Tesla Truck
Discussion in 'General Automotive' started by Boerseun, Jul 22, 2016.
  1. Dec 12, 2017 at 2:34 PM
    #81
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Now this could be interesting...............then my NG generator could be bkup to the powerwall............
  2. Dec 12, 2017 at 4:30 PM
    #82
    Boerseun
    Boerseun [OP] Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    Tesla has recently released these: (for what it's worth)
    And:
  3. Dec 13, 2017 at 4:43 AM
    #83
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    black one looks like darth vader model.................
    Boerseun[OP] likes this.
  4. Dec 13, 2017 at 4:46 AM
    #84
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
  5. Dec 13, 2017 at 4:52 AM
    #85
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
  6. Dec 13, 2017 at 5:26 AM
    #86
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    As interesting as the idea of unlimited range would be it's not practical. It takes about 3.5 hours using a 240V/50A circuit to give a Telsa about 100 miles range. Specifically 33.6kW needs to be returned to the battery (their built-in charger is 9.6kW).
    If you have a typically sized solar panel you use for topping your fridge battery it's probably about 100W, maybe 50W even. Assuming you have typical efficiency and incidence your 100W might average 50% over the whole day if the sun is good.
    So if your truck is dead and needs to go 100 miles back home from camp you're going to wait 672 hours or almost 2 months (56 days) with 12 hours of daylight if you have 50W on average from your panel.
    Or put another way, if you want to go 100 miles a day and want to move every day you need to sit still during daylight for some amount of time. So let's say we're talking a typical summer day in an average place, perhaps the Midwest. So you're getting 12 hours of daylight, so you want to do 6 hours of driving and 6 hours of charging.
    You'll need to be able to do 5.6kW for 6 hours, which means 24 x 240W panels. Those are usually about 35 lbs each and around 60" x 48" x 2", which means you'll carry 840 lbs of solar panels that take 80 sq-ft of cargo space (with 480 sq-ft of surface that needs to be exposed to sunlight) to charge enough for 100 miles in 6 hours.
    That's why an EV off highway truck isn't practical. You need a reliable, high capacity power source. Since you want to be active during the day a hybrid is necessary. But it still needs to be a decent sized generator, 3kW or so, that runs all night.
  7. Dec 13, 2017 at 5:32 AM
    #87
    Boerseun
    Ferdie
    Sarasota, Florida
    Several companies, including Tesla, are working on "charge as you go" systems. It will be built into the road and will charge the battery without being plugged in, similar to the new cell phone chargers that you just put down on a dock instead of plugging it in. To your point above, it will work on-road, but obviously not feasible for any off-road use. Some interesting times ahead of us.
    SOSC likes this.
  8. Dec 13, 2017 at 6:08 AM
    #88
    PaulK
    PaulK Life is hard. It's harder if you're stupid.
    Paul
    Pittsburgh, PA
    2013 Black Baja Access Cab
    When battery technology catches up - and it will - the range for EVs will be comparable to typical gas vehicles. If that's the case, why couldn't you go off road in one? Plenty of folks go off road without carrying extra gas. Solar charging in the field is impractical, but the idea that this prevents off road use is incorrect.
    Also, just like cans of gas, I can imagine people carrying extra auxiliary battery packs. I carry one now for my phone. In a pickup truck you could add gerry can sized battery units as needed for extra range.
    Just because we can't do it now, doesn't mean it won't be normal in a decade.
    Boerseun[OP] and SOSC like this.
  9. Dec 13, 2017 at 6:44 AM
    #89
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    The running out of fuel comparison is true, you have a given range and work within it. The question is comparable range and practicality.
    Perhaps battery technology will eventually work out. Gasoline is around 44 MJ/kg and weighs about 0.75 kg per liter. So a standard 20L jerry can gets you 660 MJ. Or in American terms, a gallon of gasoline is about 6 lbs and gets us the equivalent of 36kW-hr and a 5 gallon can gets you about 180 kW-hr.
    An 18650 cell gets you about 45 kJ and weighs about 50 grams, e.g. you get about 0.9 MJ/kg. That's the problem, if 20L of gasoline gets you 100 miles then you need to carry 733 kg (1,615 lbs) of spare battery to get the same extra 100 miles that 32 lbs of gasoline got you.
