Terrible noise from OME/Bilstein/SPC setup
Discussion in 'Suspension' started by RPain, Jan 11, 2017.
  1. Jan 11, 2017 at 7:22 PM
    RPain
    RPain [OP] Well-Known Member
    Chandler, Arizona
    2016 Tacoma DCSB 4x4 TRD Sport
    Link to build in sig
    SOLVED: After putting some super lube between the washers and bushings on the UCA's the sound has almost completely disappeared.
    Been dealing with a terrible creaking/clunking sound coming from my front suspension. Here is a video of what it sounds like going over a speed bump and also some pictures of the setup. While I was looking at the pics I noticed the sway bar looks like it may be getting rubbed on by the coil springs. Would that result in a sound like this?
    All suggestions welcome, please disregard the salt all up in my wheel wells.
    Link to video:
    https://goo.gl/photos/8qs6s9V8awMU2ytw9
  2. Jan 11, 2017 at 8:23 PM
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    Swaybar. 4 bolts and 2 nuts to pull it and confirm.
    Dalandser and EDDO like this.
  3. Jan 14, 2017 at 12:15 PM
    Ryandr91
    Ryandr91 Well-Known Member
    Corpus Christi, TX
    2018 Cavalry Blue Pro
    Was it the swaybar after all?
  4. Jan 14, 2017 at 11:45 PM
    AZ2013
    AZ2013 Well-Known Member
    Blake
    '13 Spruce Mica DCSB TRD OR
    @snowtank this isn't my video but this is the exact sound I'm dealing with.
    snowtank likes this.
  5. Jan 15, 2017 at 3:14 AM
    snowtank
    snowtank Where the fuck did my beer go!
    Andrew
    Arizona
    11 txpro dcsb 08 trd sprt dcsb
    Some stuff here and there....
    Hum. That's weird. And we pulled your sway bar off right?
  6. Jan 15, 2017 at 3:29 AM
    AZ2013
    Blake
    We did but I put it back on about a month later. I'll have to pull it off again real quick and see if that fixes it.
  7. Jan 15, 2017 at 4:01 AM
    snowtank
    Andrew
    Arizona
    Oh. Yeah pull it and see. If that's not it is don't know. I would have to hear it in person to really diagnose where it's coming from
  8. Jan 15, 2017 at 1:51 PM
    AZ2013
    Blake
    Not the sway bar. It's got to be the UCA's. Is it safe to loosen the bolts a little while under load? Thinking maybe I'll get some spray lube and see if I c an get enough in there without having to remove them completely.
  9. Jan 15, 2017 at 2:12 PM
    snowtank
    Andrew
    Arizona
    Yeah you can do that under load just don't remove the bolt
  10. Jan 15, 2017 at 2:13 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Do you have OME shocks or 5100's ?
  11. Jan 15, 2017 at 2:15 PM
    snowtank
    Andrew
    Arizona
    Icons
  12. Jan 15, 2017 at 2:20 PM
    OZ-T
    Peter North
    British Columbia
    There goes that theory
    ecgreen and AZ2013 like this.
  13. Jan 15, 2017 at 2:21 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    I got the exact set up and have the same issue. Mine is on the passenger side. It's annoying and thing I'm gunna get ome shocks. I found that the rubber washer on the driver is smashed down and the passenger is loose so I think when the shock goes up it moves.
    Who did your install?
  14. Jan 15, 2017 at 2:21 PM
    snowtank
    Andrew
    Arizona
    Haha yep
    AZ2013 likes this.
  15. Jan 15, 2017 at 2:26 PM
    AZ2013
    Blake
    Icon. I've had the lift on since March of last year and the noise started about a month ago. It was very random at first but in the last week or so it's progressed to that horribly obnoxious level. I think it might be the big steel washers sliding/rotating against the spec ride bushing.
  16. Jan 15, 2017 at 2:27 PM
    AZ2013
    Blake
    A handful of us guys from TW did the install. I know everything was installed correctly.
  17. Jan 15, 2017 at 2:40 PM
    Blackshirts
    TX
    Stuff
    Yeah same with mine.
    It's like my driver side was set in right but the passenger is not. It looks right and everything is torqued down but I can spin the rubber washer. Soooo I know that's were the noise is coming from. I've sprayed some lube and it went away but week later it was back.
  18. Jan 15, 2017 at 5:48 PM
    RPain
    Chandler, Arizona
    Just got the sway bar relocate bracket, going to install it tomorrow to see if that fixes it.
  19. Jan 16, 2017 at 2:15 PM
    AZ2013
    Blake
    You certainly need that drop bracket to help with clearance but I doubt that's your problem with the sound. I just fixed mine. It was just as I thought. The washers were binding up against the bushings. As the arms articulated, it would spin the washers which rubbed so hard against the bushings it made the sound. Take the nut off and tap the bolt slightly out to free up the opposite side washer. Clean them up and grease the shit out of them. Put it back together and torque the nut to 85 foot pounds. My noise was 20 times worse than yours and it's gone now.
  20. Jan 16, 2017 at 2:36 PM
    RPain
    Chandler, Arizona
    Good to know! Thanks for the info. From snowtanks' post above looks like I should be safe to do that under load correct?
    And just to make sure, this is the bolt and washers you are referring to? (pic stolen from your build thread :D )
