Terrible 4 cylinder mpg
Discussion in '4 Cylinder' started by Wolverinesam, Nov 3, 2015.
  1. Nov 6, 2015 at 9:17 PM
    #81
    JohnNP
    JohnNP ForeRunners Future Wife :)~
    Hobe Sound, FL
    2014 DCSB 4x4 TRD Sport JBL
    As of 11/4/15 1) Tailgate Anti-Theft Mod 2) ND4SPDBP's Fog Light Mod 3) Devil Horn Emblem 4) Weathertech Digital Floor Liners 5) ADD W-1 Vers 2 Baffled Oil Catch Can- constantly surprised at how much oil this thing captures 6) Weatherproof Under the rail LED bedlights Warm White (by Mattgecko) with hidden small cubby switch 7) Sliding Window Security Bar 8) Hood Lighting Kit Warm White /Pro Kit (by BeeRad) 9) Morimoto mini D2S retrofit HID lights w/ 55W ballasts and XB 5000k bulbs from TRS- one of the best modifications I have ever made, blows the stock lights out of the water 10) ImMrYo bracket 11) Scangauge II 12) Autodimming mirror w/ Compass/Temperature/Homelink 13) Bedrug Mat and Tailgate rug. 14) Pop n Lock Power tailgate lock w/ bolt coded to factory key. 15) Map Light w/ Door Mod 16) BakFlip HD Tonneau Cover 17) 35% Front windows ceramic tint - a very good match to factory 19) Gerber machete, because every truck needs a machete 20) Various flashlights, really love my Black Diamond Miner Mole Headlamp 21) AFE Pro Dry drop in filter 22) removed secondary charcoal air filter 23) Back up light Mod- I used the light bulb as found on page 14, 35W from Lowes. https://www.tacomaworld.com/threads/886-backup-light-mod.209578/page-14 24) Hi-Lift Off Road Recovery Kit- thank you TW Secret Santa 25) Tailgate Seal 26 interior footwell/rear seat dome light controlled LEDS https://www.tacomaworld.com/threads/footwell-and-rear-seat-led-light-dome-switched-mod-lots-of-pics.409428/#post-11529460 27) pelfrybilt aluminum front skid 28) morimoto XB fog lights 29) mob town front recovery bar with 2 Smitty bilt D-Rings 30) 48" Extreme Hi-Lift Jacks w/ ATO rail mounts 31) Prinsu rack 32) Rigid D2 Ditch lights 33) 40" Heretic LED bar on Prinsu Rack 34) Kawell x 6 side lights 2 spot and 1 wide per side 35) Rigid SRQ2 x 2 rear facing asshole/backup lights 36) NSA switch panel to 150amp bussman fuse on custom made mount 37) 267/70/17 BFG KO2's in C rating Pending installation 1) Rock Lights Upcoming/Possible Mods 1) Katzkin Leather Seats in black/ice grey (supposedly better factory match for the 2014) w/ Degreeze heater/cooling and TRD stitched into the seat faces thru jhuey - once I get to Arizona will buy them and have him install them 3) Total chaos UCA's 4) Kinda want to get some of the 2016 TRD Sport Rims or the grey TRD wheels the FJ cruiser/4Runners have. 5) BAMF LCA Skids 6) ICON or KING coilover 8) BAMF hidden grill light mounts 9) 20" or 30" LED light by Rigid Industries for behind the Grill. . 10) full leave pack maybe the Deaver 10 leaf set 11) ? Warn m8000 winch- really depends on if I end up doing more off roading 12) Possibly a console vault, not entirely convinced those are as secure as they would have you believe.
    I had a 4cyl 5spd Manual and got around 18-19mpg. When I traded up to my 4.0 it's now averaging as you can see in my Sig at 16.5. I of course have noticed the "drop" associated with the winter gas blend. I did get to I believe it was 20.9 that is listed in my Fuelly when coming back from Florida doing mainly 50-60mph on the way back to Atlanta on a tank. That made me pretty happy. It's never happened since. If I stay on the interstate and go 70-75 I'll get around 18 in my 4.0. I would get around 21 in my 4 cylinder as long as I didn't go over 70 anything beyond 70mph and that mph would do the same as my current 4.0L. There is a little link up above at the top of the page that says Mods, there is a MPG one in there.
    Evidently removal of the secondary charcoal air filter on the 4 cylinders helps with mpg's. Here's the link.
    https://www.tacomaworld.com/threads/mpg-mods.34594/#post-547096
    NMTrailRider likes this.
  2. Nov 6, 2015 at 9:37 PM
    #82
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    Those numbers sound similar to what I experienced/am experiencing, although my overall mpg is slightly better than yours. Probably because I'm logging more highway than you (and most of my traveling is on the summer blend). I have mpg graphs for both the 4 and the 6 over about 90 tanks each. I'll see if I can find them...
  3. Nov 6, 2015 at 9:42 PM
    #83
    JohnNP
    Hobe Sound, FL
    Yep, the vast majority of my driving is usually around town, stop and go. Very rarely do I get on the interstate. I try very hard to be gentle with the skinny pedal the whole "egg underneath" when accelerating, though I've also seen posts that say giving it more gas to get up to speed is better. I'm going to be removing my own secondary charcoal filter here on a day that its finally not raining and will be installing an AFE Pro Dry air filter as well. That seems to be a good choice amongst the members.
    NMTrailRider[QUOTED] likes this.
  4. Nov 6, 2015 at 9:46 PM
    #84
    NMTrailRider
    New Mexico
    So here's the chart for my 2010 double cab 4cyl 4x4. I traded it for a 2012 and am now in a 2014. Can't find the 12/14 charts at the moment but I will look for them.
