Terrible Fuel Mileage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Erkon, Dec 11, 2015.
  1. Dec 12, 2015 at 9:49 AM
    #41
    Kyle01
    Kyle01 Well-Known Member
    Kyle
    Chicago
    2024 TRD Offroad double cab 6MT
    Maybe we should just talk "miles per tank" rather than trust everyone's math skills. I can't believe how bad some of your mileage is!!
    My DCSB is nearly a year old, just turned 40k (I do a shitload of driving) I have around 3" of lift and have 285 duratracs on stock 16" sport wheels with 1" spacers. Shrockworks rear plate bumper and a softtopper. Always a few hundred lbs of tools in the bed. I usually run 89 octane fuel. 300 miles on a tank is bare minimum, usually around 330 and 350 is the most I've seen. I'm running mobil1 5-30 full syn for last 2 changes (dealer serviced to 30k) and haven't touched the plugs or changed diff oils. Oh, I've got a TRD washable air filter.
  2. Dec 12, 2015 at 10:15 AM
    #42
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    Worst was towing maxed out 304 Miles / tank
    Best was 440 Miles / tank
  3. Dec 12, 2015 at 10:20 AM
    #43
    Kyle01
    Kyle
    Chicago
    440?!? That's infuckincredible.
    Tarzan13 likes this.
  4. Dec 12, 2015 at 10:37 AM
    #44
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Increase tire pressure.
  5. Dec 12, 2015 at 10:41 AM
    #45
    Kyle01
    Kyle
    Chicago
    I've run 32(ish) psi and went up to ~36 and I don't notice a difference.
    Now, if you're willing to put up with the punishment at max inflation- maybe you'd see a small bump.
    I never complain about mileage... Light goes on, more gas goes in. Complaining does little to change this fact!
  6. Dec 12, 2015 at 10:43 AM
    #46
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    My 15' DCSB 4x4 regularly gets 310-320 before fuel light comes on,and that's city driving. Best highway was 369,I know it would've went 400. Filled it up and put 18 gallons in it. Now that was driving 2 lanes at about 62mph,bout 55miles one way.
  7. Dec 12, 2015 at 10:45 AM
    #47
    Kyle01
    Kyle
    Chicago
    I'm sure much better mileage can be attained at a steady 55-60mph with minimal starts/stops. Just never happens in my world.
  8. Dec 12, 2015 at 10:46 AM
    #48
    Crodliner
    Crodliner Well-Known Member
    DFW
    Isn't that closer to 16-17mpg?
  9. Dec 12, 2015 at 1:11 PM
    #49
    kingk0ng
    kingk0ng Well-Known Member
    11 TRD OR AC
    just a few things.
    I get around 14 in NorCal city driving on 2 in lift and ko2 only around 250 to the tank
  10. Dec 12, 2015 at 2:40 PM
    #50
    Erkon
    Erkon [OP] Well-Known Member
    Wisconsin
    2012 Pyrite Mica Tacoma TRD Supercharged
    I just switched my engine oil to synthetic today and plan to do the diffs as well. I need to do some more research on what to use for diffs. Also need to figure out for sure that I don't need to add a modifier to the rear diff.
  11. Dec 12, 2015 at 3:34 PM
    #51
    libagui
    libagui Well-Known Member
    Dominican Republic
    05 tacoma prerunner
    Bilsteins 5100 set at .085 Rear custom 1" add a leaf 265/70 R17 tires. Custom made aluminum tonneau cover with bike rack. 4x4 conversion with 4Runner transfer case.
    12 mpg city driving
    15 mpg combined
    19 mpg highway (@ no more than 55mph).
    Those are my numbers
  12. Dec 12, 2015 at 3:41 PM
    #52
    12TRDTacoma
    Rob
    Concordia
    Boosted
    350 miles divided by 17 gallons I normally fill up with.
  13. Dec 12, 2015 at 3:44 PM
    #53
    723rdCAT
    723rdCAT Well-Known Member
    Kentucky
    15 SR5 4x4 access cab mgm
    Indeed. I dont see how a driver is getting 20 MPG with a super charger and not driving in a manner that is focused on extreme efficiency. I have no super charger and have a fairly light foot(typically cruising around 60~68) I accelerate and decelerate evenly and the best I have seen is just over 20. I have had 245 Firestone A/T for about three tanks now I average 19MPG.
    I think many people either do the math wrong or they look at the best most outstanding MPG they ever figured and just say that is the average when in fact it was the exception.
    I would try running a little higher PSI in your tires. Higher will get you better MPG but the ride will be more firm which I am fine with it is a truck. Just dont exceed the tire max pressure printed on the tire. So do that with an ambient tire(cold)
  14. Dec 12, 2015 at 6:43 PM
    #54
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    Hrmmm, sounds worth trying. With PSI that high how is the tire ware?
    -- edit --
    Was reading some of the other posts. Never really considered the weight issue. I am 200lbs, with installed mods I know I have an additional 300-400lbs on board, plus whatever tools or whatever I have in the bed.
  15. Dec 12, 2015 at 6:51 PM
    #55
    ElBlancoTaco
    ElBlancoTaco Well-Known Member
    Ron
    Scottsdale, AZ
    2014 SR5 DCSB 4x4
    I'm about 70% highway per tank, but my Waze has me running about 75mph on good days and barely moving on bad days. My worst tanks average low 18's, my best tanks are right at 21. All stock, about 24k miles, 4x4, topper.
  16. Dec 12, 2015 at 6:53 PM
    #56
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    LOL! Never thought anyone else paid any attention to when the light comes on. 17 gallons! (burned)
    12TRDTacoma[QUOTED] likes this.
  17. Dec 12, 2015 at 6:57 PM
    #57
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I've just owned the truck long enough to know the numbers on it is all. :) :thumbsup:
    By the time that light turns on, I believe you have approximately 3 gallons remaining in your fuel tank. I wouldn't run the truck with any less than 1 gallon regularly and expect the fuel pump to live a long life. Especially with those tiny little Denso pumps that are in our fuel tank bucket assembly. Those things are pathetically small.
  18. Dec 12, 2015 at 7:00 PM
    #58
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    I got 23.4 driving 55-60 down I-81 through MD, WV, and VA.
    Ordinarily suburban driving gets me 16-17 in the winter, 18-19 in the summer.
    If I drive over 70-75 on the highway, I'll get about 14.
  19. Dec 12, 2015 at 7:01 PM
    #59
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    This is from a post I made a few years back. I kept a mileage record on a new 2010 Tacoma from the 1st tank of gas to the 90th tank. Here you can see how the winter blend affects gas mileage. The general trough between tanks 25 and 45 were during the winter months.
    2010 V6 double cab 4x4
  20. Dec 12, 2015 at 7:04 PM
    #60
    js312
    Joe
    New England
    What, exactly, constitutes a "tank"? That introduces a lot of variables.
    The math isn't hard, miles divided by gallons.
    12TRDTacoma likes this.
