Testing exhaust system flow?
Discussion in 'Performance and Tuning' started by dwntwnall4u, Jul 14, 2009.
  1. Jul 14, 2009 at 2:29 AM
    dwntwnall4u
    dwntwnall4u [OP] Well-Known Member
    Kevin
    san diego
    2013 4x4 Dbl cab Auto
    Powered by ^CBD Cannabidiol
    Is there a way to test the actual flow of a given exhaust system?
  2. Jul 14, 2009 at 4:02 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Dyno?
  3. Jul 14, 2009 at 4:44 AM
    branct06
    branct06 Well-Known Member
    Thomas
    norcross Ga. and High Point Nc.
    05 4x4 black sr5 long bed trd sport
    super 40 flowmaster turned down before rear axle, k&n intake, ipod interface, 20% 3m tint all the way around, grill craft mx series grill with 2 hella 500 behind the grill, 2 55 watt halogens mounted on uws black low profile toolbox, 3'' toytec ultimate lift kit sitting on black xd monsters and 285/65/18 BFG A/T, HID headlight kit
    i know when i was looking for the right sound exhaust for my truck i cut the stock muffler off and then just held up multiple mufflers to the pipe and i got a basic idea on sound
  4. Jul 14, 2009 at 5:26 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    A buddy of mine fabbed up this rig useing a small leaf blower. He measures the amount of curant draw on the motor, and the air velocity at the end of the pipe. Now, This isnt the most scientific way, AND, being as it is not a pulse like an engine produces, you cant measure scavenging, BUT it does seem to give an idea of what flows better than another.
  5. Jul 14, 2009 at 6:51 AM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    Sited from http://www.broaderperformance.com/muffler_flow_tests.htm
  6. Jul 15, 2009 at 12:13 AM
    dwntwnall4u
    Kevin
    san diego
    Sounds like a cool idea, because I wanted to build an exhaust system but how do you really know what it flows when complete?
  7. Jul 15, 2009 at 5:25 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The best way is tto learn how an exhaust affects the engine, before you do anything. Bigger isnt Better. Then, in my case, it was trial and error. You should dyno your set up to be able to see what works and such.
  8. Jul 16, 2009 at 7:43 PM
    TRON
    TRON Well-Known Member
    Boulder
    2008 Sport
    TRD Blower, TRD CAI, JBA Headers, Custom 3 inch exhaust, 2.7 APR pulley, APR 7th Injector, Ucon EMS, 255 Walbro pump, NST OverDrive Pulley Kit, B&M Shifter, AIS Methanol Kit, TR Lowering Kit, URD Stage 3 Clutch, Etc...
  9. Jul 16, 2009 at 8:11 PM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    It would be a good option for sure. Can't really say anything is better then the other with numbers to back it up.
    But under boost, more volume will help. :thumbsup:
