Terrible MPG
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rescuetech53, Nov 15, 2013.
  1. Dec 30, 2013 at 12:54 PM
    #141
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    Don't get me wrong, if it is snowing or your windows keep fogging up you have to leave your defroster on and running to keep your windshield clear. But if you just have frost on your windshield in the morning run the defroster long enough to clear the windshield then turn the heat on the floor. Some people turn their defroster on low in the fall and leave it that way until spring.
  2. Dec 30, 2013 at 3:50 PM
    #142
    TRD Toy85
    TRD Toy85 Well-Known Member
    CT
    loaded 2013 TRD sport
    Cruise makes a huge differance , I plan on getting a scan gauge to when I have some extra cash . It realy helps make you more aware and mindful of your consumption .
    My 2013 dbl 4.0 cab 4x4 was getting about 15-16 avg , now with 4k on it , bigger tires an alittle lift I'm getting about 17 , was actually 17.9 last tank but I think I must of done more highway driving then normal .
  3. Dec 30, 2013 at 7:32 PM
    #143
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Yup.
    Every vehicle I've had that's been built since 1988 has done it except for my '94 Toyota pickup.
  4. Jan 1, 2014 at 4:09 AM
    #144
    TheMuffinMan
    TheMuffinMan Banana Nut
    Coeur d'Alene, ID
    2023 Tundra Limited Crewmax 6.5' 4x4
    I've only had my truck for a short time but with the 6spd I'm getting about 17.4 average sometimes down to 15 with 4hi enabled; with suburban driving, stock SR5 package and 30-40 degree temps when I drive into work at night.
    With my last vehicle an early model Audi A4 2.0 Turbo in the winter my MPG would routinely drop by ~15% (From 28 avg to 24 avg, commuting around town) when the winter blended gas and colder temps came around.
    I have my motorcycle that gets 50-55mpg, when riding like I stole it, for the spring through fall though which pretty much offsets fuel for the three months that I'll drive the truck extensively in the winter.