    Put this another way. A Tesla can carry about 50 kW-hr of energy onboard. This is roughly equivalent to 1.5 gallons of gasoline. So you can in theory fully power a Tesla more than 3 times on a single jerry can of gasoline. This of course ignores that an internal combustion engine is inefficient at converting the fuel into work.
    It's all about power density and there's a really long way to go to figure this out. It's not a matter of figuring out technology, it's physics. We'll figure out how to make things better. The next step is lithium metal batteries (which aren't current rechargeable). They get about 4 MJ/kg, so it's about one order improvement in density. Batteries aren't a new thing either, we've been working on them for a very long time already. It's possible that improvements aren't decades away or maybe ever. Fuel cells are the next step.
    But it's not an apples-to-apples. Batteries are energy carriers, not energy sources. Fuel is an energy source, the sun is an energy source. There's no foreseeable future where you can carry spare batteries in the same way as you carry spare fuel. We need to focus on finding better energy sources with less negative sides. Solar cells and wind generation require a lot of heavy metal mining and toxic processing and aren't that space efficient at doing it. Hydroelectric ruins landscapes and ecosystems with dams, nuclear, coal, etc. of course are polluters. Hydrogen is currently a net negative, since it takes more energy (via steam reforming or electrolysis) to create than you get back out. It's somewhat ironic that the majority of industrial hydrogen currently is produced as a byproduct of petroleum refining.
    Full electric vehicles only can be justified for zero tailpipe emissions and therefore as a way to move city pollution and disperse it. If the market wants people to embrace electric vehicles they need to focus on hybrids that fit lifestyles. A diesel electric truck would be simply awesome. I worry about the complexity but I also used to worry about EFI when I got my first truck without a carburetor, too. There's a $1 billion prize sitting out there for anyone who can match battery energy density to gasoline, so there's incentive for ya.
    PaulK[QUOTED] likes this.
  10. Dec 13, 2017 at 6:58 AM
    #90
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^Funny enough many giant off-road dump trucks are diesel electric. They implement it effectively to eliminate the traditional transmission and portions of the drivetrain.
  11. Dec 13, 2017 at 7:08 AM
    #91
    PaulK
    Paul
    Pittsburgh, PA
    Not directly related, but Nova did an episode on battery technology that was really interesting: https://www.youtube.com/watch?v=gxZrQ5yPsLI
    Lot's of money and resources being applied to this. The future will exciting!
    SOSC likes this.
  12. Dec 13, 2017 at 7:09 AM
    #92
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    Completely agree, there's well established ways with mining trucks and locomotives. They are absolutely all about squeezing the most work from a fuel source.
    PaulK likes this.
  13. Dec 13, 2017 at 7:10 AM
    #93
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    sweet!
  14. Dec 13, 2017 at 7:14 AM
    #94
    PaulK
    Paul
    Pittsburgh, PA
    Somebody Photoshop this and add a plate bumper, a bed rack, and a RTT!
    BillsSR5[QUOTED] likes this.
  15. Dec 13, 2017 at 11:53 AM
    #95
    PaulK
    Paul
    Pittsburgh, PA
    Also in "heavy duty local transport": https://www.wrightspeed.com/
    A mini multi-fuel turbine driving a generator, and an all-electric drivetrain. Whose going to swap it into one of these?
  16. Dec 13, 2017 at 12:55 PM
    #96
    KenLyns
    Belly of the Beast
    Another $1 billion for anyone who can come up with the charging infrastructure to feed such dense batteries ;)
    Think about a gas station with all pumps in full use at Costco. To transfer the equivalent chemical energy in electricity in the same duration, the power draw is something like 5% of a nuclear reactor output.
    DaveInDenver[QUOTED] likes this.
  17. Dec 13, 2017 at 1:04 PM
    #97
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    Yup. That's what I was implying earlier. If it takes 5 minutes to empty a jerry can into your tank that's the same energy transferred as 3-1/3 full Telsa Model S recharges, which would take about 31.5 hours using their regular NEMA14-50 (9.6kW-hr) charger.
    06Tacooo likes this.
  18. Dec 27, 2017 at 12:05 PM
    #98
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
  19. Dec 27, 2017 at 5:21 PM
    #99
    KenLyns
    Belly of the Beast
  20. Dec 28, 2017 at 12:06 PM
    #100
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    SOSC likes this.
