Testing air recirculate mode
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jay1313g, Feb 13, 2020.
  1. Feb 13, 2020 at 7:45 PM
    Jay1313g
    Jay1313g [OP] Well-Known Member
    Jay
    Arlington, TN
    2018 SR5 DblCab 2WD
    I recently picked up a used 2018 SR5 and have noticed that the windows fog up VERY easily. (I've had a 2017 Tacoma before and didn't have the issue.)
    I THINK the recirculate door is stuck in the closed position, but don't know how to troubleshoot.
    QUESTION: If have have your fan speed set to OFF, the recirculate light is NOT on, and the air diverter is set only to the upper vents (not defroster), will you have air flowing through those upper vents when you drive down the road. Essentially free flowing and not being pushed by the fan.
    Mine does not have free flowing air under that condition even if I crack open the rear sliding glass. That should create a vacuum and pull air through the vents. I only get air through the vents when the fan is turned on.
  2. Feb 13, 2020 at 7:49 PM
    Marek71
    Marek71 Well-Known Member
    2019 TRD Sport DCSB
    Yes I have air flowing through the vents when the fan is off and diverter set to the upper vents.
    Chew likes this.
  3. Feb 13, 2020 at 7:53 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    rear sliding glass open won't have the effect you think. crack a side window one inch, that will pull air into the system far better
    GreyBaldTaco likes this.
  4. Feb 13, 2020 at 7:53 PM
    Jay1313g
    Jay
    Arlington, TN
    2018 SR5 DblCab 2WD
    That's what I thought. :\
    The good news is that I think I know what is wrong. Now, I've just got to get Toyota to agree and fix it.
    Thanks!!!
  5. Feb 13, 2020 at 7:55 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    yeah, sounds borked. should def feel some breeze in the vents with no fan and no recirc. dash is coming off if
    it is not a circuit fault
    Jay1313g[OP] likes this.
  6. Feb 13, 2020 at 7:55 PM
    Jay1313g
    Jay
    Arlington, TN
    2018 SR5 DblCab 2WD
    I actually did that also.
    I'm pretty certain that recirculate door is stuck shut. This truck fogs quicker than anything I've ever had before other than my '74 Nova back in High School, but that is a different story. :bananadance:
  7. Feb 13, 2020 at 7:56 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    The windows in my 2010 RC seem to fog up really easily at times too, and it seems like the defogger doesn't work worth a damn!
    shakerhood likes this.
  8. Feb 13, 2020 at 9:32 PM
    AtomAnt
    AtomAnt Well-Known Member
    Adam
    South Cackalacky
    2019 TRD Sport
    My 2019 fogs like crazy. Seems like I use defrost more than any other setting.
  9. Feb 14, 2020 at 12:50 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    If you have condensation check for moisture near 3rd brake light. One of the signs of a leak and water in cab is moisture/excessive fog on glass
  10. Feb 14, 2020 at 1:07 AM
    Fishnwiz
    Fishnwiz Well-Known Member
    Bill
    2019 Silver TRD ORDCSB 4x4
    My 19 seems to also but I keep ac on reguardless of temp setting, keeps it from fogging up
  11. Feb 14, 2020 at 1:19 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    Are you turning the AC off when you turn on the defroster?
  12. Feb 14, 2020 at 2:15 AM
    AtomAnt
    Adam
    South Cackalacky
    2019 TRD Sport
    I have been, yes.
  13. Feb 14, 2020 at 2:34 AM
    Fishnwiz
    Bill
    Ac dries the air, I thought it was automatic when you switch to defrost
    Chew and GreyBaldTaco like this.
  14. Feb 14, 2020 at 2:54 AM
    GreyBaldTaco
    2019 F150 5.0
    Stop doing that, there is a reason it comes on automatically
    ryan760 likes this.
  15. Feb 14, 2020 at 4:41 AM
    Markc1024
    Markc1024 Well-Known Member
    Check the cabin filter also - the recirc door is in the same area.
    Jay1313g[QUOTED][OP] likes this.
  16. Feb 14, 2020 at 4:29 PM
    Jay1313g
    Jay
    Arlington, TN
    2018 SR5 DblCab 2WD
    I did think about that and the cabin air filter is brand new.
  17. Feb 26, 2020 at 6:43 PM
    Jay1313g
    Jay
    Arlington, TN
    2018 SR5 DblCab 2WD
    Problem solved: The servo on the door that opens and closes to allow fresh air in had to be replaced. All is good now.
    tcjacado and Mikeincal like this.
