Testing A/C Refrigerant
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Orbang, Jan 13, 2021.
  1. Jan 13, 2021 at 5:00 PM
    Orbang
    Orbang [OP] Active Member
    Gerald
    Tacoma 2006
    My situation is that my A/C isn't working. Appears the compressor isn't working.
    I've read multiple times that you can't really go by the static pressure readings when the A/C isn't running.
    So here's my question; If I can't get running pressure reading how do I go about troubleshooting exactly what the problem is. I can assume the compressor but that's just a guess.
  2. Jan 13, 2021 at 5:35 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    you have to get the compressor working before you can do anything with refrigerant
    so:
    a) is the clutch working on the compressor, it should be audible with the hood up between the click and the load on the engine
    b1) you get the clutch click but no change in engine load, the compressor is probably destroyed in side
    b2) you get a click and a heavy load change, compressor is jammed with shrapnel or to much refrigerant so there is liquid in the compressor
  3. Jan 13, 2021 at 6:15 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    It's possible you have a refrigerant leak which may be affecting the compressor engaging or not. Typically I'd evacuate the lines and vacuum test it to rule that out.
  4. Jan 13, 2021 at 6:21 PM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Take it to a shop. They have the proper equipment to test the system.
    Muddinfun likes this.
  5. Jan 14, 2021 at 12:41 PM
    Orbang
    Gerald
    Tacoma 2006
    Thanks for the replies. It seems like the clutch may be a problem. The pully is turning but about every few minutes it starts to make a chattering noise then stops. This happens with or without having the AC turned on.
    I was trying to avoid the high shop charges but maybe I can just start by asking them to do an initial assessment. But from the various posts on here it always seems like the shops either don't want to give an estimate based on actual testing or jump right to saying you got a bad compressor.
  6. Jan 14, 2021 at 12:54 PM
    CraigF
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    well check that the electrical connections are clean and tight
  7. Jan 14, 2021 at 6:54 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Reach down and try to turn the compressor hub with the engine off, if you can't turn it it's bad, if you can then further diagnosis will be required.
  8. Jan 17, 2021 at 10:56 AM
    Orbang
    Gerald
    Tacoma 2006
    Thanks all for the comments will be looking into this further in the next while.
