Terrible headrests...solutions?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JKD, Aug 2, 2009.
  1. Aug 2, 2009 at 1:18 PM
    JKD
    JKD [OP] Well-Known Member
    My wife is 5'3", and the factory seat and headrest combination can not be adjusted to suit her at all. The headrest juts forward (?) so damn far that it jams her head forward, and adjusting it upward just makes it worse.
    I figure we have two options. One, we need a seat pad that will go in the upper back area, giving her shoulders support and moving her forward in the seat so the headrest position relative to her body is more comfortable.
    Two, we could have an upholstery shop modify some factory headrests to fit better. Basically, they would need to be modified to angle back (closer to in-line with the seat back) and probably have at least a section of the headrest made of a somewhat softer foam.
    I'm over 6' tall and my shoulders are higher than the seatback tops, so the headrest position is not a problem for me. Whatever we do, whether it is a seat pad or a remade headrest, we would want it to be swappable between seats without too much trouble.
    Has anyone else here found a solution that works?
  2. Aug 2, 2009 at 1:23 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    Can you just take the head rest off on the passenger side? For a long time I didn't think I could, but I found that squished down in the top of the seat there is a button that releases the head rest.
  3. Aug 2, 2009 at 1:25 PM
    JKD
    Yes, but then you have absolutely no mechanical control of head movement in an accident. You have a far, far higher chance of injuries that way.
  4. Aug 2, 2009 at 1:31 PM
    JKD
    That's why I'm looking for a solution, of course. It's not a one or the other issue. Plenty of vehicles have seat back and headrest combinations that don't hurt my wife's neck, I just need to find or make a cushion or modified headrest that will work on my Tacoma.
  5. Aug 2, 2009 at 1:35 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    I'm gonna catch hell for this..:devil:
    Get yourself a taller wife?:rofl:
  6. Aug 2, 2009 at 1:42 PM
    JKD
    Wife is perfect size, thank you. :)
  7. Aug 2, 2009 at 1:46 PM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2015 TRD Sport
    Clazzio Seat Covers Extang Tri-Fold Soft Tonneau Cover TRD Skid Plate AMP Research Electric Steps 43% Llumar Security tint TRD Exhaust Fox 2.0 coilovers and rear shocks 16" TRD Fake Beadlocks Custom LED Cube mounts in foglight location TRD Pro Grill Wheelers progressive aal
    I would just get another set of headrest on ebay and modify them like you said so, taking it off and putting the other takes just a minute.
  8. Aug 2, 2009 at 1:51 PM
    Tacoyota
    08 4wd
    Sorry, couldnt stop myself. Would it work if you placed the bars behind the seat , still not as safe as with them in the seat though.
    Or, could you get a car model that fits, some have a tilt i think, sort of the head rest mod.
  9. Aug 2, 2009 at 1:56 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    I like short chicks too ;)
  10. Aug 2, 2009 at 2:00 PM
    TacoBelle
    TacoBelle Well-Known Member
    Silver PreRunner SR5 Stock
    I just swap the front headrest with the rear passenger headrest and problem is solved.
    You can also reverse the front headrest but it looks goofy..comfortable but goofy.
  11. Aug 2, 2009 at 2:19 PM
    JKD
    Whether it's been done before or not, this is a fixable problem. I'm just hoping to run into people who have had, and fixed, the problem already.
    Always do your background research first!
  12. Aug 2, 2009 at 2:20 PM
    JKD
    I see you have a double cab (I have an access cab). I haven't taken a good look at the double cab rear headrests yet.
  13. Aug 2, 2009 at 2:26 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    I'm not short (5' 8") and the front head rest doesn't work for me.... makes me hunch over all the time. I turned my head rest backwards and works great. Like some one said looks goofy, but it's better for me.
    Good luck finding a solution.
  14. Aug 2, 2009 at 2:52 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Unfortunately, if you're short you're screwed when it comes to the new active head restraints they're are putting on new cars nowadays.
    I worked out a deal for my mom on an '09 Subaru Impreza Hatchback. At first she had a tough time getting comfortable. There were a couple of options. We messed around with seat adjustment. Another thing we did was raise the headrest so that where her head hit it was lower on the headrest since it tilts forward. Another option was to order headrests from the previous year. And finally if all else failed I offered to put a slight bend in the headrest posts for her if she couldn't get comfortable.
    The one thing you don't want to do is remove the headrest. At least have something there even if you have to turn them around. My mom is 5' and shrinking and luckily we were able to make something work.
    Personally, it hasn't been an issue for me in either my Accord or Tacoma but alot of vertically challenged Accord owners complained about the same thing.
  15. Aug 2, 2009 at 3:31 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Phone book?
  16. Aug 2, 2009 at 3:53 PM
    URBIKESUCKS
    URBIKESUCKS Well-Known Member
    Ron
    Prescott AZ
    2014 DCSB TRD OFF ROAD 8speed auto from a lexus
    Habitat
    You could get a gel pad and raise her up a bit...
  17. Aug 2, 2009 at 3:56 PM
    Tacoyota
    08 4wd
    I'm 5'11", the seat seems a little sunken to me, i have a bench btw.
  18. Aug 2, 2009 at 5:25 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    X2. Seats definately are sunken. For a sport seat, it is not very sporty. And that crappy thing they call lumbar? I mean, I know that the Tacoma is not a car. But if ful sizes have these nice seats and cars costing 30K have nice seats.. What's up with the Taco's? We don't like to be comfy?
  19. Aug 2, 2009 at 5:29 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    ^Did you test drive your truck before you bought it?
  20. Aug 2, 2009 at 5:42 PM
    Tacoyota
    08 4wd
    My bensch isnt that bad , since i can drive 4 hours in it non stop hehe, but a little bit of adjustability woulda been nice... and btw I wonder if the center rest fits the outer rests, it smaller