    Here's a link to the original thread/discussion: https://www.tacomaworld.com/threads/gas-milage-chart-2010-double-cab-v6.200313/
    The 21 and 22 mpg tanks were probably summer days with a 20-30mph ND wind pushing me along at 75mph.
  5. Nov 7, 2015 at 5:25 AM
    #85
    Wolverinesam
    Wolverinesam [OP] Well-Known Member
    New York State
    2013 Tacoma Prerunner 2.7L
    Thanks for the input Bkill.
  6. Nov 7, 2015 at 7:04 AM
    #86
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    No one is saying that a six does any better, but why have to pull over out of the travel into the break down lane to keep from getting run over by a semi. Had a two stroke SAAB on the Jersey state Parkway......deadly in high speed traffic. My four cylinder Taco in 4 wd was nearly as bad at higher speeds.
  7. Nov 9, 2015 at 2:14 PM
    #87
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I know the tire sizes for our trucks are different but I didn't think the recommended pressures would be *so* different -- 29 front/ 32 rear recommended on the stock 215/70R15 tires for my my 2006 5-lug. I usually run 34 front/ 32 rear.
  8. Nov 10, 2015 at 2:17 PM
    #88
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    Soo how is it you guys are getting such bad milage ? Cause some of you guys do stock what my truck does armored up. I'd like to understand
  9. Nov 10, 2015 at 3:41 PM
    #89
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    Haha right?!!?!? If I can get 24mpg on the highway with a 4x4 extended cab with a heavy ass bed cap, 33in 53lb tires, carrying 350lbs on the hitch.... then what in the fuck are the rest of you doing?:cookiemonster:
    numbah57 likes this.
  10. Nov 10, 2015 at 3:49 PM
    #90
    big_jarv
    big_jarv Well-Known Member
    2020 TRD Pro
    I ran 87 one tank and 91 another and got identical mileage.
    I did feel my truck got up to speed quicker on 91.
  11. Nov 10, 2015 at 3:50 PM
    #91
    TYetti
    Mat
    At first my assumption was the auto tranny and that it's just that awful. But there are some huge discrepancies. I did 21 mpg on my last tank with, plate bumpers, 3/8th skids, sliders, and a tool box full of tools and recovery gear and 5 265/75's. Are people filling up as soon as the fuel light comes on or at a 1/4 tanks?
  12. Nov 10, 2015 at 3:53 PM
    #92
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    Probably driving up hill. You're only going down with those numbers.
    big_jarv likes this.
  13. Nov 10, 2015 at 4:58 PM
    #93
    WheelInTheSky
    G
    Jackson Hole
    Nope, that's the average of going across the entire country on interstate 70. So the gentle rolling features of missouri, the flats of kansas, and the ridiculous up and down of the utah/colorado/california areas are all included. Did I mention that my exhaust system was leaking at the time, and that I spent half the trip going over 80mph? Spent 4 hours in stop and go traffic between Vegas and LA...
    If I'd babied my truck and gone 55 the whole way I'm sure I would have been over 27mpg.
  14. Nov 10, 2015 at 5:03 PM
    #94
    WheelInTheSky
    G
    Jackson Hole
    Forget higher octane fuel. Ethanol is added to the lower octanes as a way to up the energy cheaply. It doesn't have a significant enough effect on mpg to justify the extra cost of high octane ethanol free fuel.
    As for your truck seeming to get up to speed quicker, the energy difference between 87 and 91 is so minute that it is not possible to feel. The only real difference is in how much compression the fuel can handle before spontaneously combusting. A good example of this sort of placebo effect is that my shaft feels longer every time I put my hand on it. This does not, however, make it true.:laugh:
  15. Nov 10, 2015 at 5:16 PM
    #95
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    Leaky exhaust system, that 's the secrete. Don't tell me you were driving 80. The secrete to good mileage is moderate speeds. Keep under 65 and your numbers are closer to reasonable. You need to work for Toyota in the advisory capacity. Actually, 24 is reasonable for a four with a cap on the highway with a reasonable 350 lbs load driving 65 mph. You stretch credibility with me driving 80. My six will do 23-4 mph all day long at below 65. Higher, it starts dropping like a lead ballon. I can't believe a four isn't sucking pond water. But who am I...I wasn't there.
  16. Nov 10, 2015 at 5:52 PM
    #96
    big_jarv
    2020 TRD Pro
    I kinda felt it was probably the placebo effect lol
    It's nice to dream haha
  17. Nov 10, 2015 at 6:10 PM
    #97
    WheelInTheSky
    G
    Jackson Hole
    There were a lot of variables.. goin 45 through the mountains, goin 85-105 through a lot of Utah:anonymous: having over 500lbs additional weight didn't hurt.. there was a lot to it. I actually have detailed notes that I took of different variable changes from tank to tank. I intend to make a graph out of them and see how efficiency changed over the course of my trip. I'd like to drive 55 the whole way next time i head out West just to see how good I can get of mpg.
  18. Nov 10, 2015 at 7:21 PM
    #98
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    That sounds great. But driving 80 mph half the distance does not balance with driving 40 mph the other half. That is the only problem I have seeing your mileage. Driving 60 all of the time is more efficient as you well know. A burdened four suffers more and demands a lower maximum. Modern mpg fuel monitoring systems validates this.
  19. Nov 11, 2015 at 8:21 AM
    #99
    WheelInTheSky
    G
    Jackson Hole
    I'll need to verify the numbers when I get a chance. I am probably exaggerating/forgetting a good deal of info right now. I'll post up when i compile the data and make some sort of graph or some shit lol.
    Dagosa[QUOTED] likes this.
  20. Nov 11, 2015 at 9:41 AM
    #100
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    No problem. Exaggeration makes for much better conversation. Without it, it would be one boring f'n world. This entire web sight is filled with it....thank god.
