Tesla style head unit
Discussion in 'Audio & Video' started by arcenik, Sep 15, 2021.
  1. Jan 4, 2022 at 8:17 AM
    #681
    sngdawgs
    sngdawgs Active Member
    Scott
    2005 Toyota Tacoma TRD Double Cab
    Well just as a test....you can disable Carplay/Zlink in the android settings of the HU, connect your phone only to bluetooth then make some test calls with the native phone/dialer. Honestly if that does seem to be much better (I'm afraid it will be) the only other option if you want that Carplay feel you could look into the Carlink Kit 3.0. There's been some positive feedback on it in this thread. Someone else here may have other idea's/options.
  2. Jan 4, 2022 at 9:07 AM
    #682
    Hypertaco
    Hypertaco Well-Known Member
    Kevin
    Garner, NC
    2012 tacoma x-runner
    2012 Toyota Tacoma X-Runner TRD Pro Grill Magnuson S/C with TRD Flash and HPTUNER Tune Innovate Dual Gauge (Boost,EFR) (Not installed) Innovate Oil Pressure/temp Gauge (Not installed) Scangauge II Ultra Performance Thermostat from URD (not installed) 255 Fuel Pump from URD (not installed) JBA Exhaust URD CAI URS SS 6 speed TRD Shift Knob Leather Interior Custom Gauge Face for Speedometer from Blackcatcustom with X-Runner logo Blue LED's in gauge cluster with White Needles Tesla Style PX6 Android 9 12.1" Radio Custom Stereo Enclosure with Opt7 Led's Sundown X8 subwoofer Rockford Fosgate Component's Rockford Two ways 2 Alpine X-Power amps Bluetooth Stereo with Rockford 2-way in bed 19x10.5 Varrstoen ES9's Black 285/35/19 Indy 500's Gaylord Speedsturr Bed Cover Feal Coilvers - removed XII lowering Leafs - removed QA1 rear shocks - removed Back to brand new factory suspsension Kenwood Motorcycle Mount Bluetooth Stereo in the bed with 400w amp and Rockford speakers Wireless phone charger thanks to ThreatLevelMidnight
    anyone good at creating these files? would like to have one of my truck if that is possible.
  3. Jan 4, 2022 at 9:54 AM
    #683
    sngdawgs
    Scott
    Hyper do you have the Sergey Firmware? If so you can send him pics of your truck and he will create all the images for you. Part of the package you buy.
  4. Jan 4, 2022 at 9:59 AM
    #684
    Hypertaco
    Kevin
    Garner, NC
    Funny you should mention that. I was just on his facebook page and was about to ask him that question. Now I know, thank you so much!!! I'm going to be buying that firmware upgrade!
  5. Jan 4, 2022 at 5:44 PM
    #685
    whiting1977
    whiting1977 Well-Known Member
    Sacramento CA
    2014 SR5 PreRunner
    A really stupid question. My wifes Corolla uses a climate control where you can set an assigned temperature, similar to the feature on this unit. My tacoma of course only has a dial to increase/decrease temp. How does this unit allow the user to set a desired temp? Does the unit itself have a built in temp gauge to determine the temp of the air blowing into the cabin?
  6. Jan 4, 2022 at 5:47 PM
    #686
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    Joying uses Carlink 2.0 for their Android auto/carplay connection. They have the file on their firmware page. You could try loading it and see if it works
    Tbh, I never use wireless android auto, only wired. Wireless drains the battery so much
  7. Jan 4, 2022 at 5:54 PM
    #687
    Turbo-Taco
    Turbo-Taco Well-Known Member
    Randy
    Portland, Oregon
    2024 Toyota Tacoma SR5
    I believe the way this works, whether you have a dial or assigned temp number, is depending on where you set the dial or say the assigned number 78,80 or whatever you desired your blend door would either open or close more depending on whether you wanted more or less hot or cold air.
    whiting1977[QUOTED] likes this.
  8. Jan 4, 2022 at 7:55 PM
    #688
    JackmTaco
    JackmTaco New Member
    I'm not sure if this has been asked and after reading 15 pages, I didn't see it asked.
    What is the output voltage on the RCA pre-amp outputs?
    Also, how many bands of EQ control is on there?
    And lastly, is the sub output dedicated with its own crossover and separately controlled as well as the front and rear RCA having a separate high pass crossover?
    Thank you in advance for the assistance!
