2wd access cab 2.7 5 speed averaged around 27 mixed city and highway
    My 4wd access cab 2.7 5 speed averages around 20-22(with a load in the back or not). The truck is like a tractor.
