Terrible MPG and sometimes hard starts
Discussion in '1st Gen. Tacomas (1995-2004)' started by misteroldschool, Jan 4, 2023.
  1. Jan 4, 2023 at 10:12 AM
    misteroldschool
    misteroldschool [OP] Well-Known Member
    98 4x4 2.7l
    Wise dudes and dudettes of this forum I need your assistance!
    1998 3rzfe 4x4
    Is it normal to get about 230-250 miles per fill-up? 14-17mpg? Seems low to me. Mostly city driving but even cruising at 65-70 I'm getting 17 tops.
    Also about 1/10 times that I go to start the truck it'll struggle and if I don't press the gas pedal down (like you would on an old carbureted car) it'll just crank for a while until it starts. Looked around for vacuum leaks and replaced a couple suspicious vacuum lines, checked all the VSV's and they all click when given 12v, still does the same thing.
    -oldschool
  2. Jan 4, 2023 at 10:18 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    You live in Italy?
  3. Jan 4, 2023 at 12:21 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    17 would be wonderful
    Probably need to clean or replace your IAC
    TForan likes this.
  4. Jan 4, 2023 at 9:41 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    How old are the injectors.....
    .....a leaking injector causes floods....
    and inefficient spray would cause fuel consumption....
  5. Jan 4, 2023 at 9:43 PM
    O'Silver_Taco
    MD
    Stuck or bad egr valve would cause similar issues.......
    and charcoal evac system is pretty important......there's two valves there.....and the egr control module itself.....
  6. Jan 4, 2023 at 10:07 PM
    YotaGangYotaGang
    YotaGangYotaGang PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
    manual or auto? What is your tire size? Lifted? What are you hauling? City or hwy driver or both? I would start simple, air filter, maf cleaned, pcv valve changed, 5w30 oil, check trans oil, clean iacv and tb. I have a 97 reg cab 4x4 auto 3rz and I get 15mpg, 16 if all hwy. Thats normal. If you idle the truck a lot youll get worse mileage. Imo a lot of the people that think ther taco should be getting 30mpg is from the guys in the 8”’s saying ther pickup got 30mpg, well yeah they could get that high cus it was a smaller motor and a manual and a vehicle that was lower and weighed less. Now theyre more powerfull and gas hungry.
  7. Jan 5, 2023 at 8:52 AM
    misteroldschool
    98 4x4 2.7l
    Truck is manual, tire diameter is factory but they are wider than factory, lifted an inch or two. From the replies sounds like the mpg I'm getting is accurate :,) Thanks everyone.
    For the hard starting issue I'll check all that you guys have suggested and hopefully it'll be one of those things. I cleaned the IAC not that long ago and verified it was working, cleaned TB as well, I haven't checked the EGR/charcoal evac system yet but there's no codes so... hopefully they're good? Ordering a new PCV and grommet as I've never checked on that before and its loose.
  8. Jan 5, 2023 at 8:54 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I have the exact same truck in the same spec as you, I’m happy to get 13 MPG haha.
  9. Jan 5, 2023 at 4:19 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    Manual 3rz on stock size tires should do better than that for mpg, unless it’s got some funky ass tall gears or you’re doing 80-90 on the highway. I get 18-19 out of my 97 mixed driving on 35” tires, yes that’s corrected for the tires, and I was regularly over 20 mpg on 33” tires. I’d say something is a miss, especially with the starting issue.
    ztwatson likes this.
  10. Jan 6, 2023 at 9:48 AM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    Yeah. Your 4 cylinder should get better than 13. You should be above 17 based off of what you've said. MPG is always worst in winter, but you might be in Arizona for all I know.
