TERRIBLE SHAKE 55+MPH
Discussion in '1st Gen. Tacomas (1995-2004)' started by TACO3, Oct 3, 2012.
  1. Oct 3, 2012 at 11:42 AM
    TACO3
    TACO3 [OP] Deer Dropper
    Aaron
    VA
    03 tacoma 4wd 4 banger
    ok i know there are threads on this but not exactly.... ever since i had the 305 stt's ive had a little vib, no big deal.. well it had gotten worse and a few days ago i took my truck to get the tires/wheels balanced and rotated. Now the 2 on the back are at about 30% tread an the 2 front are about 60%. they balanced them with the weighted bead bags inside and i hit the road at about 45, stupid thing about jerked the steering wheel outta my hand, so i took it back and they said i needed a driveshaft carrier bearing..ok.. check.. they also said the 2 tires with 30% tread were outta round and they put those back on the rear... ok... 0-45 mph.. everythings smooth and dandy BUT i get to about 55mph+ and the whole cab, floor, steering wheel is shaking vigorously... idk if its just the tires? or what??
    any input? thanks guys
  2. Oct 3, 2012 at 11:45 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Sounds like a balance issue... Take it to another shop to get balanced.
  3. Oct 3, 2012 at 11:46 AM
    TACO3
    Aaron
    VA
    thats what im thinkin but idk how its riding so smooth at lower speeds
  4. Oct 3, 2012 at 11:49 AM
    krimson
    krimson Nothin
    TRD Off Road
    Well when A tire isn't balanced properly it will tend to wobble at higher speeds because they aren't balanced... So the more momentum A unbalanced tire gets the more it will cause it to shake.
  5. Oct 3, 2012 at 11:50 AM
    TACO3
    Aaron
    VA
    do you think it could be cuz the tires outta round?
  6. Oct 3, 2012 at 11:54 AM
    krimson
    krimson Nothin
    TRD Off Road
    Or could be the tires themselves causing the issue. You say the tread is 60% and 30% left. Why the uneven tire wear? Alignment issues? Or just never rotated them?
  7. Oct 3, 2012 at 11:55 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What weighted bead bags are you referring to?
    Did they put enough in?
    I have experience using EQUAL tire balancing compound on my old Jeep & 35's. That stuff worked awesome even at 70mph. BUT - the shop had to put the right amount in or it won't work properly.
    I would try another shop for a second oppinion.
  8. Oct 3, 2012 at 11:55 AM
    TACO3
    Aaron
    VA
    no alignment issue.. i didnt buy them brand new bought them while back they werent wore the same then. they arent uneven just hadnt been rotated
  9. Oct 3, 2012 at 11:56 AM
    TACO3
    Aaron
    VA
    and i may just grow a pair and buy a new pair :D
  10. Oct 3, 2012 at 12:27 PM
    BamaToy1997
    Bill
    Navarre, FL
    Any reputable tire shop you ask will tell you that tire vibration is the most severe between 55 and 60 MPS. This is considered (if I remember correctly) a third-order vibration, and will build up the most at those speeds. I would look at taking it to a different tire shop. Find one that performs a "Road Force" measurement that is a better, and more accurate method of testing balance. A Road Force balancer will also be able to tell you if there are any issues with rims, or tire matching. I have taken a 33 inch that caused a pretty significant vibration at 55, and after a Road Force test was able to reposition the tire on the rim and have the vibration nearly disappear completely.
  11. Oct 3, 2012 at 12:46 PM
    TACO3
    Aaron
    VA
    it took me 10 mins to read your post.. i was distracted lol
  12. Oct 3, 2012 at 5:33 PM
    BamaToy1997
    Bill
    Navarre, FL
    Glad that I could be of help.
  13. Oct 3, 2012 at 11:17 PM
    austinramsay
    austinramsay Well-Known Member
    Austin
    Yuma, Arizona
    2001 Tacoma TRD Doublecab
    Its the classic jeep death wobble :eek:
  14. Oct 4, 2012 at 12:47 PM
    TACO3
    Aaron
    VA
    are you talkin about my truck problem or bamatoys signature ;)
  15. Oct 4, 2012 at 1:13 PM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    BamaToy - are we getting a glimpse of the right nipple there, or just a little bra action? Hard to tell and it makes a difference.
  16. Oct 8, 2012 at 7:40 AM
    BamaToy1997
    Bill
    Navarre, FL
    It's just a bra showing. The YouTube video is much longer and you can tell better on it.
  17. Oct 8, 2012 at 7:52 AM
    NWTacoGuy
    NWTacoGuy Well-Known Member
    James
    Pacific North West
    2010 TRD Off Road DCSB
    Fabtech 6", xd addicts/35x11.50 Nitto Terra Grapplers, Black badges, Pioneer HU, 11' grille, ect ect ect....
    I couldn't even get through the damn thing...I literally gave up!! :D
  18. Oct 8, 2012 at 11:36 AM
    Zaint
    Zaint My Taco Eats Me
    STL, MO
    Tacoma, Black
    OP, I recently had a similar issue. I bought some steel pressed rims that weren't completely round. They would shake at 25 slightly, then 40-50 slightly, then a lot after 55mph. After about 5 mos. and 3 different shops and 400$ in balancing bs, I replaced the rims with alloy cast styles. The vibration was still slightly there, but not as bad. It was the tires that were completely worn incorrectly due to the steel rims being out of round.
    I was still worried that nothing was fixed because the vibrations were happening around the same mph, but I just drove through the vibrations, which were intermitent at times varrying from severe to minor.
    Now after about 600 miles the severe vibration is minimal at best if even at all. There is a drivetrain vibration from my driveshaft, but that is very little and was there on the stock rims.
    Bottom line, when dealing with a vibration or unbalance issue, it can ensue a list of issues that when the balance is fixed, could still remain. If you already know your tires are all worn different, that could have a massive impact on how your truck rides considering one's tire size.
    To test for drivetrain, find someone's stock tires and drive around with those and see if there is a vibration. If nothing vibrates, then put the stockers on the front and big tires on the back and drive around a little and see if you suddenly feel the vibration. Rotate your big tires around on the back until you find the worse of the 4 tires. Once you do that, you can put them on the truck in order from minimal to severe, driver front, passenger front, drive rear, then passenger rear. you want the worst feeling tire on the back passenger. It sounds though like that won't matter with the level of vibration you are getting. You may have to get new tires if the wear is sufficient enough.
    $0.02
  19. Oct 8, 2012 at 12:11 PM
    Tenax
    Tenax Well-Known Member
    Terry
    Alberta
    03 prerunner trd
    17 inch wheels
    What brand of rims were the steelies?
  20. Oct 8, 2012 at 12:41 PM
    TACO671
    TACO671 Member
    SPOKANE
    2002 TACOMA SR5 3.4V6
    I'm having the same problem with my 02 taco with 144K. The steering wheel and front end will start shake at highway speeds. 60- 70mph. I had the center support mount bearing recently replaced and had all 4 tires on stock 16" rims balanced. Shop advise me on doing an alignment, but I'm not sure an alignment will cure this problem.
