Testing cruise actuator
Discussion in '1st Gen. Tacomas (1995-2004)' started by a7scenario, Mar 14, 2024.
  1. Mar 14, 2024 at 2:04 PM
    a7scenario
    a7scenario [OP] Well-Known Member
    Austintown Ohio
    2002 Tacoma ext cab 4x4 automatic TRD
    None keeping her stock
    Is there a way to test the cruise control actuator to see if it’s malfunctioning? My cruise control doesn’t work, it never has since I’ve owned it. It’s a 2002 3.4 auto 4x4 xtra cab. The light comes on on the dash, but otherwise there’s no response. The brake switch seems ok, fuses good. I can buy a used actuator (88002-04020) on eBay for $150, but I figured I’d see if there’s a way to be sure that’s the issue before I drop the coin. I have a bad tendency to throw money at problems and not resolve them.
  2. Mar 14, 2024 at 6:05 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    There are so many inputs to the cruise control ECM without the correct Schematic for your your 2002 I would not want to even guess . With the Schematic I would trace every circuit.
    I never used one so never worked on them but to remove the parts.
