Tesla style head unit
Discussion in 'Audio & Video' started by arcenik, Sep 15, 2021.
  1. Nov 10, 2022 at 7:52 AM
    #1061
    Uncle Cliffy
    Uncle Cliffy Never tell me the odds.
    Clifford
    So. Oregon
    06 DCSB 4x4
    https://www.tacomaworld.com/threads/uncle-cliffys-build.327590/
    Thanks for the videos @arcenik!
    I’m curious if the unit can be configured to run a front and rear camera simultaneously? I have an 06 and it doesn’t have cameras at all. I was curious about running a cheater wheeling setup where I could see obstacles on the trail. Being able to see 2 images on the screen would be pretty cool…
  2. Nov 10, 2022 at 8:44 AM
    #1062
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    You will need an external video splitter box. Something like I linked below.
    4-Channel Car Video Splitter Controller - Digital Picture Video Signal Switcher with Quad Selectable for Backup Camera Video Monitor Systems CCTV Camera, PAL/NTSC Auto Adapting - Pyle PLVSPLT41 https://www.amazon.com/dp/B084G9RR14
    Uncle Cliffy[QUOTED] likes this.
  3. Nov 10, 2022 at 8:57 AM
    #1063
    Uncle Cliffy
    Clifford
    So. Oregon
    06 DCSB 4x4
    Well, sure I could definitely do it that way. I’ve seen that used with other head units. My question was more to the fact that since the unit has front and rear camera inputs, if the settings to the reconfigured to run them any time simultaneously without any external device.
    scootter82[QUOTED] likes this.
  4. Nov 10, 2022 at 9:48 PM
    #1064
    arcenik
    arcenik [OP] TRD
    Jon
    2015 X-Runner
    I went though all the settings and options and I cannot find a way to view the rear camera without activating reverse. On the old unit you could go to Aux and get the rear camera but on this one you can't. the only option would be to use a device like mentioned.
  5. Nov 10, 2022 at 9:50 PM
    #1065
    arcenik
    arcenik [OP] TRD
    Jon
    2015 X-Runner
    I also wanted to make a correction to the video. The AC button does work to turn off the compressor. It just does not work in low(as someone pointed out in the YouTube comments). As long as you are one temp setting above low you can turn off the compressor using the AC button.
  6. Nov 10, 2022 at 10:04 PM
    #1066
    Uncle Cliffy
    Clifford
    So. Oregon
    06 DCSB 4x4
    So being that there’s a front camera input, how is that activated?
    Also, I’m wondering if you could put a toggle switch in the reverse circuit to run it anytime.:notsure:
    scootter82 likes this.
  7. Nov 10, 2022 at 10:55 PM
    #1067
    arcenik
    arcenik [OP] TRD
    Jon
    2015 X-Runner
    Aucar is also working on an update for the Carauto app to fixed the split screen cutoff and reloading of the CarPlay.
    I have also been testing the vivid launcher on the screen. With this launcher it actually hides the bottom ac controls. This works great if you don't use CarPlay and just use a hotspot or 4g.
    Im going to make a video comparing the different launchers.
  8. Nov 10, 2022 at 10:57 PM
    #1068
    arcenik
    arcenik [OP] TRD
    Jon
    2015 X-Runner
    The front camera would be though the Aux input. There is an app to show the input.
    If you use something like the Pyle PLVSPLT41 mentioned above you could connect this to the Aux input. It could then show all the cameras at once.
  9. Nov 11, 2022 at 7:05 AM
    #1069
    Turbo-Taco
    Turbo-Taco Well-Known Member
    Randy
    Portland, Oregon
    2024 Toyota Tacoma SR5
    So this unit, much like the first, definitely has its glitches too. Given mine has all the glitches worked out of it now I’ll keep it it a bit longer and see what happens next year when Apple overhauls the carplay app. I’m curious to see what effects, if any, that has on these units given they are going to make it more integratable with cars systems. It probably won’t affect older vehicles much at all but newer ones will have features such as digital hvac controls and ability to change the look of your odometer and such right through their app. Looks to be like some interesting upgrades for newer vehicles.
  10. Nov 12, 2022 at 5:10 PM
    #1070
    Vin_Spin
    Vin_Spin Member
    Vincent
    2015 Grey Tacoma TRD Sport
    Rough Country Leveling kit, Tinted windows
    Hey guys, Ive had one installed since January and love it for what i use it for. This morning my backup camera stopped working. Screen just says "no signal." Haven't dug into it yet as i work crazy hours and have little down time. Has anyone had this issue and can point me in the right direction. I don't do any off-roading just use my truck as my daily, thanks for any help.
  11. Nov 12, 2022 at 5:31 PM
    #1071
    Diabl0
    Diabl0 2005 TRD Off Road DC SR5
    Tim
    Massachusetts
    2005 TRD off Road DC SR5
    AUCar Android Stereo Bluetooth Katskin Leather Soft Bed Cover Dual kicker comp s10’s Bull bar Euro headlights Black grill Clutch bypass switch Alpine 6.5 and 6x9 speakers Kicker Subaru Tweeters Diamond floor mats Dick Cepek DC2 Wheels Toyo Open Country ATII Tires Black Aftermarket Grill Rhino lined Tube Side Steps Back up Camera
    Yes I had this problem. It wasn't the head unit it ended up being a bad video wire so I replaced it and haven't had any issues. I'm a daily driver too.
  12. Nov 12, 2022 at 5:43 PM
    #1072
    Vin_Spin
    Vin_Spin Member
    Vincent
    Thanks for the quick response, can you give me a little more information regarding the video wire, location and where you got a replacement from? Thanks!
  13. Nov 12, 2022 at 6:06 PM
    #1073
    arcenik
    arcenik [OP] TRD
    Jon
    2015 X-Runner
    Factory or aftermarket camera?
  14. Nov 12, 2022 at 6:13 PM
    #1074
    Vin_Spin
    Vin_Spin Member
    Vincent
    Probably should've gave a little more information, sorry. 2015 TRD sport automatic with the factory backup camera.
  15. Nov 12, 2022 at 6:27 PM
    #1075
    Diabl0
    Tim
    Massachusetts
    I just bought a new camera and rewired it. I went to best buy. Sometimes the wires on the camera just stop working.
  16. Nov 12, 2022 at 6:42 PM
    #1076
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    Can you tell me how to get to best buy and how many miles you drove? Were you able to back out with no camera?
  17. Nov 12, 2022 at 6:45 PM
    #1077
    Vin_Spin
    Vin_Spin Member
    Vincent
    Thanks, I'm gonna take a guess and say your camera is aftermarket, mine's factory I forgot to mention that.
  18. Nov 12, 2022 at 6:57 PM
    #1078
    Diabl0
    Tim
    Massachusetts
    Yes it is it's a metra. I'm not sure about factory. If you don't have a best buy near you any auto or electronic store will carry one. I used a licence plate camera and now it works great now. You can go to best buy. Com and they will send you one. Or Amazon is cheeper.
  19. Nov 12, 2022 at 7:16 PM
    #1079
    Vin_Spin
    Vin_Spin Member
    Vincent
    Thanks, maybe I'll go that route if I can't get the factory one working. Figured I ask here in cause anyone had a similar issue with the radio and factory camera.
  20. Nov 14, 2022 at 12:10 AM
    #1080
    arcenik
    arcenik [OP] TRD
    Jon
    2015 X-Runner
    I would check the RCA connection on the back of the unit first. It should be labeled CCDV. Maybe it came loose.
