Terrible rattle after brand new Old Man Emu leafs put on
Discussion in '1st Gen. Tacomas (1995-2004)' started by Beeson, Sep 24, 2010.
  1. Sep 24, 2010 at 9:41 AM
    Beeson
    Beeson [OP] Well-Known Member
    Seattle
    '96 Tacoma SR5 4x4
    33" Goodyear Wrangler Duratracs, 15" Unique Steelie rims, Allpro wheel spacers, Heavy Old Man Emu coils, struts, shocks, leaf springs, Daystar 1" spacer, Camburg UCAs, 1" diff drop, NO sway bar, Allpro sliders, Allpro Rear bumper, Bushwacker fender flares, Tire Gate with spare, ARB Deluxe bumper with Hella 700s and 100w bulbs, 100w lights under frame pointed at tires, 50w lights on bumper for reverse, K&N Drycharger with cover, Flowmaster cat-back with custom 2-out exhast, DeeZee tool box, Huskey Liners, 5% window tint, JVC iPhone/CB compatable deck, Bazooka sub, sony speakers, Uniden CB w/4 ft. anntenna, Dixie Horn.
    So, I just finally got the correct dakar leaf springs on my truck (4 wheel parts had originally put ones on that were too long, and they were pretty stiff, now they are not stiff and feel as though they should be just right). These things are now the same size as stock, but now all of a sudden I have this pretty bad, disconcerting shake between about 10 and 25 mph and then again at 50-55 mph. I his not the engine or tanny or anything, this happens whether the gears are engaged or if I'm in neutral. It happened only after these springs got put on and it's pretty bad, the whole dash rattles and it's crazy loud. Before I call these guys AGAIN, any ideas?
  2. Sep 24, 2010 at 9:43 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Carrier bearing.
  3. Sep 24, 2010 at 9:44 AM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    x2 check out beefed tacos carrier bearing drop
  4. Sep 24, 2010 at 9:46 AM
    Beeson
    Seattle
    '96 Tacoma SR5 4x4
    Wow, yes. Give that man a cigar.
  5. Sep 24, 2010 at 9:50 AM
    Beeson
    Seattle
    '96 Tacoma SR5 4x4
    Well it actually would be slight lowered with springs that aren't so tight (which kind of sucks, but oh well), so a drop isn't the problem, I need to get under there and raise it or flip it.
