Terrible at backing boat down ramp, thinking front hitch
Discussion in 'Boating & Fishing' started by jaymoussy, Jan 2, 2018.
  1. Jan 2, 2018 at 7:09 AM
    jaymoussy
    jaymoussy [OP] Well-Known Member
    Eastern MA, US
    '12 AC Base 2.7l 4a
    I am terrible at backing my 17 f boat down launch ramp, so I was thinking about a front hitch scheme:
    I position boat approx in line with ramp, secure with chucks, quickly unhitch and turn truck around attach trailer to front, slow down ramp with full view.
    I know it is done. Anybody seen it in action?
    I would sound a bit over the top, but I have a hard time with it.
    Other solution: get a cheap trailer and practice
    TXpro4X4 and JGO like this.
  2. Jan 2, 2018 at 7:12 AM
    90yota
    90yota Instagram: 90_yota
    Dixon, CA/Truckee,CA
    88 T4R / 15 F350
    Stock....ish
    Practice makes perfect
    LTDSC, Prayn4surf, Bridge4 and 4 others like this.
  3. Jan 2, 2018 at 7:14 AM
    pta_taco
    pta_taco Exploring when I can
    Patrick
    Greenville, South Carolina
    2016 TRD Off-Road
    https://www.tacomaworld.com/threads/pta_taco-2016-offroad-build.493686/
    Can’t be as bad as my girl with my boat..
    Had to replace a bumper cap already..
    wilcam47 likes this.
  4. Jan 2, 2018 at 7:17 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    It is definitely easier. Actually much easier.
    On the other hand, practicing backing a trailer should be mastered. There will be times you wont have time to switch back to front.
    I think of it like learning to drive a stick shift. It was difficult and frustrating, but one day it just clicked.
    You can master this. Just go to an empty parking lot.
  5. Jan 2, 2018 at 7:20 AM
    Tacoaric
    Tacoaric Well-Known Member
    Dallas, Texas
    King Ranch F250 Powerstroke
    You’d still have to back up the ramp..
  6. Jan 2, 2018 at 7:21 AM
    10tacosr5
    10tacosr5 Well-Known Member
    Washington Twp, South NJ
    2010 Tacoma SR5 DCLB
    5100s/Headstrong Coils/Deaver AAL/Level8 MK6/FalkenWildpeakAT3
    definetly practice makes perfect. when your at a busy ramp and alot of people are trying to get in and out of the water your not going to have time to disconnected and reconnect to the front without pissing alot of people off. just hook up go to a big empty parking lot and practice backing into spots. you will get it, it just takes time. the hardest part for me was backing up to the ramp without the boat on the trailer, cant see the trailer at all(ive only got a 12footer, so small trailer).
    Gunshot-6A likes this.
  7. Jan 2, 2018 at 7:23 AM
    ArmandHammer83
    ArmandHammer83 This truck is AMAZING
    Raymond
    Alabama
    2018 Tacoma AC V6 MT 4x4
    none yet
    just remember go slow and like mentioned before try in an empty parking lot..maybe with a en empty trailer too...
    Harry2015 likes this.
  8. Jan 2, 2018 at 7:25 AM
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    This will waste so much time at the ramp, every time you drive there you'd have to unhook the trailer, turn the truck around then hook up the trailer in the front. Sounds like a huge PITA when you could just practice and master backing up
  9. Jan 2, 2018 at 7:25 AM
    koditten
    Kirk
    Central Michigan
    Put one hand at the bottom of the wheel. Move your hand the direction you want the trailer to go.
  10. Jan 2, 2018 at 7:34 AM
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    Honestly, the thing that taught me was using an RC truck with a trailer. It helped me get a bird's eye view of the process so my spatial skills improved. I was 14 or 15 at the time.
    Eye candy:
    https://youtu.be/_upu8R6iVt4
  11. Jan 2, 2018 at 7:37 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    this ^^ works great
  12. Jan 2, 2018 at 7:43 AM
    TRDZILA
    TRDZILA MPS SUX
    Brian “”Keith””
    Kokomo Indiana
    DCSB 12 slightly lifted Tacoma
    Ripped off all four mudflaps. Scratches all down both sides 6112’s up front on 3rd notch 5100’s in back with Toytech 1” block Skids & sliders from SOS Concepts I got rid of the 1” block and put on Wheelers 1 1/2” progressive AAL. SPC UCA. Be sure your standing on the drivers side when reading the instructions! I swapped sides so many times that I can swap UCA’s in 15 minutes. I put in the 3/4” spacer to eliminate the Taco Lean, and just got my 4th alignment. Traded the OEM rims for 17” Sport rims and a bora bora 1” spacer. I got my Firestone 285/70/17 MT2’s. Pelfreybilt gas tank skid and hi-lift jack should be here Friday. Looking at bumpers, but I think they will wait for next year. So far I’m happy with my build. I’ve done it all myself, leading to a lot of cussing and frustration, but it’s all mine.
    A girlie Ford pickup will back it up for you.
    PvilleJohn and wheeliest like this.
  13. Jan 2, 2018 at 7:47 AM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    This is the easiest way to learn. I learned with an 8ft trailer which is a PITA because it Jack knifes so easy!!! But now everything else is easy.
    PvilleJohn and JimboAnz like this.
  14. Jan 2, 2018 at 7:48 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Sounds crazy to be honest. Will waste a lot of time at the ramp and if you've got people waiting in line behind you they'll definitely get a chuckle out of it. Just practice. When I first moved to college I hitched up my Grand Marquis with a junky utility trailer and no clue, went to a big empty parking lot, and spent about 30 minutes trying different maneuvers. Aiming for tough parking spots, parallel parking, etc. That's pretty much all it took to master it.
    honda50r, wilcam47 and JimboAnz like this.
  15. Jan 2, 2018 at 7:56 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    I don't think it's crazy to have a front hitch, it's pretty useful to have. But in this case you need to practice. You'll eventually need to know how to back up if you're going to tow a trailer.
    PvilleJohn likes this.
  16. Jan 2, 2018 at 7:56 AM
    JGO
    JGO Well-Known Member
    South Central Kentucky
    '14, 4 Cyl, A/T, Silver A/C
    I am the world's worst reverse driver. I put a front hitch on my old Nissan Frontier and never regretted it. I haven't done it yet with the Tacoma but come summer, I'll probably do it.
  17. Jan 5, 2018 at 7:11 PM
    lock
    lock Well-Known Member
    greg
    N.W.OHIO
    tacoma
    Too late with this rig but the farther back your trailer axles the easier to back.
    Also if you are using a ball on the bumper install a hitch, just moving the ball eight inches further back makes a noticeable difference.
    A longer trailer tongue is easier. Ever notice how much more difficult it is to back a small trailer.
  18. Jan 5, 2018 at 7:20 PM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    A front hitch is actually harder to deal with since the pivot point between the truck and trailer is so much closer to the steering axle that the trailer will tend to change directions MUCH faster, and you will have more of a tendency to overcontrol . Just practice in an empty lot and take your time, and you'll get it figured out.
  19. Jan 5, 2018 at 7:23 PM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    just grab the bottom of the steering wheel. its how i teach guys in the tow trucks. also find a empty shopping center and go for it. the more you do it the better you'll get.
  20. Jan 5, 2018 at 7:24 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    I can't believe no one has brought up the fact that you are going to be driving into the water face first. That is such a bad idea. What if a rogue wave comes through and floods the intake? What if you have to drive in further to get the boat floating and you flood the intake? Just practice for Christ's sake
