Tesla swapped 2wd 1st Gen build
Discussion in '1st Gen. Builds (1995-2004)' started by Drewthecarguy, Jul 17, 2023.
  1. Jul 17, 2023 at 5:08 PM
    Drewthecarguy
    Drewthecarguy [OP] Well-Known Member
    Drew
    2016 TRD OR
    3.6TT Engine swapped, Icon Stage 4, SCS wheels
    Alright I’m going to start a build thread now since I’ve got a pretty good lead on what’s going on.
    Little background story
    i finished my LS3 swapped 3rd gen Tacoma and was ready for something else so I unloaded it pretty cheap
    I bought a 2021 Tesla Model 3 standard range for a work car because gas was killing me in my 2023 Lunar rock 4runner for work.
    after owning the car for a couple months I pretty much feel in love driving a full electric car. The torque and power is addictive. So I got to thinking I needed to build an electric truck. After doing tons a research and finding frame dimensions of the 1st gen Tacoma I figured it would be a perfect contender.
    starting off I picked up a pretty nice 2002 5 lug 2wd single cab from a older gentleman in Tennessee, Rust free which is almost impossible to find where I live in southern Illinois
    I drove it around for a little while while I sold the 3rd gen and loved
    Driving the little truck around, but that came to a end and tear down started
    9F928B41-88BE-4024-A5E6-C0E609EF5A06.jpg F85E872E-47E4-4F0F-A4B7-FF0A6A8D30D3.jpg
    I knew I wanted to do a Tesla drive unit and not some other electric motors
    Tesla Model S drive units are a little to wide for the Tacoma so I picked up a Model 3 Performance test drive unit, should have about 300 or so horsepower and all the instant torque you can ask for
    I found a pair of Rotiform wheels locally for a really good deal so I picked them up 18x8.5
    then I started mocking it up and seeing what was needed
    04EDD227-966F-421F-8612-A9F52BC9199A.jpg 03997903-0F29-4675-A274-555727FEEEC9.jpg
    Mounting the drive unit was as easy as I thought it was going to be
    I welded a 2.5inch tube across the rear mounting locations and just had to build little tabs for the front mounting tabs
    I then welding some 3/16s plate around the rear tube just to make it a little more solid
    Next I had to figure out how to power this drive unit, there are all kinds of battery options out there, my goal was to have at least 200 mile range which is very hard from a EV conversion, so I picked up a Model 3 battery. This thing is enormous, heavy and expensive lol.
    you don’t see a lot of guys using the model 3 battery because it is so large.
    I started to take the battery apart because I had a idea lol
    there are 4 modules in a model 3 battery each one weighing about 300 or so pounds
    There is also a thing they call a penthouse which is on the top of the battery and it holds almost all the things needed for a EV conversion - dc/dc convertor, charger, contactors, battery management system. So I decided to relocate that to under the hood, so it’s easy accessible and kind of out of the elements, also when you pop the hood you see a shiny thing that says Tesla lol
    BD5E666A-D71A-4BC0-9A9C-04DACE2DE446.jpg 93B2300A-85E3-4C61-97B5-AB3D39C5D261.jpg A2F14F50-509F-41F4-8D70-D4FBA576BB09.jpg
    so the plan is to mount the two longer modules in between the frame rails and the other two will be in a custom battery box mounted in the bed, there really was no other way to stuff these massive batteries anywhere else, trust me
    so I have roughly mounted the two longer ones in the frame rails and I don’t think it can get any closer to fitting. I just need to build a little sheet metal or thin aluminum cover for it to seal it up
    I’m currently waiting for the battery box to be made from a local fab shop. Should be done this week then I’m going to have it painted body color to blend in in the bed of the truck.
    that’s about as far as I’ve gotten on the EV conversion part, I’m going to use EV controls controller to run all this. I’ll order that probably this week or so too.