    Uncle Cliffy likes this.
  9. Jan 4, 2022 at 8:51 PM
    #689
    CF Sapper
    CF Sapper Well-Known Member
    Rob
    New Brunswick Canada
    09 TRD Sport long box
    Front and rear trailer hitch mounted winch.
    So I have read this entire thread and I have a new problem (outside of trying to get my android to connect to ZlinkI still don't know what I did to actually make it work as it just started working when I went out to grab dinner after fighting with it for near 4 hours and its very finicky) my remote starter now won't work, truck starts up just fine, and then immediately shuts off.
  10. Jan 4, 2022 at 9:09 PM
    #690
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    1. Unknown but there is an output gain adjustment in the settings from 0-30
    2. Eq = 16
    3. Sub yes and there is a dedicated bass boost menu that allows you to select the freq and gain. Yes high and low x overs too
  11. Jan 5, 2022 at 7:49 AM
    #691
    scootter82
    Aurora, CO
    Curious if this works better than zlink. From joying's site. I don't see why it wouldn't tbh
    Car-link 2.0 https://drive.google.com/file/d/1RlAQp2NsM2cWhGHIqAfhMAoIjJG8eBoL/view?usp=sharing
  12. Jan 5, 2022 at 8:13 AM
    #692
    sngdawgs
    Scott
    Adding the Power Amp EQ app helped control the music and added better control of Highs/Mids/Lows. It basically works in conjunction with the HU equalizer.
  13. Jan 5, 2022 at 6:13 PM
    #693
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    interesting i was curious to check it out when i saw sergey mention it as “ the best “ eq. does it have time alignment too ?
    if it is an android app does it work when your music source is from carplay ?
  14. Jan 6, 2022 at 1:35 PM
    #694
    Diabl0
    Diabl0 2005 TRD Off Road DC SR5
    Tim
    Massachusetts
    2005 TRD off Road DC SR5
    AUCar Android Stereo Bluetooth Katskin Leather Soft Bed Cover Dual kicker comp s10’s Bull bar Euro headlights Black grill Clutch bypass switch Alpine 6.5 and 6x9 speakers Kicker Subaru Tweeters Diamond floor mats Dick Cepek DC2 Wheels Toyo Open Country ATII Tires Black Aftermarket Grill Rhino lined Tube Side Steps Back up Camera
    Do you have to have sergey’s fw to use it?
  15. Jan 7, 2022 at 8:29 AM
    #695
    CF Sapper
    Rob
    So the polarization on these screen are the wrong way. If you use polarized sunglasses the screen goes black...tilt head screen works. Not ideal. :/
  16. Jan 7, 2022 at 9:19 AM
    #696
    Toy2022
    Toy2022 Member
    Jim
    2009 Tacoma
    I am definitely waiting on a purchase of this unit. Seems nobody installs without finding a new issue. The price of this should be lower base on these, they are high tech, but to many setup issues right now.
    crashngiggles and JackmTaco like this.
  17. Jan 7, 2022 at 9:26 AM
    #697
    Diabl0
    Tim
    Massachusetts
    Yes I noticed this too. It’s a shame
  18. Jan 7, 2022 at 10:08 AM
    #698
    CF Sapper
    Rob
    Yeah, I sorta agree but the look was exactly what I wanted and since I got it installed I've had very few issues once I got the bugs worked out (I still don't know that I did that fixed my issues but it works.) The sound is better than my old ass stock unit using the Toyota installed Bluetooth from 2009, install it's self was easy and not nearly as complicated as it looks. Set up was a bit finicky but customer service has been good. Overall I'm mostly happy with it though the issue with the polarization is annoying it's not a deal breaker. Im reaching out to them today about this just cause I like the idea, layout and even general execution of the product just the small details need work. Like any first gen product its got some bugs/issues.
    arcenik[OP] likes this.
  19. Jan 7, 2022 at 5:52 PM
    #699
    whiting1977
    Sacramento CA
    2014 SR5 PreRunner
    Question regarding the rear camera. I understand that when in reverse the rear camera is engaged, but if using the Car Monitor button within the apps window and selecting rear camera will it stay on even when driving? I want to be able to monitor my bbq smoker trailer when towing it.
  20. Jan 7, 2022 at 6:22 PM
    #700
    Turbo-Taco
    Randy
    Portland, Oregon
    Yes it does I posted a video about it earlier
