terrible stumble
Discussion in '4 Cylinder' started by bsb120, Jan 31, 2015.
  1. Jan 31, 2015 at 7:27 PM
    bsb120
    bsb120 [OP] Well-Known Member
    Bradley
    Easley, South Carolina
    2016 DCLB TRD SPORT
    Ok got a 2000 prerunner 2.7 When taking off from a complete stop the truck hesitates kinda stumbles then catches up and everything is fine. It has just started. The fuel filter was replaced not long ago. Everything seems fine. Every now and again there's a quick pop not real loud almost soubed like a backfire. Possibly a bad spark plug?
  2. Jan 31, 2015 at 7:34 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Installing new plugs would be a good start. Check for dry, brittle or cracked vacuum lines.
  3. Jan 31, 2015 at 7:55 PM
    bsb120
    Bradley
    2016 DCLB TRD SPORT
    well the vacume lines seem fine but, i changed the plugs like a year ago. i just dont understand what it is the exhaust acctually sounds a little raspy and the tail pipe is black inside and out.
  4. Feb 1, 2015 at 1:09 AM
    nickonfire700
    nickonfire700 Reg. Cab Nation Member
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    Satoshi grill, 3rd Gen TRDOR Bucket Seats, TRD front skid plate, TRD Beadlock Wheels, TRD Exhaust, OEM bed mat, LCE Header, LCE Balance Shaft Delete, ECGS front diff bushing, TRD Sport LSD rear diff, Diode Dynamics SS3 Sport fog lights, Stainless Steel Brake-lines, No A/C with Defrost mod, 2014 OEM Radio, Illuminating 4x4 switch, Various LEDs, UWS Toolbox, Proven Design Products Mudflaps, Bilstein 8112 front Coilovers w/ rear Bilstein 5125's/IronMan lift leaf springs, Archive Garage Hammer Hangers, JBAs HD UCAs, SOS Bolt-On rock sliders, TRD bedside decals, ImMrYo Mirror Bracket, Relocated rear diff breather, 2019 Steering wheel, color matched door handles
    Try cleaning the throttle body, and the MAF sensor as well.
  5. Feb 1, 2015 at 5:52 AM
    bsb120
    Bradley
    2016 DCLB TRD SPORT
    Cleaned the maf sensor not long ago as well. But I guess it can hurt to do It again.
  6. Feb 1, 2015 at 5:53 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    you have a misfire...start with a tune up and then start looking for other problems.
    Howard
  7. Feb 1, 2015 at 7:46 AM
    bsb120
    Bradley
    2016 DCLB TRD SPORT
    why is there no check engine light?
  8. Feb 1, 2015 at 8:15 AM
    hetkind
    Howard
    Johnson City
    because it won't give EVERY cause for a misfire...
  9. Feb 1, 2015 at 8:54 AM
    bsb120
    Bradley
    2016 DCLB TRD SPORT
    Hmm well I pulled a plug and its deffinatly running rich. It's black around the bottom but them haven't been in there long
  10. Feb 1, 2015 at 9:07 AM
    hetkind
    Howard
    Johnson City
    it is the correct heat range? are you having terrible gas mileage? is it getting good spark?
    Those would be my first three questions.
    Howard
  11. Feb 1, 2015 at 9:33 AM
    bsb120
    Bradley
    2016 DCLB TRD SPORT
    Heat is fine. Gas mileage has been slowly declining for a while went from 19.7 to 18.8 over the coarse of about 2 months according to the ultra gauge
  12. Feb 1, 2015 at 10:49 AM
    hetkind
    Howard
    Johnson City
    I would look for a failure in the ignition system...does that motor use the individual coil towers?
    Howard
  13. Feb 1, 2015 at 11:38 AM
    bsb120
    Bradley
    2016 DCLB TRD SPORT
    I'm not sure. It's the 2.7 from 2000 just changed the plugs. Cleaned the throttle body I'm waiting on the k&n to wick all the oil it needs then I'll test drive an. Check for improvments
  14. Feb 1, 2015 at 12:16 PM
    hetkind
    Howard
    Johnson City
    oh...I think I just found why your plugs are fouling...how about you put fresh plugs in and try a paper air filter?
    Howard
  15. Feb 1, 2015 at 12:29 PM
    bsb120
    Bradley
    2016 DCLB TRD SPORT
    It's fixed now. But I have had a paper filter. But if had the k&n for probley 2 years with no problem . But it's fixed now
    thanks for all the help guys
  16. Mar 10, 2015 at 6:59 PM
    bsb120
    Bradley
    2016 DCLB TRD SPORT
    and now its back. I have changed to a paper filter again and claned MAF
