Test rode a '16 TRD Sport tonight... loved it... but...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by vuTron, Sep 9, 2015.
  1. Sep 10, 2015 at 2:41 PM
    #101
    unclemat
    unclemat Well-Known Member
    2012 TX Baja
    It's sign of times.... You get car enthusiasts who don't know what engine braking is (and who probably have no idea how to drive a manual transmission), or those who believe engine braking does a damage...
    :facepalm:
    Lord Helmet and Doggman like this.
  2. Sep 10, 2015 at 2:42 PM
    #102
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    Yeah I like Toyota does that hurt your feelers? Go find another truck to go to since Toyota ruined your day
    BlkTaco47 likes this.
  3. Sep 10, 2015 at 2:43 PM
    #103
    archerm3
    archerm3 Well-Known Member
    Nebraska
    97LX (sold) 15DCSB BRM MT OR(RIP) 09 Tahoe
    Brake controller, Snugtop, Hellwig981, Gentex, custom frame bending and body removal by red light runner.
    Its amazing what you learn with an engineering degree. But yes its amazing what people who get on the interwebs without schooling believe.
  4. Sep 10, 2015 at 2:43 PM
    #104
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Only way to tell if you like it is to drive it. The 2016's just started to arrive at several local dealership. I think I'm gonna test drive just so I can compare to the 4.0 with vvti and dual vvti.
  5. Sep 10, 2015 at 2:43 PM
    #105
    DrFunker
    DrFunker Well-Known Member
  6. Sep 10, 2015 at 2:46 PM
    #106
    archerm3
    Nebraska
    YRMV....
    When the cylinder goes off....pressure in chamber >> crankcase pressure, rings curl down. Intake stroke....chamber pressure < crankcase pressure. Rings curl up. How your rings get broken in initially determines the wear pattern, and continued use or overuse determines the longevity even further. Ever see a vehicle with MT that had specific instructions NOT to engine brake in the first several hundred miles? I have.
  7. Sep 10, 2015 at 2:46 PM
    #107
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    Engine rebuild at 100k from engine braking.. thats comical. I'm with you though in the sense that you can over do the down shifts to utilize engine braking. When slowing I normally downshift once, twice if coming from 5th, (never into 1st) and then use engine braking and regular brakes until I get to ~1500 rpm and put it in neutral. Where I use engine braking the most is in moving traffic.. I never sit on the clutch or clutch in to brake, instead I just leave it in gear or down shift and use engine braking as necessary.. this reduces clutch actuations and wear and tear across the board in my opinion.
    Gotten off topic but oh well.
  8. Sep 10, 2015 at 2:50 PM
    #108
    Zach O
    Zach O Well-Known Member
    Zach
    Texas
    2015 TRD Off-Road SWFTMFW 6 speed
    I don't see how compression alone (which is what slows you down during engine braking) causes any more wear than the mixture of gasoline and air exploding in the cylinder.
  9. Sep 10, 2015 at 3:01 PM
    #109
    Gatordog
    Gatordog Well-Known Member
    Florida
    18 TRD SPORT DCLB4x4
    um Rock Lobster I believe it's "just sayin" LOL... no idea what happened in this thread.....you lost me at cylinder pressure and ring bending :)
  10. Sep 10, 2015 at 3:06 PM
    #110
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Fucking #rekted
  11. Sep 10, 2015 at 3:09 PM
    #111
    archerm3
    Nebraska
    Its not the compression. It's the high vacuum on the intake stroke from excessive rpms trying to suck way more air through a closed throttle.
  12. Sep 10, 2015 at 3:11 PM
    #112
    archerm3
    Nebraska
    Like I said....YRMV. Exactly how long does an engine last? who knows...I don't, you don't....
    Exactly how long does a clutch bearing last? who knows...I don't, you don't....
    Exactly how long will a guy drive a car that's burning oil or squeaking down the road with a noisy clutch? who knows....
    YRMV.
    Doesn't change the fact that high vacuum situations puts more wear on rings than not going into high vacuum situations at all, and running torque through gear pairs in the opposite direction puts loads in the opposite side of the normal bearing load axially and radially and changes the wear on the tooth surface.
    My last taco had 225000 when I sold her and didn't use a lick of oil between changes and I engine braked more than I cared to. Two of my autocross cars both starting burning oil prematurely...wonder why that happened with so much time spent engine braking for racing purposes.
  13. Sep 10, 2015 at 3:18 PM
    #113
    TashcomerTexas
    Can someone put someone in a headlock already?
    Lord Helmet and DoorDing like this.
  14. Sep 10, 2015 at 3:19 PM
    #114
    TashcomerTexas
    If you ain't @paramud with an actual 3rd gen then you ain't shit in these forums.
    Simon's Mom likes this.
  15. Sep 10, 2015 at 3:20 PM
    #115
    archerm3
    Nebraska
    That's a nice personal insult there lock raw. Well done!
  16. Sep 10, 2015 at 3:23 PM
    #116
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    You want to buy a new one with the same issues as the first and second gen? o_O To each their own.
  17. Sep 10, 2015 at 3:28 PM
    #117
    Gincoma
    Salt Lake City UT
    Im keeping my trouble free 2nd gen till the wheels fall off.
  18. Sep 10, 2015 at 3:31 PM
    #118
    archerm3
    Nebraska
    Not saying it's all just the engine braking...what else is harsh about autocross as far as the engine is concerned? full throttle off throttle full throttle off throttle.
    Are you saying full throttle is the only thing that wears out engines?
  19. Sep 10, 2015 at 3:32 PM
    #119
    unclemat
    2012 TX Baja
    Oh, yeah, that proves it. Totally stastically relevant sample set. I bet at least one of them was a Subaru, and therefore we can conclude Subaru makes crap engines.
    Doggman likes this.
  20. Sep 10, 2015 at 3:44 PM
    #120
    archerm3
    Nebraska
    I don't know what rock you guys live under that you've never heard of this. You guys are taking this way out of proportion which means you really don't understand much about mechanics. You guys are trying to imply that saying something increases wear equates to something being completely destroyed or unusable. You have no concept of relativity and qualitative comparison.
    Its amazing how many outspoken uneducated dweebs are on TW compared to all the other forums I've seen.