    Now to handle this extra weight I ordered some QA1 plates from MJBtaco
    but I’m more of a fan of Ridetech/fox shocks over QA1 so I picked up a set of Ridetech HQ coil overs for a S10 which has the right shock but wrong spring weight (I’ll order right spring weights after doing a proper corner weight of the truck after it’s all together)
    then picked up some tie bars from speedway motors so they will work on the QA1 plate
    AFC0541E-00DF-4B94-868F-03F84B71A120.jpg A6A40453-E54C-444D-9E0D-F825C2E85130.jpg
    Next I picked up some used Brembo Cadillac ATS brake calipers. And a new set of the EVO brake rotors and had a local machine shop redrill and bore them out
    9C0A5D5D-A835-4117-AE61-28382EBD54B3.jpg 8955521A-E5C7-4C0B-8667-E32DCE46B56A.jpg
    and that’s where I’m currently at at the moment
    I really don’t have a lot left to go and this should be a fun one
    my plan is to do some autox and road race events
  2. Jul 17, 2023 at 5:10 PM
    Just_A_Guy
    Just_A_Guy Rain is a good thing
    On the hunt
    A truck
    First like and comment!
    I’ll read the post after :laughing:
  3. Jul 17, 2023 at 5:15 PM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    Subbed. :popcorn:
    Kolter45 and HondaGM like this.
  4. Jul 17, 2023 at 5:18 PM
    Kilo Charlie
    Kilo Charlie I have lost my way
    Iowa
    2017 Inferno Off Road
    In to watch this one!
    Taco critter, HondaGM and RustyGreen like this.
  5. Jul 17, 2023 at 5:20 PM
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    :eek:
    This is insane, I opened this thread thinking it was only an idea. I wasn't prepared to see a mad scientist actually doing it.
    Sub'd!
    Lawfarin, saf023, Kolter45 and 4 others like this.
  6. Jul 17, 2023 at 5:20 PM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    subbed
    HondaGM likes this.
  7. Jul 17, 2023 at 5:21 PM
    Whitetac0
    Whitetac0 Active Member
    David
    2021 Tacoma trd off road 4x4
    Wow :eek:
    HondaGM likes this.
  8. Jul 17, 2023 at 5:23 PM
    Drewthecarguy
    Drew
    2016 TRD OR
    I don’t mess around lol
    Lawfarin, Steves104x4, saf023 and 7 others like this.
  9. Jul 17, 2023 at 5:24 PM
    roboturner
    roboturner Dead Eyed
    Colorado
    00 IJM AT XC 4x4 3.4L TRD | 18 CB MT DCSB 4x4 V6 Pro | 98 NW MT 4x4 3.4L SR5 4Runner
    This is what the people want!
    HondaGM and Squirt like this.
  10. Jul 17, 2023 at 5:25 PM
    Just_A_Guy
    On the hunt
    A truck
    Don’t unload lead this one pretty cheap!
    HondaGM, doublethebass and Squirt like this.
  11. Jul 17, 2023 at 5:28 PM
    Squirt
    Squirt Certified in forklifts and meme stealing =)
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back. J&L catch can
    Not an EV guy but this is still sweet! Know what you mean about finding a good rust free Tacoma I'm IL! :annoyed:
    HondaGM and Just_A_Guy like this.
  12. Jul 17, 2023 at 5:31 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Agree :thumbsup:
  13. Jul 17, 2023 at 5:52 PM
    Kilo Charlie
    Iowa
  14. Jul 17, 2023 at 5:55 PM
    Azza
    Azza ㅤㅤㅤㅤㅤㅤㅤㅤㅤ
    This is so awesome! I can't wait for more updates and pictures.
    HondaGM likes this.
  15. Jul 17, 2023 at 5:56 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
  16. Jul 17, 2023 at 5:58 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    Hell yeah dude! I’m a big fan of your work! I was able to attend professors John Kelly class at Weber State University. I still have his contact so if any questions arise please let me know! Keep up the good work dude!
    HondaGM likes this.
  17. Jul 17, 2023 at 6:00 PM
    YourActualName
    YourActualName Well-Known Member
    NH
    2015 Black Tacoma Limited DCLB
    Magnuson SC, +
    Looks factory to me!
    Squirt and HondaGM like this.
  18. Jul 17, 2023 at 6:18 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Nice! You doing only the rear motor from the model 3 performance? Both motors combined are closer to 550hp. Also which battery pack are you using? There are several available in the 3.
    HondaGM likes this.
  19. Jul 17, 2023 at 6:19 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  20. Jul 17, 2023 at 6:29 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    So it’s interesting. But the weight is a real problem.
    I am wondering if you could potentially be better off without the bed mounted battery parts?
    I’m personally leaning leaf guts. But some of that is my irrational Musk hate.
