Testing 4WD
Discussion in '1st Gen. Tacomas (1995-2004)' started by egl28, Oct 4, 2011.
  1. Oct 4, 2011 at 7:18 AM
    egl28
    egl28 [OP] New Member
    Northeast
    04 Tacoma SR5
    I am new to this message board, new to this truck as well as 4WD's. I am in the process of assessing a used "04 double cab, 6 cyl. automatic. No snow, ice, or sand in the area right now to test the system. Is there an easy way to assure that the 4WD system is not damaged and functioning properly? Thank you.
  2. Oct 4, 2011 at 7:28 AM
    TACODACKS
    TACODACKS Forging Elite Fitness
    The Streets of America
    Engage the 4WD- you will notice the ride getting "rougher" and the engine will get louder.
  3. Oct 4, 2011 at 7:33 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    :notsure:Find some wet grass?
  4. Oct 4, 2011 at 8:52 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    A lift... or for jackstands and make sure your not aimed at anything
  5. Oct 4, 2011 at 9:34 AM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    Slam that bitch into 4L and press the accelerator pedal..if you go nowhere fast then it's good.
  6. Oct 4, 2011 at 9:35 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    ^What he said.
  7. Oct 4, 2011 at 9:38 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    That wouldn't check your front driveline necessarily....
    something with the ADD or the cv's could be amiss..
    that would tell you your t case was engaging though
  8. Oct 4, 2011 at 9:41 AM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    Ok, turn the wheel some, you'll feel the binding.
    Done deal.
    It's really not that hard, it's simple as fuck.
    Everybody in the entire world makes it SEEM so hard.
    A stock truck 99% of the time isn't going to have a broken front diff or case..it's pretty hard to break them(unless your doing donuts in 4L on pavement while dumping the fuck out of the clutch)..so long as your case engages in lo range...then 4WD is FINE
  9. Oct 4, 2011 at 9:41 AM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    Plus!
  10. Oct 4, 2011 at 9:46 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    I converted my prerunner to 4x4, I feel I understand the 4wd system pretty well, does that count or do I still have to leave?
    The Vacuum and electronic actuators have been known to fail...
    Edit: Why Edit??
  11. Oct 4, 2011 at 9:49 AM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    Lulz, because I forgot I was talking to G Scott..I thought you were someone else.
    Your like one of the active members who actually did the swap.
    and I'm just giving you a hard time..I'm aggravated at work and using TW as a release.
    Plus I drive a 89' Pickup..I ain't got none of that bullshit actuator crap. Manual hubs, Manual case, Manual transmission. Ready to fucking rock your motherfucking socks!
  12. Oct 4, 2011 at 10:26 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    You can roll a few feet forward and reverse in front of your house to test if the lights go on, you hear the click or thump... Also try low range and the locker if you have an Off Road TRD. The locker is the most difficult to engage and disengage, typically taking a few attempts. Just roll forward and back in front of your home or work... Avoid turning the wheel on dry pavement. Better yet, test during rain or snow, then you can turn some while moving... turning while still or moving slow will be difficult in 4WD unless the surface allows the tires to slip.
  13. Oct 5, 2011 at 3:06 AM
    egl28
    Northeast
    04 Tacoma SR5
    Thanks for all your input guys!
  14. Oct 5, 2011 at 3:10 AM
    yotamikez
    yotamikez Street glide or die
    Valrico
    04 civic & 08 Street glide
    x2
