Testing Ignition Coils in my '97 3vz-fe 4x4...
Discussion in '4 Cylinder' started by RichardGrayJr, Aug 31, 2012.
  1. Aug 31, 2012 at 7:37 PM
    RichardGrayJr
    RichardGrayJr [OP] New Member
    Richard
    Elllijay, GA
    Tacoma 4x4 w/ 478,000 mi and counting!
    I have searched everywhere trying to find which pins on the coil to test. I can find all sorts of threads discussing the, but none explaining which pins on the coil I need to test. It's been a really frustrating experience and any help would be greatly appreciated. I cannot find my Haynes manual anywhere so you guys are my only hope! Thanks in advance for the help...
  2. Aug 31, 2012 at 7:55 PM
    blakes09
    blakes09 Toyota Tech..when im not Fishing
    Blake
    Deep South
    4x4
    IGNITION COIL INSPECTION
    1. DISCONNECT HIGH-TENSION CORDS FROM IGNITION COILS
    2. DISCONNECT IGNITION COIL CONNECTORS
    1. INSPECT SECONDARY COIL RESISTANCE Using an ohmmeter. measure the resistance between the positive (+) and high-tension terminals.
    Secondary coil resistance
    Cold: 9.7 - 16.7 K ohms
    Hot: 12.4 - 19.6 K ohms</B>
  3. Aug 31, 2012 at 8:07 PM
    RichardGrayJr
    Richard
    Elllijay, GA
    Can you tell me which terminal is the positive and which are the high tension? I'm sorry for the ignorant questions, I'm just so dang aggravated!
  4. Aug 31, 2012 at 8:15 PM
    98tacoma27
    Ben
    Not Beech Creek
    Page IG-4...second pic
  5. Aug 31, 2012 at 8:22 PM
    RichardGrayJr
    Richard
    Elllijay, GA
    Thanks Tacoma, this has driven me nuts. Thanks for the help, fellas.
