Terrible tapping behind glovebox, pls help.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mdean1107, Apr 29, 2023.
  1. Apr 29, 2023 at 3:58 AM
    Mdean1107
    Mdean1107 [OP] Active Member
    Michael
    2007 Tacoma 2.7 L
    New Frame, SnugPro
    When my 07 4 cylinder is on the highway or over 40 mph there is a repetitive rhythmic tapping sound coming from behind the glove box. Unfortunately I cannot troubleshoot and drive at the same time. As the vehicle increases in speed, the tapping increases. Any advice or Intel would be appreciated as I am traveling across the country
  2. Apr 29, 2023 at 4:01 AM
    TacomaUSA
    TacomaUSA Cross Country Tacoma
    PA
    2007 Tacoma TRD Sport 4x4 Access Cab- 6 speed
    Check your cabin air filter for debris. You could have an acorn in there.
    Turn the blower motor on/off and see if that changes the noise.
    Those are easy to check
  3. Apr 29, 2023 at 6:41 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Check the splash guard in the wheel well that goes from the frame rail to the apron (by the shock tower). On mine the plastic pushpin fell out and it was slapping against the frame rail from the wind. It was loud enough to hear inside the cabin
    tak1313 and Dm93 like this.
  4. Apr 29, 2023 at 7:05 AM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    Not my Taco, but my wife's prius briefly had a "ticking/soft knocking" at highway speed. Poked around and one of the MANY plastic shields was loose so at highway speed there was enough turbulence to make it flap rhythmically against the body.
