Terrible Gas Mileage on Brand New 4-cylinder Automatic
Discussion in '4 Cylinder' started by rgardine2000, Jun 5, 2013.
  1. Mar 27, 2014 at 1:55 PM
    #81
    2TFERDCSB
    2TFERDCSB New Member
    I have a 2013 DCSB 2.7 PreRunner. My first tank of gas was a trip to Tahoe which is a lot of hilly driving though it is all highway, when I got home from the weekend my average MPG was 27. My average tanks are 22-23 MPG. 27 MPG is my high so far, but I haven't spent a whole tank driving on the highway since then, and on that 27 MPG trip I was pretty much staying at 55 or 60 MPH the entire trip and accelerating like I just drove it off of the lot, which I did.
    I don't drive like a grandpa now and have 11k miles. My mileage is consistently in the 22-23 MPG zone, though.
  2. Feb 12, 2017 at 7:17 AM
    #82
    coach107
    coach107 New Member
    I have a 2013 Toyota Tacoma Pre runner Double Cab SR5 4 cylinder. Very disappointed with gas mileage. I bought this truck used with 30,000 miles. It was well taken care and have all service records. Truck is getting 14mpg city and 15.5 on hwy. If I had known this I would have never purchased this truck...would have gotten 6 cylinder.
  3. Feb 12, 2017 at 7:49 AM
    #83
    t3mpo
    t3mpo Well-Known Member
    Jose
    2016 Tacoma SR
    Does it have any modifications? Have you checked your intake air filter? Maybe you need a tune up.
  4. Feb 12, 2017 at 10:52 AM
    #84
    coach107
    coach107 New Member
    Toyota Local Dealership checked it all out....found no issue. I mean a 4cylinder getting 14-16 MPG.....thats pitiful. The only thing I can think of is the little 4 cylinder has zero ass and the Double Cab is a heavy little truck....that engine must have to work overload ???
  5. Feb 12, 2017 at 10:58 AM
    #85
    t3mpo
    Jose
    2016 Tacoma SR
    Mines a double and I get over 27 mpg all the time. The double cab is about 110 lbs heavier than the single btw. hopefully some of the more mechanically inclined guys here will help eventually. It's odd with 30k miles that you're having that problem. I would think try to add some fuel injector cleaner in your next refuel and check your fluids yourself. Check your filter and all the little things you can. Other than your fuel mileage do you feel any other problems?
  6. Feb 12, 2017 at 11:09 AM
    #86
    coach107
    coach107 New Member
    Thanks alot for the advice....I will try the fuel injector cleaner and let you know if this works.
    t3mpo likes this.
  7. Feb 12, 2017 at 1:12 PM
    #87
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    What weight engine oil are you running?
    t3mpo likes this.
  8. Feb 15, 2017 at 8:55 AM
    #88
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    Mine has 19,400 miles as of this morning. I have gotten the same mileage (17-20) since it was new. It only goes down to 17 when im on the hiway because our speed limit here is 75. I like to run 80 and the little motor has a hard time keeping that speed without downshifting on even the slightest incline. So my bad mileage portion is caused by me. I can baby it and get 20.
  9. Feb 15, 2017 at 9:10 AM
    #89
    t3mpo
    Jose
    2016 Tacoma SR
    Lce header with a drop in afe dry filter will do wonders for both
  10. Feb 15, 2017 at 9:54 AM
    #90
    bkinatacoma
    bkinatacoma Well-Known Member
    Jeff
    My 4 cents... Similar truck as Coach but non SR5 and purchased mine with 50K miles - and she was babied by original owner. Average 19 miles/gallon with 95% being highway miles. Right at 100 miles/day driven and I do not baby her at all - pushing 80 most of the way on tollways. She's a Tacoma and doesn't need babying. 14 miles/gal sounds very odd. I have no suggestions just giving you a background on a 13 double cab 4 banger with decent miles/gallon.
  11. Feb 21, 2017 at 2:34 PM
    #91
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    So, so many variables, such as... ethanol in gas (or not)... startup temperature and warm up times... mods... tire sizes and pressures... how many pounds of extras you are hauling around unnecessarily... too many to list.
    The most influential variable of all is your driving habits. As others have said, jackrabbit starts and high cruising speeds will kill your fuel economy. Remember these trucks are not very aerodynamic. (The Corvette is very low and slick and gets 28mpg cruising 80mph no problem hehe)
    Dirty air filters in fuel injected engines will kill power not fuel economy. The computer monitors airflow and less airflow gets less fuel, so the mix is carefully controlled. Carbureted engines are another story.
    t3mpo likes this.
  12. Feb 21, 2017 at 2:38 PM
    #92
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    23.89 mpg today,Costco regular gas
