Terrifying Tire Wear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cam2010taco, Apr 26, 2020.
  1. Apr 26, 2020 at 5:37 PM
    Cam2010taco
    Cam2010taco [OP] IG: Blvcktaco
    Cameron
    Mission Viejo, CA
    2010 4x4 Tacoma
    Every mans nightmare... you regularly rotate your tires on time, you are diligent with keeping correct psi, and you just bought your tires less than a year ago. BUT THEN... returning home from a long road trip, you decide to check your tires and, WHAMMY, you’ve been hit with bfg’s all new racing slick a/t ko2 at a first glance.
    Alrighty now that I’ve gotten my silliness out, what in the world could have caused this problem? I got a rotation before leaving for Montana from California and back l and never saw signs of wear before the trip. I made sure I had 35 psi cold in the tires before leaving and I trekked on. I had just got my last alignment from Solo motorsports when they had worked on my lowers as I am running their long travel +3.5. In the past, the specialist alignment techs I’ve gone to have told me that the tie rod extensions were maxed out so I am assuming this tread wear pattern has something to do with the toe? I’m no alignment guy and I don’t know how toe affects tread wear but I’m assuming that the tie rod extensions are much too short, or long, causing my toe to be off cause I can’t think of anything else and now I need new tires (perfect time to get falkens again). The wear is also significant from about the middle of the tire all the way to the inside as it gradually gets worse but it’s really hard to capture on camera. Also the wear is much worse than it looks. Havent washed the truck yet sorry!!
    461CF87D-2C4A-45A5-9321-E448E5B16C91.jpg 20AAF786-839C-485C-9F7C-1C7E691DD80C.jpg
    also wanted to say that my tires did have correct pressure even after the wear occurred!
  2. Apr 26, 2020 at 5:39 PM
    lynyrd3
    Bill
    East Central Upstate NY
  3. Apr 26, 2020 at 5:39 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    My only guess would be too much toe out or some serious negative camber. I'd take it back to the original alignment shop immediately.
  4. Apr 26, 2020 at 5:39 PM
    Cam2010taco
    Cameron
    Mission Viejo, CA
    2010 4x4 Tacoma
    Exactly my reaction lol I was butt puckering all the way from bishop to Orange County
    lynyrd3[QUOTED] likes this.
  5. Apr 26, 2020 at 5:40 PM
    ZekeR7
    ZekeR7 Well-Known Member
    2018 TRD Off-Road 4x4 Quicksand
    Curious as well as that is where all my tire wear is normally at. Not that sever, but it does show uneven wear after 10k or so. I don't have extended travel yet (its being shipped), so wonder why that is happening.
  6. Apr 26, 2020 at 5:40 PM
    Cam2010taco
    Cameron
    Mission Viejo, CA
    2010 4x4 Tacoma
    I’m gonna email solo about it probably cause it has to be something with the toe rods right? I mean if you look there’s no adjustment room at all on those
  7. Apr 26, 2020 at 5:41 PM
    mhshark
    mhshark Well-Known Member
    Bend, Or
    Dang dude my condolences that sucks. You just noticed this though? Seems like it would take at least 2 months or so for this type of wear
    Biscuits, BlackGT99, tacoma2g and 2 others like this.
  8. Apr 26, 2020 at 5:42 PM
    Cam2010taco
    Cameron
    Mission Viejo, CA
    2010 4x4 Tacoma
    Right!! I did a full inspection and rotation before the trip... this wear happened within 2 days!!!
    JKU3000 likes this.
  9. Apr 26, 2020 at 5:43 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Are you saying the inside of the tire looked just like the outside of the tire prior to your trip? How many miles on the trip? And this all happened in a single trip?
    Alexely999 and Cam2010taco[OP] like this.
  10. Apr 26, 2020 at 5:43 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Take a head on picture of the front. Far enough away to see both tires.
    SR-71A and Cam2010taco[OP] like this.
  11. Apr 26, 2020 at 5:44 PM
    Cam2010taco
    Cameron
    Mission Viejo, CA
    2010 4x4 Tacoma
    Yeah the tires were absolutely symmetrical, and this happened just on a trip to Montana I returned home from yesterday
  12. Apr 26, 2020 at 5:44 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    If everything was good prior to the trip and you had rapid wear, something came loose and shifted.
  13. Apr 26, 2020 at 5:44 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Might be the angle but the camber looks like it's way too negative in the first pic.
    Cam2010taco[OP] likes this.
  14. Apr 26, 2020 at 5:45 PM
    mhshark
    Bend, Or
    Do you have a pic directly at the front of the truck? I feel like for wear like this to happen your camber has to be visible to the eye. I had a 335 that had a decent amount of camber and it took months for wear like this to develop
  15. Apr 26, 2020 at 5:47 PM
    gotoman1969
    I agree. Id start checking All the front suspension something is very wrong for that to happen that quickly.
  16. Apr 26, 2020 at 5:48 PM
    Cam2010taco
    Cameron
    Mission Viejo, CA
    2010 4x4 Tacoma
    Here’s the best picture of the front I can get right now, The camber can’t be bad enough to cause this big of a problem I don’t think. I agree cause I thought it was camber at first too. 45E6135F-EB1C-4FFA-9C24-7A2859FBF0BD.jpg
    also you can kinda see how the pattern cones in this pic that I was talking about.
  17. Apr 26, 2020 at 5:51 PM
    Cam2010taco
    Cameron
    Mission Viejo, CA
    2010 4x4 Tacoma
    I wonder if he could just take a look and try and figure out the issue before I have to spend so much on an alignment
    Skyway likes this.
  18. Apr 26, 2020 at 5:51 PM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    soft rubbers
    12TRDTacoma and Cam2010taco[OP] like this.
  19. Apr 26, 2020 at 5:52 PM
    jeremy5000
    jeremy5000 Well-Known Member
    Philadelphia
    A combination of improper toe and camber can cause this. I had a similar thing happen about 10 years ago to a nearly brand new set of Michelin Pilot Sports. I was livid to say the least. If you have the time, you can always do a rudimentary alignment at home to try to improve it for the time being.
  20. Apr 26, 2020 at 5:52 PM
    gotoman1969
    In that picture you just posted, left front camber is way way out.
